johnnytran Posted November 3, 2022 Posted November 3, 2022 On 11/1/2022 at 9:40 PM, Netduma Liam said: @alex.devine @johnnytran Have you guys tested out my suggestion above? The key part being adding the custom rule to Traffic Prio, I think it should help you. As you mention, we are also working on a update to help DumaOS detect the new CoD's traffic much more fluently, that should improve matters. Yes just tested it step by step but my game ran like ass. I didn't get to try the advanced option, by default if you don't select advanced it gets set to gaming/voice, not "normal (default)" like it mentions in the advanced option I'll try the other options tomorrow
Alex49H Posted November 3, 2022 Posted November 3, 2022 14 hours ago, TODDzillaInLA said: I have mentioned this before the faster your internet connection the harder the game handicaps you, use the sliders and dumb down the connection 20mb download 5mb upload and set mtu to 750 I tried changing MTU on PS4 to 750, the game stayed at the loading screen and would not start. 😬
DUMA BOLTON Posted November 3, 2022 Posted November 3, 2022 1 hour ago, Alex49H said: I tried changing MTU on PS4 to 750, the game stayed at the loading screen and would not start. 😬 Same! Anything below MTU 1400 is a bingo for me, the games just won’t load
K0NSPIRACY Posted November 3, 2022 Posted November 3, 2022 Apparently Xbox needs a minimum of 1380 MTU (or a similar figure) so it may be the same for PS.
Alex49H Posted November 3, 2022 Posted November 3, 2022 4 hours ago, DUMA BOLTON said: Same! Anything below MTU 1400 is a bingo for me, the games just won’t load Yeah, we tested changing MTU for many years now but honestly it may be placebo for some. Never really helped me.
Jackal235 Posted November 4, 2022 Posted November 4, 2022 I changed my MTU to 750 on XR1000. To my surprise it run very well. Playing MW2 on PS5 (did not touch PS5 settings). I lowered it before (not as much though), I can definitely say it helps in my case.
TODDzillaInLA Posted November 4, 2022 Posted November 4, 2022 On 11/2/2022 at 6:45 PM, xx._iq_.xx said: Which are you setting the MTU at 750? The router or the PC/gaming console? duma
xx._iq_.xx Posted November 4, 2022 Posted November 4, 2022 7 minutes ago, TODDzillaInLA said: duma Copy that.
TODDzillaInLA Posted November 4, 2022 Posted November 4, 2022 https://cod.tracker.gg/warzone/profile/xbl/TODDzillaInLA/matches
K0NSPIRACY Posted November 4, 2022 Posted November 4, 2022 What does lowering MTU to 750 do in gaming? and will it affect other devices connected in the house when not gaming?
kinel Posted November 4, 2022 Posted November 4, 2022 On 11/3/2022 at 1:45 AM, xx._iq_.xx said: Which are you setting the MTU at 750? The router or the PC/gaming console? Why 750 Ive never heard any onr e recomend 750 before The lowets i ever tried in the past was 1320 around This was a few years ago From my experience with trying diffrent mtu values It only seems to work correctly if you do it on one ot the devices when i tried a few years ago I will be testing this out later today on ps5 IF ANYBODYS INTRESTED TRY THIS I just discover some new ports that cod mw2 are using And it using alot of data from my testing it actualky looks like its the main port from my testing It using 5 in these ranges so far inbetween these ranges0000 to 65000 destination 80 to 80 tcp Ive set my rule up like this so fsar this how i would set it up Rule 1Source 1 to 65535 detination 80 to 80 tcp only rule 2 ource 3074 to 3074 destination 35000 to 50000 udp only These are the ports that are the mainly used i m shocked the game is now using tcp 80
Alex49H Posted November 4, 2022 Posted November 4, 2022 3 hours ago, kinel said: Why 750 Ive never heard any onr e recomend 750 before The lowets i ever tried in the past was 1320 around This was a few years ago From my experience with trying diffrent mtu values It only seems to work correctly if you do it on one ot the devices when i tried a few years ago I will be testing this out later today on ps5 IF ANYBODYS INTRESTED TRY THIS I just discover some new ports that cod mw2 are using And it using alot of data from my testing it actualky looks like its the main port from my testing It using 5 in these ranges so far inbetween these ranges0000 to 65000 destination 80 to 80 tcp Ive set my rule up like this so fsar this how i would set it up Rule 1Source 1 to 65535 detination 80 to 80 tcp only rule 2 ource 3074 to 3074 destination 35000 to 50000 udp only These are the ports that are the mainly used i m shocked the game is now using tcp 80 Xbox or PS4?
N3CR0 Posted November 4, 2022 Posted November 4, 2022 On 11/3/2022 at 8:53 PM, Alex49H said: Yeah, we tested changing MTU for many years now but honestly it may be placebo for some. Never really helped me. I tried a few different values back on IW and MW19 and only found that messing with that made the game so much worse.
NetZilla Posted November 5, 2022 Posted November 5, 2022 12 hours ago, kinel said: Why 750 Ive never heard any onr e recomend 750 before The lowets i ever tried in the past was 1320 around This was a few years ago From my experience with trying diffrent mtu values It only seems to work correctly if you do it on one ot the devices when i tried a few years ago I will be testing this out later today on ps5 IF ANYBODYS INTRESTED TRY THIS I just discover some new ports that cod mw2 are using And it using alot of data from my testing it actualky looks like its the main port from my testing It using 5 in these ranges so far inbetween these ranges0000 to 65000 destination 80 to 80 tcp Ive set my rule up like this so fsar this how i would set it up Rule 1Source 1 to 65535 detination 80 to 80 tcp only rule 2 ource 3074 to 3074 destination 35000 to 50000 udp only These are the ports that are the mainly used i m shocked the game is now using tcp 80 Where did you input those rules for sources? In the port forwarding? Im willing to try it out and see.
Alex49H Posted November 5, 2022 Posted November 5, 2022 4 hours ago, N3CR0 said: I tried a few different values back on IW and MW19 and only found that messing with that made the game so much worse. Yeah it has a placebo effect. Maybe a game or two it plays ok but the rest were bad and connection was worse.
TODDzillaInLA Posted November 5, 2022 Posted November 5, 2022 My settings is what works best for me they might not work best for you you need to try them then play with the values to you dial in your connection for your setup, MTU at 750 helps me get a better connection to the game im on a 1gb connection here are all my settings My settings are also dedicated to the game and give a bad internet experience to other devices why i have spectrum and frontier, one internet for just my gaming and the other provider for the whole family when i play multiplayer i change my sliders to 20mb down and 5mb up when i play warzone i set it to 70% and 70% I have Wi-Fi completely turned off and i have upnp off
kinel Posted November 5, 2022 Posted November 5, 2022 22 hours ago, Alex49H said: Xbox or PS4? Ps4 and ps5 13 hours ago, NetZilla said: Where did you input those rules for sources? In the port forwarding? Im willing to try it out and see. In traffic priotization its on the qos conestion control screen
alex.devine Posted November 6, 2022 Posted November 6, 2022 On 11/1/2022 at 10:30 AM, johnnytran said: Exactly my experience. No matter what I've changed in the router settings I can't seem to get fluid gameplay/good hit reg. Above 3kd in most cods but I'm almost always last in this, I'm lucky to get a kill if I shoot someone from behind it's that bad. It really sucks cause the R2 gave me great connection in MW19.. I feel like there's some dodgy shit going on with the connection in MW22 just have to wait it out until they tweak something that works for your connection Try this... I am from the UK! Set your geo filter over Italy, use the poly selection to select around italy and ping assist to 0. I get a ping of 50ish and the game plays perfect, you will get some games that you cant explain WTF just happened moment, but that is just COD. (it will take a little longer to find games).
l2eactionz Posted November 6, 2022 Posted November 6, 2022 On 11/1/2022 at 9:06 AM, alex.devine said: I have been testing ping, I have played a lot of games lately with a ping of 20-35 and I get the same issues. Now if I set my Geo filter away from my location and get a ping of 50, the games play perfect and very fair + ALL games are very close and even. Dont know why, it just plays perfect and I will keep it like that. I've made a post about this a while back glad someone else has the same experience
l2eactionz Posted November 6, 2022 Posted November 6, 2022 On 11/4/2022 at 2:07 PM, kinel said: Why 750 Ive never heard any onr e recomend 750 before The lowets i ever tried in the past was 1320 around This was a few years ago From my experience with trying diffrent mtu values It only seems to work correctly if you do it on one ot the devices when i tried a few years ago I will be testing this out later today on ps5 IF ANYBODYS INTRESTED TRY THIS I just discover some new ports that cod mw2 are using And it using alot of data from my testing it actualky looks like its the main port from my testing It using 5 in these ranges so far inbetween these ranges0000 to 65000 destination 80 to 80 tcp Ive set my rule up like this so fsar this how i would set it up Rule 1Source 1 to 65535 detination 80 to 80 tcp only rule 2 ource 3074 to 3074 destination 35000 to 50000 udp only These are the ports that are the mainly used i m shocked the game is now using tcp 80 This could effect your bandwidth control by the way. If you are not using qos then it's fine but prior port 80 will bypass any qos for that device.
philo3391 Posted November 7, 2022 Posted November 7, 2022 21 hours ago, alex.devine said: Try this... I am from the UK! Set your geo filter over Italy, use the poly selection to select around italy and ping assist to 0. I get a ping of 50ish and the game plays perfect, you will get some games that you cant explain WTF just happened moment, but that is just COD. (it will take a little longer to find games). what other settings have you changed ? do you have traffic prio rules ? upnp/dmz etc ? do you use vpn or just geo filter over italy ? thanks
alex.devine Posted November 7, 2022 Posted November 7, 2022 1 hour ago, philo3391 said: what other settings have you changed ? do you have traffic prio rules ? upnp/dmz etc ? do you use vpn or just geo filter over italy ? thanks QOS - 70% on each slider, and Congestion always on. Traffic Prio - I have switched off the Classified Games and added my console only. Turn off Cross play, I am on the PS5. I dont mess around with ports, I personally think it is a waste of time. Using a VPN from Express, location is Germany Nuremberg. The minute my ping goes back to the normal 30ish I am lucky to get 5-10 kills, I do this method and I have in the range of 35-50 kills per game and maybe 1-2 poor games for the evening. I get shoot first and kill first, its amazing I think what is happening, I am closing down the player range to a small amount. Happy to help and answer anything else, fire away and I will do my best to help. I know how frustrating this can be.
philo3391 Posted November 7, 2022 Posted November 7, 2022 31 minutes ago, alex.devine said: QOS - 70% on each slider, and Congestion always on. Traffic Prio - I have switched off the Classified Games and added my console only. Turn off Cross play, I am on the PS5. I dont mess around with ports, I personally think it is a waste of time. Using a VPN from Express, location is Germany Nuremberg. The minute my ping goes back to the normal 30ish I am lucky to get 5-10 kills, I do this method and I have in the range of 35-50 kills per game and maybe 1-2 poor games for the evening. I get shoot first and kill first, its amazing I think what is happening, I am closing down the player range to a small amount. Happy to help and answer anything else, fire away and I will do my best to help. I know how frustrating this can be. Hi Alex , thank you for the response, i am also on ps5 . do you use dmz or upnp? and thanks everyday is a school day so do you vpn the whole ps5 then rather than specific ports to get the higher 'lag' if you like. appreciate the help
alex.devine Posted November 7, 2022 Posted November 7, 2022 2 minutes ago, philo3391 said: Hi Alex , thank you for the response, i am also on ps5 . do you use dmz or upnp? and thanks everyday is a school day so do you vpn the whole ps5 then rather than specific ports to get the higher 'lag' if you like. appreciate the help No Problem at all No DMZ and UPNP is on. Happy to have a chat with you this evening to help duplicate my setup, step by step if you want? I think you did say you are from the UK? I am in the UK as well!
