DanyKTM Posted February 10, 2020 Share Posted February 10, 2020 On 2/7/2020 at 7:20 AM, Cussiv said: Yes, your settings rule in hardcore. I have some gameplays on my channels using your settings + bandwith monitor disabled. I also noticed these settings works better on older piece of hardware. WNDR3700v1 and WNR2200. I feelt more instamelted on hardware like wrt1900acsv2 and tp link c7 v5. https://www.youtube.com/watch?v=E8D-VFZUklQ&t=2s https://www.youtube.com/watch?v=oDCO4dYqAIM do you think I can install gargoyle for my R7000 ? Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 10, 2020 Share Posted February 10, 2020 50 minutes ago, DanyKTM said: do you think I can install gargoyle for my R7000 ? gargoyle is not supported by broadcom routers. If you have an old one maybe you can flash it. Link to comment Share on other sites More sharing options...
DanyKTM Posted February 10, 2020 Share Posted February 10, 2020 1 hour ago, Cussiv said: gargoyle is not supported by broadcom routers. If you have an old one maybe you can flash it. sorry, what you means by broadcom routers ? is it my ISP router ? Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 10, 2020 Share Posted February 10, 2020 23 minutes ago, DanyKTM said: sorry, what you means by broadcom routers ? is it my ISP router ? It's the chipset or processor. It's not compatible with the software. No its your R7000 router. You can check what routers are compatible here: https://www.gargoyle-router.com/download.php Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 10, 2020 Share Posted February 10, 2020 Had some sick gameplays eariler Link to comment Share on other sites More sharing options...
N3CR0 Posted February 10, 2020 Share Posted February 10, 2020 5 hours ago, WalkedDave said: You use the basic SQM with cake and piece-of-cake. At this momemt i use gargoyle qos plus DSCP tags.. But i will install openwrt on my wrt3200acm again and use this https://forum.openwrt.org/t/ultimate-sqm-settings-layer-cake-dscp-marks/25832 Would love to give that a go but thats so over my head its in space lol. Link to comment Share on other sites More sharing options...
Krush Posted February 10, 2020 Share Posted February 10, 2020 I have a Dlink dir 869 on hand and unfortunately gargoyle is not compatible ... Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 10, 2020 Share Posted February 10, 2020 If you cant use gargoyle try to find a stable build with dd-wrt. Sfq + hfsc is a good combo. https://gist.github.com/eqhmcow/939373 Link to comment Share on other sites More sharing options...
Zippy Posted February 13, 2020 Share Posted February 13, 2020 On 11/29/2019 at 11:32 AM, Cussiv said: Hello, I have tried many routers and I would say its the router + firmware. I have tried many routers and firmwares and have some recommendations if you want to feel less insta melted. r7000 with merlin vortex or advanced tomato asus rt-ac68u with merlin + fresh jr script moD gargoyle works great, tried it on 2 diffrent routers, tp link archer c7 v5 performed better then wrt1900acsv2 I have tried ddwrt and openwrt its not great for cod I would not recommend it. I have my netduma r1 it works great on the older cods that use p2p host/ Not true dedicated. As longest if the p2p have around 20-40 it feels great. Interesting you had fresh scripts added on your asus.. Good stuff right there! He was working on IPv6 QoS. Havent seen him in awhile on the forums though.. Zippy.. Link to comment Share on other sites More sharing options...
DanyKTM Posted February 13, 2020 Share Posted February 13, 2020 i'm looking to flash my R7000, do you suggest to use advanced tomato, open WRT or DD-Wrt ? Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 13, 2020 Share Posted February 13, 2020 10 hours ago, DanyKTM said: i'm looking to flash my R7000, do you suggest to use advanced tomato, open WRT or DD-Wrt ? Try freshtomato or ddwrt. I had better experience using dd-wrt with kong 35550m Link to comment Share on other sites More sharing options...
Guest Cussiv Posted February 20, 2020 Share Posted February 20, 2020 DD-wrt Link to comment Share on other sites More sharing options...
N3CR0 Posted March 27, 2020 Share Posted March 27, 2020 Since my R1 is on its last legs, gonna look into getting an Asus RT AC86U with Merlin and see how it goes. Link to comment Share on other sites More sharing options...
DanyKTM Posted March 28, 2020 Share Posted March 28, 2020 seem to be a good one, 200 $ not to bad Link to comment Share on other sites More sharing options...
sncjez Posted March 28, 2020 Share Posted March 28, 2020 15 hours ago, N3CR0 said: Since my R1 is on its last legs, gonna look into getting an Asus RT AC86U with Merlin and see how it goes. I use that router and merlin if you do go that route check out the freshjr. https://www.snbforums.com/threads/release-freshjr-adaptive-qos-improvements-custom-rules-and-inner-workings.36836/ Link to comment Share on other sites More sharing options...
N3CR0 Posted March 28, 2020 Share Posted March 28, 2020 2 hours ago, sncjez said: I use that router and merlin if you do go that route check out the freshjr. https://www.snbforums.com/threads/release-freshjr-adaptive-qos-improvements-custom-rules-and-inner-workings.36836/ Will do I was also looking at Linksys WRT32X and trying out DD-WRT but after doing abit of research, DD-WRT is no longer recommended over OpenWRT so won't bother going down that route. Link to comment Share on other sites More sharing options...
MySettingzSucks Posted March 30, 2020 Share Posted March 30, 2020 On 3/28/2020 at 1:55 PM, N3CR0 said: Will do I was also looking at Linksys WRT32X and trying out DD-WRT but after doing abit of research, DD-WRT is no longer recommended over OpenWRT so won't bother going down that route. Why not dd-wrt? Is it because OpenWRT has lower latency? Well I don’t know. Tried playing with OpenWRT and my stock performed better when it come to hit detection. and the WRT32X.. Why spend lot of money on routers on a broken game? It’s better to try cheap netgears. Link to comment Share on other sites More sharing options...
N3CR0 Posted March 30, 2020 Share Posted March 30, 2020 8 hours ago, MySettingzSucks said: Why not dd-wrt? Is it because OpenWRT has lower latency? Well I don’t know. Tried playing with OpenWRT and my stock performed better when it come to hit detection. and the WRT32X.. Why spend lot of money on routers on a broken game? It’s better to try cheap netgears. Not really sure but everywhere I looked where folk were asking which to go for, everyone said OpenWRT and said that DD-WRT was great 10 years ago but just doesn't cut it anymore. I already have a OpenWRT router so didn't see the point. I get better hit reg on OpenWRT then I did on my Duma R1. I'm wanting a new router as my R1 is on its last legs and I wasn't impressed at all with the XR500 and don't fancy trying another Netgear router. Link to comment Share on other sites More sharing options...
MySettingzSucks Posted March 30, 2020 Share Posted March 30, 2020 3 hours ago, N3CR0 said: Not really sure but everywhere I looked where folk were asking which to go for, everyone said OpenWRT and said that DD-WRT was great 10 years ago but just doesn't cut it anymore. I already have a OpenWRT router so didn't see the point. I get better hit reg on OpenWRT then I did on my Duma R1. I'm wanting a new router as my R1 is on its last legs and I wasn't impressed at all with the XR500 and don't fancy trying another Netgear router. Alright if it works for you. Keep using it if its stable. You can always try dd-wrt if openwrt disappoint you. And about the Xr500, yes i agree it performed very bad, R1 performed better with the OG firmware. For some reason the new DUMAos performed bad even on R1. Might be something with the new firmware CoD dosn’t like with QoS and DumaOS. I woul’nt blame netgear, its really good with the orginal stock firmware. You could always try xr500 with dd-wrt. I saw a video the hit detection performed better with dd-wrt on xr500 then dumaos Link to comment Share on other sites More sharing options...
DUMA BOLTON Posted June 5, 2020 Share Posted June 5, 2020 On 2/9/2020 at 10:45 PM, Knomax said: Edgerouter X with Openwrt installed ...SQM with Cake...beast! Can you help me get openwrt on my edge router x please? Link to comment Share on other sites More sharing options...
Chaiyoabc Posted June 6, 2020 Share Posted June 6, 2020 On 2/14/2020 at 5:44 AM, Cussiv said: Try freshtomato or ddwrt. I had better experience using dd-wrt with kong 35550m Is it compatible with asus acrt88u router? Im currently have it combo with standard ddwrt with netduma dmz method Link to comment Share on other sites More sharing options...
vShikko Posted June 7, 2020 Share Posted June 7, 2020 On 2/10/2020 at 7:34 AM, WalkedDave said: You use the basic SQM with cake and piece-of-cake. At this momemt i use gargoyle qos plus DSCP tags.. But i will install openwrt on my wrt3200acm again and use this https://forum.openwrt.org/t/ultimate-sqm-settings-layer-cake-dscp-marks/25832 Cake is amazing, considering it's potential. If only more people would listen to Dave Taht, cough Netduma cough and his predecessors before his work on traffic shaping becomes a lost art. I still have my ERLite and if it weren't for it's limited CPU capabilities & my gig connection - I would still use it to this day. It had no problem pushing 600mb symmetrical using CAKE + SFE packet forwarding. If 3.0 is a total wash, I'll be converting back to the dark side, Ubiquiti. Link to comment Share on other sites More sharing options...
Knomax Posted June 7, 2020 Share Posted June 7, 2020 2 hours ago, vShikko said: Cake is amazing, considering it's potential. If only more people would listen to Dave Taht, cough Netduma cough and his predecessors before his work on traffic shaping becomes a lost art. I still have my ERLite and if it weren't for it's limited CPU capabilities & my gig connection - I would still use it to this day. It had no problem pushing 600mb symmetrical using CAKE + SFE packet forwarding. If 3.0 is a total wash, I'll be converting back to the dark side, Ubiquiti. For my connection DumaOS 2 creates to big bufferbloat..i check every % in sliders....with CAKE i dont have this problem..i also have autoSQM to change values in SQM every hour.So i am waiting DumaOS 3 to see how it works and how it handles packets...an interesting function is line benchmark...but it will be better if the results of this benchmark applied in QOS to have perfect line every time...many ISP's doesn't have stable bandwidth during day ...so to just do a speedtest..put the values in QOS is a permanent solution. And for the link with DSCP marks...if you use openwrt and netduma you dont want all this work.."veth inteface" and so on...just create another SQM interface....first SQM etc in pppoe-wan and put upload bandwidth only......another SQM interface in lan and put download speed in upload box.. You have SQM now both in download and upload direction. Link to comment Share on other sites More sharing options...
DanyKTM Posted June 7, 2020 Share Posted June 7, 2020 works in Warzone ? Link to comment Share on other sites More sharing options...
DanyKTM Posted June 7, 2020 Share Posted June 7, 2020 Why netdumaos could not be better than the RT-AX88U Link to comment Share on other sites More sharing options...
