Destiny 2 now using Steam Network Sockets
Nuyorrican
  • Replies 342
Ok guardians... Just signed up... Im so clear with all the community. Netgear/Support/Seo/Ceo/ who ever - need to adress/change that. It can´t be a thing, that cheaters/programmers from silly website using the router thousand of levels higher then the company wich sells it.
Since the geofilter option is not working on pc, the question is - why would you even buy the XR500 for d2? Portforwarding is a thing every router can do.
Why does UpNp dont work with d2?
Wich setup to run for d2?
Hybrid vpn to host/server - normal connection p2p no vpn? Is a combination worth it?
Wich ports are really needed for d2? wich should be open ore closed - the game is using so many different ports meanwhile...
If the companie is not able to handle such easy things - it is OK to say, we dont have that cracked people here on our side, we just can do, what we can do. It is also OK guys but do atleast something. Do gamepacks for port forwarding, ping reduction what the hell i know.
But if u cant offer a product wich is basecally not working since years its litterly time to change something.
Someone was talking about ping assist? what? how? in d2?
adding:
ore you can give us free qos settings, just update the list - sniff for pc wich ports is destiny 2 using and give us something.... there are so many easy steps for YOU guys, you could give us honey for our mouth... but nothing is coming..
how long would it take? to update the QoS section for actual games? Lets see destiny 2, they post all there ports wich they are using on their site. so copy and paste them, first data. play some crucible games, different modes. ask people who play d2 for a database if they have one?
Add new QoS rule for Destiny 2. GG
What do you mean by QOS settings? Port forwarding is easy to do.
With the Steam Porting thing. Does all of the Individual game data from each player come from 1 source from Steam? Or are there individual streams of data? If it's 1 source/stream of data for all players then we should be bugging Bungie or Steam. Does anyone know?
Steam datagram relay system. Anti ddos and ip protection service from Steam
Added to Xbox consoles in todays Destiny 2 patch, so now the dumaos is pointless for Xbox owners now too and still nothing about any work being done to give us some kind of functionality back!
Oh well
Oh well
I think some people got it to works, I just don't know how. Odd thing is I know the guy running it is doing it for ghost lobbies on xbox so I wonder what is happening that some cheater can somehow circumvent this but we can't.
Hi guys, just signed up, XR500 owner.
I want to report that I tried geofiltering destiny on some Xbox (Series X and One X), with no luck, and on one PS4 where it still works. So I guess that the people selling the ghost lobbies out there are just using cross saving to do the trick on a PlayStation.
It's game over for the white elephant.
40 minutes ago, Shoulin said:
Yes, You need to change you custom settings. It can be done via DumasOS in the Hybrid VPN. Best results are with extra vpn.
The more important question I would say is where is your brother located and where is he vpning to? Enabling some VPN on the router isn't any different than enabling it on a pc and im sure quite a few people have tried this.
2 hours ago, Shoulin said:
In what format would you like it?
I am sure many people here would be really grateful if you could provide some step by step of the process. Hell maybe even make it a youtube video and gain some subscribers in the process.
For example I assume he is setting a Hybrid VPN to target both consoles, but what else?
I tested hybrid vpn. Two xboxes on the same vpn using geo filters. It didn't seem to work.. any corrections welcome
Have you tried fiddling with any of these settings?
28 minutes ago, Dumaguy1 said:
Will this allow you to only get players with a certaing ping setting? Or is that some stupid way of only getting a win trading team in your region so you can be a loser and cheat?
I’m not sure it means your either, but it allows you find any additional consoles you have on the same network.
removed at users request
Wait are ghost lobbies working now
Guest
