Lag compensation fix on PS4 Pro
V3ndeTTo
Hello
Do you know some tips on how to fix the problem with lag compensation?
  • Replies 57
Hello, I have tried many routers and I would say its the router + firmware. I have tried many routers and firmwares and have some recommendations if you want to feel less insta melted.
r7000 with merlin vortex or advanced tomato
asus rt-ac68u with merlin + fresh jr script moD
gargoyle works great, tried it on 2 diffrent routers, tp link archer c7 v5 performed better then wrt1900acsv2
I have tried ddwrt and openwrt its not great for cod I would not recommend it. I have my netduma r1 it works great on the older cods that use p2p host/ Not true dedicated. As longest if the p2p have around 20-40 it feels great.
Yesterday you posted me a link to tp link wr841n open wrt  firmware
but my router cant get open wrt lede fw
It sounds like you know a bit about this stuff
What firmware would you recomend i try to install for my tp link wr841n  out of the ones you posted above
i only want it for cod mw
I am clueless regaring this stuff
I dont own that model and im not sure how it works, maybe a youtube video will help. I checked around and its not It supported by gargoyle. I would not recommend openwrt or ddwrt. Do you have another router ?
Dosn’t look like its supported. A little update: I tried advanced tomato on my asus rt-ac68u and I feelt I was a step ahead all the time. I also noticed the killcam sems legit. Here’s a short video.
Ya'll are forgetting one of the best routers out there..the edge router X and its other family of components. Its going to be my next investment tbh. I honestly only ever found the netduma to help on like AW, or bo3, other than that its purely your end (ISP, router, modem)
If you want to run QoS / SQM then you would want to look into the Edgerouter 4 or higher. 4 doesn't have a switching chip, the 6 and up have I thought. ER-X doesn't really have enough CPU power for high bandwidth connections.
I looked at this to run in tandem with my R1 but to be honest I think it's all pissing in the wind. Connect to the closest server and there is not much else you can do. Unless you really need to utilize QoS etc.
I have tried the edge router x, It was good in reducing bufferbloat but I feelt kinda insta melted. I didnt have good experience when i played bo4, the problem is SQM dosnt know how to priotize the gaming packets. And about the r1 it helps when its p2p host and if its the ping is 30-ish its feels great
well again, my ping is like 25ms and it doesnt feel great to be insta killed every second lol. Add all the chaos and bad maps in the mix and its just a cancerous experience.
Cussiv in your opinion the best 3rd.party firmware for playing games its gargole:
What are the most have parametrs on QOS and traffic PRIO
I might changed my mind. I love Advanced tomato, gargoyle comes second, then duma r1 Third because of the filter, its only good for old cod games that uses p2p dedicated.
in advanced tomato i havent even changed anything, just set my speed and im ready to go. (Tested on asus rt-ac68u and r7000)
for gargoyle:
https://www.gargoyle-router.com/phpbb/viewtopic.php?t=11739
bullet connects great in all cods and even hardcore expect bo4 in core for some strange reason but hardcore works great there. wndr3700 performed better then wrt1900acsv2 and tp link c7 v5 with gargoyle
Netduma: its comes third because of the filter.
xr500, Ddwrt and openwrt comes last.
Openwrt with SQM (cake or fq_codel) dosn’t know how to priotize packets and it dosnt feel great when you gaming. (Tried it on wndr3700, wrt1900acsv2 and tp link c7 v5)
Ddwrt qos lacks categorization and it dosn’t perform well in my option. (Tried it on wndr3700, wrt1900acsv2 and tp link c7 v5)
Xr500: bullet connected bad and never worked great in my experience. Tried on on cable and fiber and feelt insta melted. Something weird with the firmware. Saw a video a guy posted a video ddwrt vs xr500 and bullets seems to connect better with ddwrt.
  • 1 month later...
for gargoyle:
I use OPENWT with cake-layer of cake.
And to priotize packets  i use custom firewall rules, to use ip-tables to set dscp
Almost all of the gameplays on my YT channel were got while using OpenWRT Cake / Layer Cake. On BOps4 I found that much better than using the Duma's CC sliders.
I never prioritised packets, didn't need to.
You just use duma geo-filter
Nope. Geo filter didn't work very well for me alot of the time on BOps4. 99% of the time the game would connect me to the nearest server anyways.
7 minutes ago, WalkedDave said:
But your setup isnt openwrt --- duma-- ps4
Sometimes, sometimes not. Sometimes I'm only using the Duma and others I'm only using OpenWRT.
Occasionally I use both at the same time, just trying out stuff.
stupid question, do you put your consol in bridge mode in XR500 ?? I,ve touch this option
You can only put your console in the DMZ of the XR500, you can't bridge it.
I think that you can actually with a XR500, under settings / advanced / VLAN/Bridge settings.
As far as I see it allows you to create a bridged port.
The caveat however is that you would need to have access to multiple public IP addresses. That makes this function kind of useless as when in bridged mode you won't be benefiting from any of the QoS aspects of the router. So you might as well hook up a switch before your router and plug into that.
I don't think R1 DumaOS lets you do this but there is some times where this would be attractive. Say you have a home router. You place your R1 at the desk with your PC, laptop, PS4 etc. You can let your PC and PS4 make use of the R1's geofiltering capacity while the laptop that isn't used for games could use a bridged pass through port and connect straight to your main router, giving it a speed advantage since the R1 is limited when operating in a Gigabit environment. Without a bridged mode you would need a switch to connect the laptop and R1 separately.
Bridging is only useful for akward setups. Most home networks follow the star topology with the router in the center so most of the time this is of no use.
for gargoyle:
You use my post in Gargoyle forum...😃
  • 3 weeks later...
Yes, your settings rule in hardcore. I have some gameplays on my channels using your settings + bandwith monitor disabled. I also noticed these settings works better on older piece of hardware. WNDR3700v1 and WNR2200. I feelt more instamelted on hardware like wrt1900acsv2 and tp link c7 v5.
https://www.youtube.com/watch?v=E8D-VFZUklQ&t=2s
https://www.youtube.com/watch?v=oDCO4dYqAIM
Edgerouter X with Openwrt installed ...SQM with Cake...beast!
