Gamer_93 Posted September 13, 2021 Author Posted September 13, 2021 when i am loading up the game this is the heat map i get from the geo filter
Administrators Netduma Fraser Posted September 13, 2021 Administrators Posted September 13, 2021 Did you not get that before? If so that is what is supposed to happen so that server definitely should have been whitelisted, should be faster to get a game now, let us know!
Gamer_93 Posted September 13, 2021 Author Posted September 13, 2021 nope still slow, still waiting 10 minutes, i always get this heat map whenever i load up the game but i never get a ping lower than 40, and that is VERY RARE THAT I GET 40, i keep getting 100 ping games!!!!!! even though oi live in san francisco and live right next to a server, come on guys
Administrators Netduma Fraser Posted September 13, 2021 Administrators Posted September 13, 2021 How slow is it without the Geo-Filter enabled to get a game?
Gamer_93 Posted September 13, 2021 Author Posted September 13, 2021 its relatively quicker but i get higher ping games which was the only reason i bought this router was to have lower ping matches!!!
Netduma Liam Posted September 14, 2021 Posted September 14, 2021 11 hours ago, Gamer_93 said: its relatively quicker but i get higher ping games which was the only reason i bought this router was to have lower ping matches!!! Does the ping also show as being super high in Geo-filter or is it closer to what you see in Ping Heatmap? Out of interest, do you have an Open NAT type in-game? Do you have a VPN enabled in Hybrid VPN?
Gamer_93 Posted September 14, 2021 Author Posted September 14, 2021 hi it takes about a minute to get into a game without the geo filter on, literally I'm not exaggerating 1 WHOLE EFFING MINUTE!!!!?? and the ping goes all the way past <90ms ping, I'm seriously taking this router back and i don't pay attention to the ping when i get into a game because i check the call of duty settings and it tells me my ping in the game (latency) and its always 80-100 ping when i live RIGHT NEXT TO THE EFFING SERVER YES I HAVE OPEN NAT NO I DONT HAVE HYBRID VPN INSTALLED
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 THIS IS WHERE THE SEARCH IS TAKING ME OUTSIDE MY RADIUS WHAT IS GOING ON??
Netduma Liam Posted September 15, 2021 Posted September 15, 2021 OK, next time you play could you please check what it shows for ping in Geo-filter as this will tell us what the router is seeing to the game server. The server you're seeing in your screenshot is whitelisted. It's either been whitelisted by yourself or has been whitelisted by us if it's an authentication server, in which case it won't affect your game at all.
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 OK SO WHEN I AM ON THE GEOFILTER, THE SERVER I AM NEXT TO, IN US WEST! IS 15-17ms ping, however it never puts me into a match when the Png chart shows, it just keeps loading and looking for a match
Administrators Netduma Fraser Posted September 15, 2021 Administrators Posted September 15, 2021 When the game is searching for a match and the ping range is increasing look at the Geo-Filter with it completely zoomed out, are you seeing anything being blocked? Have you got any entries on Allow/Deny other than the one I mentioned to allow?
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 NOW I CANT EVEN LOAD UP THE GAME, ITS STUCK ON CONNECTING TO XBOX LIVE, WHAT IS GOING ON AND YES I HAVE A LOT OF DENIES ON THERE BECAUSE ALL OF THE SERVERS ARE EAST COAST!!!!! I WANT TO PLAY ON WEST COAST!!!!!!!!!!!!!!!!
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 THIS IS WHAT SHOWS WHEN IM CONNECTING TO THE XBOX LIVER SERVERS AT THE MENU SCREEN
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 THIS IS THE SERVER THATY SHOWS WHEN IM CONNECTING TO XBOX LIVE, THERE ARE 4 BOXES THAT SHOW THE PING BEING 16-19ms ping, however my game doesnt connect to xbox live, its been stuck on the"connecting to xbox live" screen for the past 5 minutes your product is garbage
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 WHY AM I GETTING A PING OF 15ms AND I CANT EVEN CONNECT TO XBOX LIVE, IM STUCK ON THE SCREEN THAT SAYS "CONNECTING TO XBOX LIVE" WHAT IS THIS GARBAGE PRODUCT!!!!!!1
Bert Posted September 15, 2021 Posted September 15, 2021 Clear your deny list. Set geofilter in the middle of the ocean with strict mode on, and set geofilter to 30-40.
Bert Posted September 15, 2021 Posted September 15, 2021 Because then it blocks all the servers, but allows everything below the ping assist limit you set. Ie you are letting it work purely on ping rather than fencing off a geographical area.
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 mmmm so what do i do? put it in middle of the ocean with ping assist set to 30-40?
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 what should the radius be when its in the middle of the ocean?
Bert Posted September 15, 2021 Posted September 15, 2021 Doesn't matter, as lang as it covers no servers.
Administrators Netduma Fraser Posted September 15, 2021 Administrators Posted September 15, 2021 It's quite possible you've denied a server that was required for online play or servers that were mislocated so the above is good advice, let us know how you get on.
Gamer_93 Posted September 15, 2021 Author Posted September 15, 2021 nope i have not denied ANYTHING!! i followed all your tips fraser and they were DUD HOWEVER BERT'S! tip of going into the middle of the ocean and just using ping assist seems to be gathering results, i will let you know further but THANK YOU SO MCUH @BERT!!!! between these 2 guys giving me the run around by asking me 21 questions, and getting f**k ALL results you just gave an answer that could work so thank you.
