Netduma Liam Posted April 21, 2021 Posted April 21, 2021 1 hour ago, iz_prof said: Hello @Netduma Admin, I acquired my netduma R2, 3 weeks ago. I have been following the posts about the geofilter in Destiny 2. I have a question and a question. The placement: Some people on the xbox, are managing to use the geofiler, did not want to talk about how. My question: Do you believe you launch an att this week? Sorry for English. Greetings BRasileira Welcome to the forum! We're hoping to release an update this week but it's very difficult to work around. We are making promising progress, but do not have the finished result just yet. We'll keep you posted!
Grarrg Posted April 28, 2021 Posted April 28, 2021 On 4/21/2021 at 9:10 AM, Netduma Liam said: Welcome to the forum! We're hoping to release an update this week but it's very difficult to work around. We are making promising progress, but do not have the finished result just yet. We'll keep you posted! Hi, Hi, I was just checking in to see if there were any updates Thank you
Administrators Netduma Fraser Posted April 28, 2021 Administrators Posted April 28, 2021 20 minutes ago, Grarrg said: Hi, Hi, I was just checking in to see if there were any updates Thank you Not yet but we are making progress, we'll be sure to let people now when we have something to share
iztrials Posted April 28, 2021 Posted April 28, 2021 5 minutes ago, Netduma Fraser said: Not yet but we are making progress, we'll be sure to let people now when we have something to share Does the update come out this week?
Administrators Netduma Fraser Posted April 28, 2021 Administrators Posted April 28, 2021 1 hour ago, iztrials said: Does the update come out this week? It's unlikely to be this week but we're doing our best to get it out as soon as possible
ghorman Posted April 28, 2021 Posted April 28, 2021 3 hours ago, iztrials said: Does the update come out this week? You trying to get some trial cheese?
Frank Posted April 29, 2021 Posted April 29, 2021 12 hours ago, Netduma Fraser said: Es poco probable que sea esta semana, pero estamos haciendo todo lo posible para publicarlo lo antes posible. With this update you will be able to use the geofilter in destiny 2
Mattyzcav24 Posted April 30, 2021 Posted April 30, 2021 19 hours ago, APE-SLIDE said: whoever needs help with the new method for matchmaking in destiny 2 msg me and ill help u and show u :))) edit: i can help u on psn only Help me out I’m on ps4 I have a xr500 and was running lobbies until this happened
Grarrg Posted May 5, 2021 Posted May 5, 2021 On 4/28/2021 at 5:11 PM, Netduma Fraser said: It's unlikely to be this week but we're doing our best to get it out as soon as possible Just doing a weekly check in to see if there has been any progress. Thank you.
iztrials Posted May 6, 2021 Posted May 6, 2021 @Netduma Admin Any placement of the update for destiny?
Administrators Netduma Fraser Posted May 6, 2021 Administrators Posted May 6, 2021 5 minutes ago, iztrials said: @Netduma Admin Any placement of the update for destiny? Nothing yet, we'll put one out as soon as we're confident it will allow you to at least filter servers
ghorman Posted May 6, 2021 Posted May 6, 2021 4 hours ago, Netduma Fraser said: Nothing yet, we'll put one out as soon as we're confident it will allow you to at least filter servers I know you guys are working hard but I think a lot of the people are asking for something you can't do anymore. Seems like they want to be able to filter off IPs and not servers. Please don't get me wrong; I'll take the server option too but I know it will not be like it was before.
Administrators Netduma Fraser Posted May 6, 2021 Administrators Posted May 6, 2021 1 hour ago, ghorman said: I know you guys are working hard but I think a lot of the people are asking for something you can't do anymore. Seems like they want to be able to filter off IPs and not servers. Please don't get me wrong; I'll take the server option too but I know it will not be like it was before. Yeah it's unlikely you'll be able to match solo/against friends
Oni Posted May 7, 2021 Posted May 7, 2021 Yes I could care less about solo/against friends, I just want to filter servers :) May I ask where you guys are doing tests on? Are you testing in comp, quickplay, or different game modes?
Netduma Liam Posted May 7, 2021 Posted May 7, 2021 We've pushed a cloud update that should hopefully mean you're able to filter by servers, just flush your cloud in Geo-filter and give it a go! We tested this on Crucible and Strikes pre-dominantly.
ghorman Posted May 7, 2021 Posted May 7, 2021 14 minutes ago, Netduma Liam said: We've pushed a cloud update that should hopefully mean you're able to filter by servers, just flush your cloud in Geo-filter and give it a go! We tested this on Crucible and Strikes pre-dominantly. Thank you for the update. Looking forward to it.
Dumaguy1 Posted May 7, 2021 Posted May 7, 2021 47 minutes ago, Netduma Liam said: We've pushed a cloud update that should hopefully mean you're able to filter by servers, just flush your cloud in Geo-filter and give it a go! We tested this on Crucible and Strikes pre-dominantly. So we just pick a geo filter region and it should only load players from that server area? How to you flush the cloud?
Netduma Liam Posted May 7, 2021 Posted May 7, 2021 49 minutes ago, Dumaguy1 said: So we just pick a geo filter region and it should only load players from that server area? How to you flush the cloud? You should now be able to choose which server you connect to, though DumaOS has no control over with other players also connect to that server.
Administrators Netduma Fraser Posted May 7, 2021 Administrators Posted May 7, 2021 Click the icon on the Geo-Filter Map and click resync cloud
Administrators Netduma Fraser Posted May 7, 2021 Administrators Posted May 7, 2021 36 minutes ago, ONEovFOUR said: Are they also changed in ping heat map? Many thanks. Should be the same on heatmap, showing most of the servers currently
Oni Posted May 7, 2021 Posted May 7, 2021 1 hour ago, Netduma Fraser said: Should be the same on heatmap, showing most of the servers currently If bungie ever adds more servers will they automatically be applied in geo-filtering?
Administrators Netduma Fraser Posted May 7, 2021 Administrators Posted May 7, 2021 19 minutes ago, Oni said: If bungie ever adds more servers will they automatically be applied in geo-filtering? Not automatically no but we will update it yes
OzQuant Posted May 8, 2021 Posted May 8, 2021 14 hours ago, Netduma Liam said: We've pushed a cloud update that should hopefully mean you're able to filter by servers, just flush your cloud in Geo-filter and give it a go! We tested this on Crucible and Strikes pre-dominantly. Mirabile dictu! How do I go about doing this on R1? I have the old firmware (v1.x), do I need to flash the new v2 firmware?
