Administrators Netduma Admin Posted December 5, 2018 Administrators Posted December 5, 2018 2 minutes ago, Dan said: Yes the original firmware. I do hope the cloud update comes to it. Original firmware beats DUMAOS for my purposes Could you try upgrading back to DumaOS now and try this please: Go to your Geo-Filter Open the Geo-Filter Map Options (click the three horizontal lines in the top left of the panel) Click 'Flush Cloud' Wait about 30 seconds - 1 minute for the Flush to complete. Don't worry if it takes longer than this, just be patient Once complete, make sure you're happy with your other Geo-Filter settings e.g. home location, radius, Ping Assist on the R1 etc. Now restart Black Ops 4 Now try and play some games and let us know if your experience changes. Thanks
Dan Posted December 5, 2018 Posted December 5, 2018 17 minutes ago, Netduma Admin said: Could you try upgrading back to DumaOS now and try this please: Go to your Geo-Filter Open the Geo-Filter Map Options (click the three horizontal lines in the top left of the panel) Click 'Flush Cloud' Wait about 30 seconds - 1 minute for the Flush to complete. Don't worry if it takes longer than this, just be patient Once complete, make sure you're happy with your other Geo-Filter settings e.g. home location, radius, Ping Assist on the R1 etc. Now restart Black Ops 4 Now try and play some games and let us know if your experience changes. Thanks Hi I need the original firmware. DUMAOS lacks upnp forwarding which I rely upon hence the need for a cloud update on the original R1
Administrators Netduma Admin Posted December 5, 2018 Administrators Posted December 5, 2018 Ok - just sit tight for 24 hours (at most) and the changes should propagate.
Chaiyoabc Posted December 27, 2018 Author Posted December 27, 2018 Sry for having been disappearing. I have been having great time with new dumaos’s cloud update. I don’t have much issue finding lobby. It connect me to SG about 95% of time I play. For the current setting I have been using was still 98/98. But here I have find more variables to get good connection, at least for me well my bandwidth is 100/40 I set my download bandwidth to 6% which is equal to 6mb and upload bandwidth to 4%. I also have ‘when high priority traffic detected’ ticked however this is kind of endless test because this method is not 100% guaranteed that you will have good time with no lag compensation issue. That’s why I have backup method. It also depends on weapon fire rate as well. Let’s call this the ‘method 1. When method 1 doesn’t work, I go to method 2. And if it doesn’t work, I go to method 3 and 4. Below are lists of method I found Method 1: 6% / 4% equal to 6mb download and 1.6mb upload. With ‘when high priority traffic deteced’ anti bufferbloat apply Method 2: 6% / 4%. With ‘never’ ticked. And yes, that would turn off bufferbloat completely with 6mb and 1.4 ul bandwidth. For some reason anti-bufferbloat make your hit slight delay to. This is obvious when you use very low rate of fire gun and it has delay hit that u have to lead your aim in order to register your hit. Method 3: Go back to 98%/98% bandwidth. Which equal to 98mb download and 39.2mb upload Method 4: 98/98 and turn off anti bufferbloat
Demi Posted December 27, 2018 Posted December 27, 2018 1 hour ago, Chaiyoabc said: Sry for having been disappearing. I have been having great time with new dumaos’s cloud update. I don’t have much issue finding lobby. It connect me to SG about 95% of time I play. For the current setting I have been using was still 98/98. But here I have find more variables to get good connection, at least for me well my bandwidth is 100/40 I set my download bandwidth to 6% which is equal to 6mb and upload bandwidth to 4%. I also have ‘when high priority traffic detected’ ticked however this is kind of endless test because this method is not 100% guaranteed that you will have good time with no lag compensation issue. That’s why I have backup method. It also depends on weapon fire rate as well. Let’s call this the ‘method 1. When method 1 doesn’t work, I go to method 2. And if it doesn’t work, I go to method 3 and 4. Below are lists of method I found Method 1: 6% / 4% equal to 6mb download and 1.6mb upload. With ‘when high priority traffic deteced’ anti bufferbloat apply Method 2: 6% / 4%. With ‘never’ ticked. And yes, that would turn off bufferbloat completely with 6mb and 1.4 ul bandwidth. For some reason anti-bufferbloat make your hit slight delay to. This is obvious when you use very low rate of fire gun and it has delay hit that u have to lead your aim in order to register your hit. Method 3: Go back to 98%/98% bandwidth. Which equal to 98mb download and 39.2mb upload Method 4: 98/98 and turn off anti bufferbloat will definitely try this right now
Administrators Netduma Fraser Posted December 27, 2018 Administrators Posted December 27, 2018 3 hours ago, Chaiyoabc said: Sry for having been disappearing. I have been having great time with new dumaos’s cloud update. I don’t have much issue finding lobby. It connect me to SG about 95% of time I play. For the current setting I have been using was still 98/98. But here I have find more variables to get good connection, at least for me well my bandwidth is 100/40 I set my download bandwidth to 6% which is equal to 6mb and upload bandwidth to 4%. I also have ‘when high priority traffic detected’ ticked however this is kind of endless test because this method is not 100% guaranteed that you will have good time with no lag compensation issue. That’s why I have backup method. It also depends on weapon fire rate as well. Let’s call this the ‘method 1. When method 1 doesn’t work, I go to method 2. And if it doesn’t work, I go to method 3 and 4. Below are lists of method I found Method 1: 6% / 4% equal to 6mb download and 1.6mb upload. With ‘when high priority traffic deteced’ anti bufferbloat apply Method 2: 6% / 4%. With ‘never’ ticked. And yes, that would turn off bufferbloat completely with 6mb and 1.4 ul bandwidth. For some reason anti-bufferbloat make your hit slight delay to. This is obvious when you use very low rate of fire gun and it has delay hit that u have to lead your aim in order to register your hit. Method 3: Go back to 98%/98% bandwidth. Which equal to 98mb download and 39.2mb upload Method 4: 98/98 and turn off anti bufferbloat Thanks for posting what works for you! Hopefully this will help others who aren't sure about their settings.
RL317 Posted December 27, 2018 Posted December 27, 2018 Lag compensation still doesn't have anything to do with bandwidth lol http://denkirson.proboards.com/thread/5972/networking-lag-compensation-hit-detection https://youtu.be/TWLyKkLD-7E
NoMoreMyFriend-S Posted December 27, 2018 Posted December 27, 2018 6 hours ago, Chaiyoabc said: Sry for having been disappearing. I have been having great time with new dumaos’s cloud update. I don’t have much issue finding lobby. It connect me to SG about 95% of time I play. For the current setting I have been using was still 98/98. But here I have find more variables to get good connection, at least for me well my bandwidth is 100/40 I set my download bandwidth to 6% which is equal to 6mb and upload bandwidth to 4%. I also have ‘when high priority traffic detected’ ticked however this is kind of endless test because this method is not 100% guaranteed that you will have good time with no lag compensation issue. That’s why I have backup method. It also depends on weapon fire rate as well. Let’s call this the ‘method 1. When method 1 doesn’t work, I go to method 2. And if it doesn’t work, I go to method 3 and 4. Below are lists of method I found Method 1: 6% / 4% equal to 6mb download and 1.6mb upload. With ‘when high priority traffic deteced’ anti bufferbloat apply Method 2: 6% / 4%. With ‘never’ ticked. And yes, that would turn off bufferbloat completely with 6mb and 1.4 ul bandwidth. For some reason anti-bufferbloat make your hit slight delay to. This is obvious when you use very low rate of fire gun and it has delay hit that u have to lead your aim in order to register your hit. Method 3: Go back to 98%/98% bandwidth. Which equal to 98mb download and 39.2mb upload Method 4: 98/98 and turn off anti bufferbloat somehow sounds random and too much work. if it doesn;t work at all then I restart BO4 and more often than not it works. your bandwidth sounds like you are sitting in BKK on AIS?
