R3M!X Posted November 26, 2015 Posted November 26, 2015 dai I feel your pain bro. This router sucks with Destiny in general. Ive had the R1 for some time now and Ive never really benefit from it on Destiny.
frustrated Posted November 27, 2015 Posted November 27, 2015 Having the same issues again as well..Randomly getting kicked.
Netduma Staff Netduma Crossy Posted November 28, 2015 Netduma Staff Posted November 28, 2015 Does the kicking still happen with the GeoFilter disabled?
dai.hop Posted November 28, 2015 Author Posted November 28, 2015 No Crossy - it doesn't. Geo Filtering is definitely the causing the errors.
Netduma Staff Netduma Crossy Posted November 28, 2015 Netduma Staff Posted November 28, 2015 No Crossy - it doesn't. Geo Filtering is definitely the causing the errors. Do any padlocks/triangles appear when you get kicked?
frustrated Posted November 29, 2015 Posted November 29, 2015 No never see and triangles padlocks,its just boom..kicked ..turn off geo filter all good.
Administrators Netduma Fraser Posted November 29, 2015 Administrators Posted November 29, 2015 PM me for some 1 on 1's on Destiny, I really want this Destiny issue to be resolved asap but I need IDs for a cloud update to do so. I can do this via 1 on 1s
Chiver2007 Posted November 30, 2015 Posted November 30, 2015 Hello all, just got the router today. Been playing around with it and when I use the distance search for a host it seems to work just fine, when I add in Ping Assist is when it all gets really messed up. Fraser -- I will PM you right now, let me know if you want to do a 1 on 1 and maybe together we can get this fixed.
Administrators Netduma Fraser Posted November 30, 2015 Administrators Posted November 30, 2015 Don't use ping assist for Destiny
Chiver2007 Posted November 30, 2015 Posted November 30, 2015 Don't use ping assist for Destiny Could I ask why? One of the prominent destiny PvP'ers right now (tripleWRECK) said with the latest update he has started using the ping assist and it is working for him.
frustrated Posted December 1, 2015 Posted December 1, 2015 Let us no whats the cure guys,as ive had to play with the duma turned off geo filter,as the getting kicked issue is to common.Im using ping assist ?Thought that was the go.
R3M!X Posted December 1, 2015 Posted December 1, 2015 My set-up goes: Geo:ON Strict mode:OFF Radius: 1000mi / 1615km Peer Ping: Checked I get kicked in a 4 hour gaming session at least once. Once I turn on Strict mode I increase the radius so that it covers all of USA and a bit of CA and Mexico. I'll get the ocasional boot but not as much as before and that was pretty much every other game.
frustrated Posted December 1, 2015 Posted December 1, 2015 Never use Strict mode on mine,but id get kicked at least twice in two hours,i did have ping assist on tho.But Frasier checked my settings and all was good so confused why we are all getting kicked latley.Not sure what the recent issue is to be honest.
Spartanogc Posted December 1, 2015 Posted December 1, 2015 2 times an hour is not bad compared to me, I might get to play 2 to 4 games in an hour. I keep getting booted over and over when flying into a game with the beaver error , its so difficult to find a game and not get booted during the game that I don't play Destiny that much anymore. I have tried every setup suggested but no luck
frustrated Posted December 1, 2015 Posted December 1, 2015 Sorry to hear that,really am its quite frustrating i can understand that, even im getting slightly mythed by it all,ive even now disconnected it,but i agree the duma does work as you can tell the difference in game play,but rather that than being disconnected all the time ...i also get "beaver".
R3M!X Posted December 1, 2015 Posted December 1, 2015 There are times when I feel like I wasted my money on this router. Basically purchased it for Destiny. I should have read through the forums first before making the jump. I only found out afterwards that Destiny in general was not a good match with this router after doing a search for "Destiny Settings" that even with the suggested settings, it wasn't that great at all. I still feel confident that they'll find a work around but I honestly feel that it's all in Destiny's shitty network coding.
Spartanogc Posted December 1, 2015 Posted December 1, 2015 I agree Remix and I have confidence in the Duma crew, when I do get in games lately the experience is good
Chiver2007 Posted December 1, 2015 Posted December 1, 2015 I've had good luck with using the geo filter with the distance. I have NOT been using the ping assist, just the distance and I haven't had any issues. I cannot wait until they add the feature in where you can click on the ping bar graphs and block them from that way. Will make it hell of a lot easier to block large people
frustrated Posted December 1, 2015 Posted December 1, 2015 Played Control,rift clash for two hours kicked twice "Beaver". No padlocks nothing range increased...turn geo on and off play again for another hour. Just a update.
Administrators Netduma Fraser Posted December 2, 2015 Administrators Posted December 2, 2015 I'm still attempting to gather IDs and do 1 on 1's to resolve this. I will also test the game myself to see if I can replicate it
frustrated Posted December 2, 2015 Posted December 2, 2015 Sent you a message Frasier,the thing is its quite intermitant..when you get kicked,it will happen just never no when..so odd always "beaver".Happy to do a 1-1.
dai.hop Posted December 2, 2015 Author Posted December 2, 2015 Fraser As per our Direct Message conversation - here are some ID's. They have been taken over the course of today and yesterday evenings. Outside filter range host ID's (yellow triangles) during matchmaking: ce546530f16dcdd2 4b5318e3f0eaf9fe 2e5cc792f9cd9499 6e0295609f0deef3 c45a521df7632025 8b5ea873fb2a5f64 335e6c37fbd2282d 0850814ceda7474c d33e4d18db72d6db 921fdea9bc318d92 595d28f3faf82126 682e804bcb070409 Outside filter range host ID's (yellow triangles) directly after kick (very rare): 67595924f6068186 ba5701ccf4590c11 Have you been able to replicate the problems yourself yet Fraser?
Redcheat Posted December 2, 2015 Posted December 2, 2015 After upgrading to the new version yesterday today has been a real hell playing destiny. Before the update using same settings the matchmaking was working way better. Tonight ive gotten so many errors trying to matchmake. Im located in sweden and i use these settings: Geo-filter: Peer ping: checked F. distance: 1200km P. assist: 30 and yes i have changed the playstation network service and refreshed etc. I am on a 250/100 fiber connection, finally able to enjoy full download speeds but this matchmaking problems are starting to become a headache. There are alot of connections outside the radius sneaking past all the time, before the patch it didnt use to be this many and didnt give any errors. You may take a look at the router if you want.
Chiver2007 Posted December 2, 2015 Posted December 2, 2015 After upgrading to the new version yesterday today has been a real hell playing destiny. Before the update using same settings the matchmaking was working way better. Tonight ive gotten so many errors trying to matchmake. Im located in sweden and i use these settings: Geo-filter: Peer ping: checked F. distance: 1200km P. assist: 30 and yes i have changed the playstation network service and refreshed etc. I am on a 250/100 fiber connection, finally able to enjoy full download speeds but this matchmaking problems are starting to become a headache. There are alot of connections outside the radius sneaking past all the time, before the patch it didnt use to be this many and didnt give any errors. You may take a look at the router if you want. I was told to NOT use the ping assist with destiny.
Administrators Netduma Fraser Posted December 2, 2015 Administrators Posted December 2, 2015 Great thank you dai! I will hopefully test it out tomorrow. Red ensure you have strict off and I would also turn PA to 0. If you're getting booted please do look for IDs like dai did so I can add them to the cloud.
