What setup do I need for Traffic Prioritization for CW on PS5??
Dyson350
If someone could literally spell it out for me what the start and end ports are for Source and Destination. I would appreicate it.
3 hours ago, Netduma Fraser said:
Would recommend source 1-65535 with the destinations being the ports/protocol from the above link.
So 4 separate ones?
Like this for example?
Source: start = 1 - 6553
End: Destination = 3478 - 3479
TCP
38 minutes ago, Dyson350 said:
So 4 separate ones?
Source: start = 1 - 65535
TCP
Yes exactly!
41 minutes ago, Netduma Fraser said:
If you enable DumaOS Classified Games or add it with the Games Console service does it prioritize correctly?
I will have to test tonight when I get home.
Does doing both cancel one out ?
If you did them both you'd basically be prioritizing twice which isn't needed - wouldn't cancel out but wouldn't be as effective.
For ps5 should I use classified games or add it manually as games console then ?
Classified Games should pick it up as all consoles are covered - if it doesn't then disable it and choose the Games Console service instead.
When I got home and checked they were no longer there. I have no idea why.
I have one issue with the traffic prioritization with my ps5. Before on the PS4 I had put game console PlayStation ani it worked. Now with the ps5 doesn’t work. I don’t have a red dot 🔴. The only way is to check the DumaOS classified games. Why this happen? I want to give priority only on my ps5 and no on the other consoles.
What do you mean exactly? Could you clarify please?
It should work the same way. The device you think the PS5 is, if you check the IP in the Device Manager does it match the IP on the PS5 network settings?
Hi Fraser, yes I already checked and is the same IP. Also I noticed that with the PS5 now my ping on the games is 120-130 ms and the day before with my PS4 I always played on 70-80ms.
The lines I added are were gone. I am pretty sure I didnt delete them either.
On what device/web browser did you add them?
Okay that's probably why they were removed then. Don't reboot by unplugging it, do so from the router interface and all settings will be retained.
Ok good to know, but the original issues still remains. They aren't working either way.
