Will r2 work with openreach bt modem ?
Max
  • Replies 174
Did it crash again? If you haven't then it's just saved the log from the previous time it happened. You can delete it for the moment.
51 minutes ago, Max said:
No it didn’t crash works fine just to let you know
Okay great thanks, just delete that then and carry on as normal
  • 1 month later...
Hi there quick question I just get connected with fibre do I have to change anything on r2  to fibre connection?
or do hard reset and start from beginning?
everything it’s working fine I only change the bandwidth 150 up and 30 down
what is your recommendation?
  • 2 weeks later...
I don’t have access to geofilter my devices are gone can’t add them again
You will need to re-connect the device to the router that was previously added to the Geo-Filter with the same name, device type and connection method and the error will go, otherwise you'll have to do a factory reset unfortunately
Won’t let me add when you click add nothing happened
and yes I restart r2 2 times
If you check Device manager, are you devices still named properly or are they showing as 'unnamed device'?
Hi guys I restart my r2 factory settings and when I’m changing download and upload I’m getting this message after standard reset to
can you advise
maybe my settings ?
Did you wait 2 minutes after the reboot/reset for it to load properly before trying to change settings?
Could you view the error message please and post it here?
I think I solved the problem
once you move sliders for more percentage on gaming and then reduced uploads and download you getting this error
I reduce gaming % and now I can move sliders for download and upload without error
sorry folks
No problem Fraser thanks for all support from Duma army 😎💪
