Netduma Host Filter no longer works for Destiny 2 since they have changed to using Steam Network Sockets (Steamworks)
Thank you for your answers. I hope this will be fixed as soon as possible.
  • 3 weeks later...
  • Replies 107
58 minutes ago, lunafaction said:
Hey guys, just checking in as it's been a while now
Has Alex had time to look into this yet?
With DumaOS announcements/testing recently he hasn't had a chance I don't think but he will do it asap.
12 minutes ago, lunafaction said:
Understood! Hope the launch goes well and everybody is doing okay over there!
Thank you, you too!
  • 4 weeks later...
Hey guys, been another month since the last message here so wanted to check in and see if there's been any update yet? Getting desperate now!
I hope this issue will be addressed as soon as possible
Thanks for checking in, I've asked Alex to test this as soon as he can, if he is too busy I'll think of another solution.
  • 2 weeks later...
keep seeing a trend of "i'll ask alex" and "I'll test again".   At the sake of sounding ungrateful, could we just get a straight up answer if this issue is actually being looked at or pushed to the side?
so can you not see who you are connecting to anymore on D2 PC via the Geo-Filter page?  When I'm playing the game, I don't see anyone nor the dedicated servers anymore
Sorry for the delay, I'll ask Alex to actually post here himself with an update.
I did see the server I was connected to using the PC.
I unchecked 'Duma Classified Games' on traffic prioritization and I was able to see people that I connected to like before
Hi all,
We haven't had time to get Destiny 2 PC working with Geo-Filter since it switched to Steamworks. I'm afraid it might take some time to get this done as we are also very busy with getting DumaOS 3.0 out.
I don't yet know whether Steamworks will be even be compatible with Geo-Filter, I read the official documentation and it looks as if the matchmaking takes place on Steam's network rather than locally, meaning that we might not have any control over it. We'll need to experiment, there may be some changes we can make to Geo-Filter to make it compatible.
I'll update you when we've made progress on this one. Sorry about the wait.
Thanks for the update Alex! One thing to note is that casual play with CS:GO works with the Geo-Filter apparently, and that is also using Steamworks so there is some hope that it can work with Destiny 2 PC.
It's completely understandable that DumaOS 3.0 is the priority but with it being 4 months now since the Geo-Filter stopped working it's a little frustrating to not know if and when it'll ever return. Is there any chance of an ETA? Perhaps a rough estimate on when DumaOS 3.0 is likely to be complete and some time can be spent on this?
After digging into it more, there is no way around it at the moment unfortunately. We will keep trying but it doesn't look possible right now.
Alright, I would suggest you update your list of games that the Geo-Filter is working for on your main page then as I purchased one under the assumption it would work on PC and it didn't. They're also moving the Steamworks stuff to console in the near future so it'll stop working there too.
  • 6 months later...
Hi,
Are there any updates/roadmaps that can be shared regarding re-enabling this functionality for Destiny 2 on PC?
Thanks
3 hours ago, Jambo said:
Hi,
Thanks
Nothing I can share unfortunately at the moment. Alex will be/is looking at the issue for a potential solution.
  • 3 weeks later...
Just wanted people to be aware here also, in case they're following this thread. Destiny 2 for console will be using Steam Datagram Relay (the same as PC) within the next 3 months, which will break geofiltering capabilities for consoles also. Please give this some priority, as I know many people bought DumaOS enabled products solely for this game. Thanks.
  • 1 month later...
Any updates on this please? Bungie announced that steamworks is coming to console very soon (next month or so).
We've overhauled our cloud system so this should help with it when it happens but it's still a complex issue to try and get around
Hi Fraser. Would this require upgrading to dumaOS 3.0 to take advantage of?
It's all backend systems, nothing on the router side. It will just allow us to more easily provide cloud updates and with higher accuracy
You can use the Geo and Ping assist yes, wouldn't usually suggest PA for Destiny but you can give it a try
