kinel Posted January 16, 2023 Author Share Posted January 16, 2023 1 hour ago, Mobel said: @kinelyes I know, but thats exactly what I dont want (dont want to prioritize chatparty) Only the Udp packets used for gaming I want to be prioritized. Thats why I dont use Games Console because it will prioritize chatparty traffic and some other stuff as well. Ah ok sorry i only read a bit of your post Ah sorry lol i thought you wanted to know what ports psn chat used sorry my bad Link to comment Share on other sites More sharing options...
Swgohlegend Posted January 17, 2023 Share Posted January 17, 2023 Open bar never worked well for me. High ping assist and Geo filter in my area works well for me. End of the day you need practice so you generate some decent games. Doesn’t help for me since I only have to play 4-8 hours a week 😕 Link to comment Share on other sites More sharing options...
satinghostrider Posted May 7, 2023 Share Posted May 7, 2023 Guys, I'm a little confused seeing some of the ports prioritised. I'm on PC and I would like to know if TCP/UDP should be set to 3074 Source or Destination Port. With the other set to 1-65535? Your help is most appreciated. Because some are using Source Port as 3074 and Destination Port as 1-65535. I'm on PC so I'm wondering if I have to set it to : TCP/UDP 3074 Source and Destination 1-65535 Or TCP/UDP 1-65535 Source and Destination 3074. I'm also aware some are running both rules. Im on PC so I'm curious which works best as I'm on 1000/1000 connection with local ping of 3ms for Singapore server. Thanks in advance Guys! Link to comment Share on other sites More sharing options...
