Gamer Posted May 15, 2019 Author Posted May 15, 2019 Ok i send you a Screenshot of Ping Assist do Not working. And I Download Pingplotter and After this i give you a Feedback. Ok i Download the pingplotter and i Test Pingplotter. And i send you a Screenshot of Ping Assist do Not working. I Test the Ping Assist and Ping Assist give you games with high quality and low Ping But mi Ping Assist do Not work Only on 1 Day it works well.
Administrators Netduma Fraser Posted May 15, 2019 Administrators Posted May 15, 2019 Could you post the screenshots in this topic please so other people can help if I’m not available and that way you get faster support. Once you post them here I can comment and other people can too if they want to.
Administrators Netduma Alex Posted May 16, 2019 Administrators Posted May 16, 2019 Your PingPlotter results look fine. Sometimes when Ping Assist is initially installed, something goes wrong and it doesn't work quite right. To fix this, we need to downgrade and then upgrade your firmware. DOWNGRADE to the previous firmware: https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32 Now UPGRADE to the current firmware: https://kb.netgear.com/000060464/XR500-Firmware-Version-2-3-2-40 Once that's done, try this: Set your home to the middle of the ocean Reduce your radius so it's tiny Put ping assist to your desired level (maybe 50?) Turn off Strict Mode Now see if your games improve!
Gamer Posted May 17, 2019 Author Posted May 17, 2019 Hello Alex i Downgraded the firmware and then i upgrade to the newest but nothing happens All is the same before and ping assist do not work I do all steps that you send me
Administrators Netduma Admin Posted May 18, 2019 Administrators Posted May 18, 2019 Could you take a screenshot of it not working please. Could you also take a screenshot of your settings in the Geo-Filter map? Thanks.
Gamer Posted May 19, 2019 Author Posted May 19, 2019 On the first day that i use ping assist it works well but now nothing happen. And sometimes it kicks me out of the lobby
Administrators Netduma Alex Posted May 20, 2019 Administrators Posted May 20, 2019 Try deleting your device from the Geo-Filter and adding it again.
Gamer Posted May 20, 2019 Author Posted May 20, 2019 yes i try this and then i do a couple of games but it is no better now
Administrators Netduma Fraser Posted May 21, 2019 Administrators Posted May 21, 2019 We are looking into Ping Assist not working for some people but meanwhile could you flush the cloud and see if that helps please.
Administrators Netduma Alex Posted May 22, 2019 Administrators Posted May 22, 2019 Ah that's a shame. We are aware of a few people having ping assist problems and we're doing tests to figure out what the problem is and why it's happening. Thanks for your patience!
Gamer Posted May 29, 2019 Author Posted May 29, 2019 After i down and upgraded i have a new Problem i cant choose a new device
Administrators Netduma Alex Posted May 29, 2019 Administrators Posted May 29, 2019 Rename the device that you are trying to add to the same name it had before you did the factory reset
Gamer Posted June 21, 2019 Author Posted June 21, 2019 Hello Alex do you have new Information about Ping Assist do Not working ?
Administrators Netduma Fraser Posted June 25, 2019 Administrators Posted June 25, 2019 Hi Domenik I've asked the team for an update on the issue.
Gamer Posted July 3, 2019 Author Posted July 3, 2019 Ok yes thats good. On the beginning i told to Alex that im sure that the Software needs a Update. Because the first Time that i used the Ping Assist it works well and 1 day later it does Not work. In this Time i See how good Ping Assist works. Providet Ping Assist works.
Administrators Netduma Fraser Posted July 5, 2019 Administrators Posted July 5, 2019 Keep us updated, best way is to make sure it works correctly is to completely turn off the console, verify Geo-Filter settings are correct, do a cloud flush and then refresh the page and boot up the console.
Gamer Posted July 19, 2019 Author Posted July 19, 2019 Hello Yes i try Exactly This what you say But nothing happens . Can you help me to fix another big Problem. Sometimes my Router Start again from their selve. And it kicks me out in the middle off my Game. Do you have new Information about a new Update ?
Administrators Netduma Fraser Posted July 23, 2019 Administrators Posted July 23, 2019 The router is restarting itself? The most common cause for that is overheating which is plausible given it is summer. Is it in an area where the vents are not covered and it's not on a surface such as carpet that could allow it to overheat?
Gamer Posted July 25, 2019 Author Posted July 25, 2019 No my router is on a flat surface and the ventilation is not covered or blocked. And the router is in the same place where my old router stand and my old router has never started by itself. Whether it was summer or not in our apartment, it is cool. And I Go to my Router und Test it is warm or Not but the Router has a normal tempreture.
Administrators Netduma Alex Posted July 25, 2019 Administrators Posted July 25, 2019 Are you doing anything specific when it restarts or is it totally random?
Gamer Posted July 27, 2019 Author Posted July 27, 2019 Hello Alex no its totaly random when it restart.
