s1rtoast Posted July 3, 2015 Posted July 3, 2015 I have 150mb up and down with verizon, currently im only getting around 60mb up and down wired on my pc. I have followed the basic slow speed instructions by turning off ipv6 and the other things but i still have slow speed
PharmDawgg Posted July 3, 2015 Posted July 3, 2015 Replicate these settings in the screen shots and do the internet diagnosis and let us know what you get: Just as a heads up the R! can currently only handle about 125mb download speeds but with the next update it will be able to handle 900mb download speeds Oh yeah make sure you enter actual download/and upload speeds under congestion control. And the latest firmware is 1.03.4. Make sure that is up to date as well.
s1rtoast Posted July 3, 2015 Author Posted July 3, 2015 i already did all those already and im getting 60 down and 60 up
PharmDawgg Posted July 3, 2015 Posted July 3, 2015 Yeah you should atleast be able to get 125mb download. And this has always been the case since you first connected it?
s1rtoast Posted July 3, 2015 Author Posted July 3, 2015 somewhat, i have gotten different speeds with it since i installed it. this speed slowness has been the case for 4 days now atleast
lukasz Posted July 3, 2015 Posted July 3, 2015 What about the silder in conjestion control as well as witch alogirtm you are using reactive or pre emptive Just a simple check do you have deep pAckeg processing diable in Sett-misc? And stuf like beeing sure that the cable is connected to peo port in Duma? And that cabela are all fastend? And what is your setup innterms of do you use modem only and. R1 as a primary router. Or msybe not and you still have some trothling rules on old router? And stuf
Netduma Staff Netduma Crossy Posted July 3, 2015 Netduma Staff Posted July 3, 2015 If you connect directly to the modem do you get the speeds that you expect? Can you also check that you have the reactive algorithm set in congestion control and that you have entered the speeds that you are expecting in the congestion control page.
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 As well as what everyone else has said make sure you reset the device prioritisation before doing a speed test.
s1rtoast Posted July 3, 2015 Author Posted July 3, 2015 I have it set to reactive. I made sure to put in my speeds 150 over 150. When I connect directly to my router I get 150mb over 150mb wired
Administrators Netduma Iain Posted July 3, 2015 Administrators Posted July 3, 2015 If you're getting 60/60 it sounds like IPv6 is still enabled. Please make sure to disable as specified in speed up guide. Cheers!
Administrators Netduma Iain Posted July 3, 2015 Administrators Posted July 3, 2015 if you follow the guide, restart the modem then restart the router then it should get 120mbit. If not it could be a cable issue. If you need 1 on 1 assistance Fraser can help you next week, he's at an event all weekend. Schedule a time with him please
s1rtoast Posted July 3, 2015 Author Posted July 3, 2015 How should inset up the time? Over Twitter? On the forum?
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 How should inset up the time? Over Twitter? On the forum? If you send me a PM on here we can schedule one
s1rtoast Posted July 3, 2015 Author Posted July 3, 2015 im not sure if my PM went through to u or not, can we dm over twitter, that would be so much easier for me
Administrators Netduma Fraser Posted July 6, 2015 Administrators Posted July 6, 2015 I've replied to your PM, was at an event over the weekend sorry for the late reply.
Dioni Rod. Posted July 6, 2015 Posted July 6, 2015 I also have Verizon fios 150/150...wasn't getting my correct up/down..why..because my laptop couldn't handle gigabyte..so I tried a different laptop..got my correct up/down..lol..
Administrators Netduma Fraser Posted July 6, 2015 Administrators Posted July 6, 2015 Ahhh thanks Dioni! Thats great to know!
major masingil Posted July 8, 2015 Posted July 8, 2015 New Duma user here. I have been running some speed tests and am seeing a restricted upload speed since implementing the duma. The reason I was even checking the speeds was my streaming tv started buffering in the middle of the program. This has never happened before the Duma. I followed the instruction seen in the forums ie: Share Excess, reset device prioritization before the speed test, preemptive congestion, had the upload and download caps set to 100%... I should be receiving 50 up/ 50 down from the ISP Verizon Fios (Fiber). I was running speed test a few days ago before introducing the Duma and was receiving higher than advertised bandwidth, in the vicinity of 58 down / 55 up, during the middle of the day. Tonight when the TV started buffering there was nothing else going on with the internet. I had device prioritization for the direct tv set at 15%...seemingly should have been fine to stream a show without buffering. I ran several speed tests. Before I reset the device prioritization I was only receiving half of my upload speed. After resetting everything to equal I was seeing the mid 40's for upload. Any suggestions or comments on why I would start to buffer with nothing else happening on the internet/router? In order to end on a good note: I was experimenting with congestion control today. The Mrs. was streaming tv downstairs, I was streaming on a tv upstairs, and played 3 excellent games of Titanfall XB1 with no noticeable lag issues. (70/70 with the cap slider) I was quite pleased. Before the duma, when just one TV was streaming a show I had serious lag issues even with the netgear router QoS on highest priority for the XB1.
Zennon Posted July 8, 2015 Posted July 8, 2015 Major masingil it is always best practice to start a new thread with isues you may have. Here is the info on how to get your speeds up Why is my speed lower
Administrators Netduma Fraser Posted July 8, 2015 Administrators Posted July 8, 2015 Hey Major, welcome to the forum! Following Zennon's link should fix the speed issue. Fantastic to see the congestion control works so well for you
