The best settings (IMO) for the 1.03.06 firmware: feedbacks and suggestions
Update: a new section has been added for network console manual configuration.
Nice write up Chive,easy to understand for anyone that gives it a read, which I would highly recommend... :D
I'm glad you like it.
Now, no one can say "i don't have any support for my configuration" or "that firmware is so buggyyyyyy...".
I hope it will save some time for DUMA Team.
Good stuff Chive, I hope it gets pinned to help others in the Tutorials section and support section at the top so when the click the sections. The Tutorial would be right there when someone click into the section.
Thanks for the support mate :)
It's already pinned on general support so we don't need to put it anywhere else.
I disagree with the port forwarding recommendation. Unless you have nat issues there is no need to use port forwarding especially with multi condoles. Then i would recommend port triggering but Upnp is working for me.....
That's why i've specified "in my opinion".
But like you said, it will not works with multi consoles.
I will had something on the thread about it.
Sounds good! I wonder why the duma does not have port triggering?
There is only one difference between port triggering and port forwarding: the first is like a switch on/off for ports and the other open ports once it for all.
You and your Port Triggering. Hehe. :P
haha, good memory my friend!!!
Still have that 4500 Sir?
Still have mine. Still works too. :D
Yeah still have it and still works. It is in my desk drawer collecting dust.
2 questions
1, do i havr to untick upnp in thr misc section aswell ?
2, i tried to untick upnp but was still getting moderate nat on black ops 3 and was getting strict on rainbow six.wh
en i turned upnp back on i was getting open on rainbow six again
please help thanks
2 questions
please help thanks
You have 2 ways to open your nat: upnp or port forwarding.
You can use only one of them so if you use port forwarding, you need to disable upnp.
  • 1 month later...
when i do the ports the netduma runs very slow. is that a glitch with the software?
Make sure you're using Google Chrome/Default theme in miscellaneous settings. If you still encounter it follow http://forum.netduma.com/topic/19266-slow-gui-interface-the-solution-is-here/
stealth mode do you have some more useful information? i cant see anything on the forums. is it ment for gaming?
http://support.netduma.com/support/solutions/articles/16000028079-what-do-the-miscellaneous-settings-do-
