Help please
  • Replies 100
Let it go for at least a day to see what it shows at all times of the day... I typically go with Michigan as it's the most accurate and stable. Kansas is actually Virginia, but it goes a little wild at times.
Overall I'd say that's a typical cable connection
i always do 8.8.8.8 and 8.8.4.4, since dns servers respond much more reliably
Eh.. I've had pretty bad luck with google dns dropping alot of packets on their end
Its a good cable line I think, I have seen some atrocious plots in the past and yours fine for the type of broadband you have, is it affected by time of day? say peak time 7pm onwards.
I also see bad results sometimes to Google's DNS I feel for people using it in their consoles etc.
I use OpenDNS you can use DNS Bench to find one that suits you.
how is it used
Too fast sampling time, i usually lose packets at almost every hop including my LAN when set to .5
so nothing to worry about
Yeah the lowest I've tested without problems is 1 second. That's what doing a ping command in command prompt does and it works fine so pingplotter should be okay too. Other say use 2.5, even their website says it.. But I find it to be too slow
why is my router highlighted in pink. i wanted to try .5 seconds. this is what happened
They seem to have removed the sub-1-second interval now, it's missing from my Mac version at least.
I can't remember if the 1 sec interval used to bug out too or if it was just sub-1 interval, either way it seems to be fine now.
I've only tested it briefly though.
