ifell Posted July 12, 2021 Posted July 12, 2021 this occurs at random. the longest time this hasn't happened is 5-6 days this is with firmware XR1000-V1.0.0.54_1.0.40 I'm still using firmware Netduma Fraser provided me 1 or 2 devices would be connected to the router but wouldn't configure properly, example IPV4 on a iPad would be set to DHCP and the settings would be IP Address: 169.254.124.145 Subnet Mask: 255.255.0.0 router: comes up blank one or 2 of the game consoles had this happen too. should be IP Address: 192.168.2.67 Subnet Mask: 255.255.255.0 Router: 192.168.2.1 DNS: 192.168.2.1 while this happened I tried to manually set the WIFI configuration to what it should be but it wouldn't work still, only a power cycle would remedy this issue. this has happened a couple of times
Bert Posted July 12, 2021 Posted July 12, 2021 Have you tried setting a IP adress reservation in your DHCP table? IP Address: 169.254.124.145 Subnet Mask: 255.255.0.0router: comes up blank That range is essentially set if your device doesn't get a IP from DHCP at all, ie the DHCP service stops functioning.
ifell Posted July 12, 2021 Author Posted July 12, 2021 it should have been like this IP Address: 192.168.2.67Subnet Mask: 255.255.255.0Router: 192.168.2.1DNS: 192.168.2.1 some devices were unaffected, but the effected ones I manually specified WIFI settings, which didn't work as mentioned before even with the configurations I've set it didn't work until the XR1000 was rebooted its really weird because even if the DHCP wasn't working, manually specifying the IP Address, Subnet Mask, Router\Gateway, DNS. should have worked, but it didn't 😕
Netduma Liam Posted July 12, 2021 Posted July 12, 2021 On the iPad, go to the Wi-Fi settings for the XR1000 network and disable Private addresses, see if this helps!
ifell Posted July 13, 2021 Author Posted July 13, 2021 all that comes up is auto-join: enabled IPV4 Address Configure IP: Automatic aka DHCP IP Address: 192.168.2.24 Subnet Mask 255.255.255.0 router 192.168.2.1 DNS: manual 192.168.2.1 1.1.1.1 1.0.0.1 9.9.9.9 at the moment its working because I restarted the XR 1000
Netduma Liam Posted July 13, 2021 Posted July 13, 2021 6 hours ago, ifell said: all that comes up is auto-join: enabled IPV4 Address Configure IP: Automatic aka DHCP IP Address: 192.168.2.24 Subnet Mask 255.255.255.0 router 192.168.2.1 DNS: manual 192.168.2.1 1.1.1.1 1.0.0.1 9.9.9.9 at the moment its working because I restarted the XR 1000 OK, let us know if the issue re-occurs after disabling private addresses!
ifell Posted July 15, 2021 Author Posted July 15, 2021 I'll try disabling private addresses once the IPAD has connectivity troubles again. this issue isn't just for the iPad, it also happens to consoles, computers, my android phone. my android doesn't have private addresses listed in the WIFI settings and it also runs into connected but no internet
Netduma Liam Posted July 15, 2021 Posted July 15, 2021 47 minutes ago, ifell said: I'll try disabling private addresses once the IPAD has connectivity troubles again. this issue isn't just for the iPad, it also happens to consoles, computers, my android phone. my android doesn't have private addresses listed in the WIFI settings and it also runs into connected but no internet I'd suggest making the changes to the iPad now, then see if it continues to have connectivity troubles. Out of interest, did you factory reset the XR1000 after upgrading to the beta firmware?
ifell Posted July 18, 2021 Author Posted July 18, 2021 yes I factory reset the XR1000 when updating the firmware you provided, the problem has occurred again, on both the iPad and this Computer, I had to USB tether my phone to the computer to get internet. here's what shows up. the iPad doesn't have a private addresses option. I've tried setting up a static IP for the Computer, didn't work. doesn't work with Obtain an IP address automatically, as well as trying different DNS servers
Administrators Netduma Fraser Posted July 18, 2021 Administrators Posted July 18, 2021 Just to clarify, did you change the LAN IP of the router to 192.168.2.1 manually as it's usually 1.1 by default. I have an iPad and it has the private addresses option, click the 'i' on the wifi network and you can disable there, did you also disable it on the PC?
ifell Posted July 18, 2021 Author Posted July 18, 2021 yes I set the LAN as 192.168.2.1, as 192.168.2.1 was the same gateway as the Netduma R2 I was using, just so I didn't have to re-enter everything password/SSID or change the gateway, and devices IP addresses (static IP's) the iPad version 12 doesn't have Private addresses, can't be updated just checked google Chromecast also had the same problem at the time. I couldn't check if changing the network profile from Private to Public would work or not on the computer. Chromecast wasn't connected to the internet either as mentioned above, and someone wanted to stream Kayo so I had to restart the XR1000 just so everything could connect to the internet again ( temporary fix ) there seems to be a big issue with DHCP, but as I've shown previously, I tried to manually specify the IP Address/Gateway/SubnetMask/DNS which again, should have worked but hasn't when it happens to the computer again ill set the Network Profile to Public and see if it detects an internet connection ( IPV4 )
Administrators Netduma Fraser Posted July 18, 2021 Administrators Posted July 18, 2021 Is it an older iPad then? On LAN Settings, set the DHCP range to start at .100 then in LAN settings reserve all your devices and give them IPs between .2-.99 and see if it helps
ifell Posted July 18, 2021 Author Posted July 18, 2021 yeah its an iPad Mini 2, the latest IOS version is 12.4 I think this is how I have LAN DHCP setup LAN TCP/IP Setup IP Address: 192.168.2.1 IP Subnet Mask: 255.255.255.0 RIP Direction: both RIP Version: disabled Use Router As DHCP Server: Enabled Starting IP Address:192.168.2.20 Ending IP Address: 192.168.2.254 I have game consoles and computers already in Address Reservation, haven't changed it since installing the firmware you provided
Administrators Netduma Fraser Posted July 18, 2021 Administrators Posted July 18, 2021 Do change the starting IP address to .100 and make sure reservations are outside the range that DHCP provides - reason being if you give a device a reserved IP of .21 for example the router may mistakenly thing it's using DHCP, try and assign a new IP and thus cause a disconnection - thats a theory anyway
ifell Posted July 23, 2021 Author Posted July 23, 2021 Just a follow up, on the games consoles the Nat type comes up as ( NAT TYPE FAILED ) when this happens, only way to remedy this is to reboot the XR1000. This can happen while the DHCP issue is occurring, and it can happen without the DHCP playing up. I've posted this in the (Nat type trouble on the XR1000 ) since it seems to occur at the same time but not always.
Administrators Netduma Fraser Posted July 23, 2021 Administrators Posted July 23, 2021 I'll post in your other topic, lets keep it going there
