Problem geofiltri Destiny 2
Axel
  • Replies 53
You will not be able to use the geofilter forever. Because Bungie changed the matchmaking to SDR so our ip is completely hidden by steam system. Believe me, it will never work again since the geofilter will not be able to see others' ip to know their ping.
Quindi mi stai dicendo che il modem netgear su destiny 2 non serve più a niente ???!! Praticamente se non funziona il geofiltri a cosa può servire altro ?
There is no other option now. Geofilter is dead now and will never work with destiny 2 again like before. You will never be able to play against your friends or do solo activities. :)
Yes nothing works anymore, geo filter servers will still connect you to servers outside your range, blocking servers manually will still occasionally connect you to that same server, you can't controll servers you connect with ping anymore on Destiny this router is compelty useless. No amount of flushes or resets will help, I mean connecting to the same server I Blocked yesterday with the same name and ip addresss is just retarded.
The router intention is not to help you get into a game solo or force connections to your friends so you're on opposite teams - the intention has always been to get you the best games possible. We are going to re-classify Destiny and push a cloud update so you can at the very least filter via servers properly. We're looking into the possibility of a workaround to allow an unintentional way of connecting to the game but it may not be possible. We'll keep people posted.
@Netduma Fraser  sorry but who talked about forcing matches with friends? !!  I'm interested in the geo filter working, otherwise I spent 400 € for practically nothing, since I only play on destiny.
A lot of people seem to be interested in that so just mentioning it as a few people commented in the topic. We'll be pushing a cloud so you can filter servers when ready, hopefully next week.
It will be pushed automatically to the router, no need for you to do anything
Which routers will be updated?
@Netduma Fraser Thanks for keeping us updated and working on a fix or workaround for this, I know that a bunch of people are quick to jump down you guys' throats on this topic as I am looking for a solution as well.
8 minutes ago, Netduma Fraser said:
لقد رددت على موضوعك ، لا داعي للنشر في كل مكان ، يكفي موضوع واحد :)
Mate are you solve this problem?
Are you referring to Destiny?
Yes
I talked with a guy on Xbox yesterday who told me that they've figured out how to run ghost lobbies after the matchmaking patch. Problem is that they refused to share the info on how to do it.
8 hours ago, Grarrg said:
Any updates?
None as yet I'm afraid, we're still testing potential solutions but unfortunately I don't have an ETA for this.
Hello @Netduma Admin, I acquired my netduma R2, 3 weeks ago. I have been following the posts about the geofilter in Destiny 2. I have a question and a question. The placement: Some people on the xbox, are managing to use the geofiler, did not want to talk about how. My question: Do you believe you launch an att this week? Sorry for English. Greetings BRasileira
