Will r2 work with openreach bt modem ?
Max
59 minutes ago, Max said:
No I’m not adding 5 devices it’s only 4 but When I’m trying switch on or off geofilter this message it’s showing it was working fine last week no problem it works on pc it’s only app
If you delete one of the devices can you toggle the reset on and off?
  • Replies 174
  • 1 month later...
2 hours ago, Max said:
Hi there I updated DumaOS app and sliders on  geofilter it’s working but I got a message like that
Thanks for the report max, could you click export on that message and then post it here please?
Also if you click close can you adjust the settings without it reappearing?
  • 3 weeks later...
Hi there sorry for not replying for long time but I think this issue it’s easy fix this error pop up when you have app open and you login to r2 via browser on the same device in the same time (iPhone)
also I have a simple question does r2 work with any WiFi booster?
I have very weak WiFi upstairs
please advise
thanks
please advise
thanks
Thank you very much for the reproducible steps, I have passed this over to the developer to have a look at.
If the WiFi booster has to be connected via WPS then it won't work but if you can configure it using another method then that should be fine.
  • 2 weeks later...
Hi Fraser a just restarted r2 with the button on the back
I start getting all settings once again and I got disconnected from r2 and now I can’t login
the message is my connection with the website it’s not private
I try on pc
app on phone
and google on phone
can’t get in
what I did wrong and what I need to do to login again
please advise
thanks max
Broadband WiFi it’s going ok all devices are working
I was connect to r2 WiFi
when I was setting up the static ip I was logout from r2 and I can’t login
when I finish my work I do the factory reset again
unless you have different solution?
do I have to do software update after factory reset?
last time I had the latest version
pleas advise
pleas advise
If the reset allows you access, you can then upgrade without needing to reset again.
Let me know if that works.
Guys I do apologies when I done factory reset I think I type in WiFi password for username and password that’s  way I could not login 🤦‍♂️
I done factory reset again and I’m in via pc and phone app
I apologise again and thanks  for support at any day and time
Awesome, no worries at all, glad to hear that!
  • 2 weeks later...
