Wintercabin Posted August 27, 2019 Share Posted August 27, 2019 Hi all! I've come to the point where I need to play a lot of PvP in D2. I'm pretty sure my setup for D2 is outdated and I need help to get it configured so it works correctly for me. I know people have different setups and are located in all different areas so their experiences is completely different. I live dead in the center of the US in Kansas so I have a little room to branch out using the geo-filter. I have the XR500 and I know I'm not using all the features it comes with. I was reading that using the ping assist as a ping filter was 'very powerful'. Would anyone recommend using this in Destiny 2 as the main filter or just continue to use the normal geo-filtering? Also it's been about since early 2018 that I have messed with my Duma settings/D2 setting for geo filtering. What are the optimal settings for my location? I am on Xbox. Thank you in advance! Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted August 27, 2019 Administrators Share Posted August 27, 2019 Recently in Destiny 2, people have reported that the game will only search for a peer-to-peer match for about 30 seconds before it gives up and just routes you through the servers. Because of this, having a very low ping assist setting will most likely cause it to bypass P2P altogether. The best settings would probably involve setting a ping that you consider reasonable in ping assist, make sure that strict mode is off, and see how you go from there. Destiny can be tricky to filter because of their complicated server structure. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 27, 2019 Author Share Posted August 27, 2019 thank you for the reply. how would you go about determining the best ping? What would you start with? Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted August 27, 2019 Administrators Share Posted August 27, 2019 Well what's the average ping you get in a game in Destiny 2? What's the best ping you've ever had in Destiny 2? If you put it in Spectating Mode and leave the Geo-Filter open (maybe on another screen) as you play, with Auto-Ping Host turned on, you'll be able to see the kind of pings you're getting. This should give you an idea of what's reasonable to expect in your area. The Geo-Filter would be able to filter out any games where the ping is unreasonably high for some reason. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 27, 2019 Author Share Posted August 27, 2019 Ok, I will try this later tonight when I get home Link to comment Share on other sites More sharing options...
mathmath51 Posted August 27, 2019 Share Posted August 27, 2019 1 hour ago, Netduma Alex said: Recently in Destiny 2, people have reported that the game will only search for a peer-to-peer match for about 30 seconds before it gives up and just routes you through the servers. Because of this, having a very low ping assist setting will most likely cause it to bypass P2P altogether. The best settings would probably involve setting a ping that you consider reasonable in ping assist, make sure that strict mode is off, and see how you go from there. Destiny can be tricky to filter because of their complicated server structure. Hi, could you be more specific please ? In the geofilter settings, you select the Destiny profile then set the ping assist very low and you will never use P2P anymore to locate a host ? Thanks Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted August 27, 2019 Administrators Share Posted August 27, 2019 Basically if Destiny 2 is unable to get you a P2P match within 30 seconds it seems to switch to matchmaking through dedicated servers. This means that after 30 seconds, all of your Geo-Filter rules are disregarded. We have no control over this. Link to comment Share on other sites More sharing options...
Bmann Posted August 27, 2019 Share Posted August 27, 2019 Destiny is peer to peer and no dedicated servers. I believe that when Geo-filter is enabled it will not go outside of your search area like it would do if geo-filtering is off it will time out and give you a mongoose error. I have been testing after the new firmware patch and switched to strict mode with ping assist. I have been only testing as a solo player and so far after 3 days I have had no disconnects like I did during previous testing. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 27, 2019 Administrators Share Posted August 27, 2019 There are definitely dedicated servers, they use a hybrid system where servers are used when players cannot all connect to each other. They are also used to periodically check (stats, connection etc) when playing. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 27, 2019 Author Share Posted August 27, 2019 so i did what Alex said previously and this is what I get Link to comment Share on other sites More sharing options...
Wintercabin Posted August 27, 2019 Author Share Posted August 27, 2019 lots of connections outside my area Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 27, 2019 Administrators Share Posted August 27, 2019 They're connecting through the dedicated server within your radius, that can't be helped but because it's close to you then you'll still have the advantage. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 So when I use Auto-ping for PvP it barely shows anything when i'm searching or playing a match. When it does say something it's only up for like 15 seconds or less. Is that normal? Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted August 28, 2019 Administrators Share Posted August 28, 2019 It will connect to the most recent thing that was connected to. Sometimes if it's only a brief connection, it will disappear quickly too. You could try manually pinging the host if you want to keep it on the screen for longer. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 I can't ping it unless I uncheck the auto-ping option. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 19 hours ago, Bmann said: Destiny is peer to peer and no dedicated servers. I believe that when Geo-filter is enabled it will not go outside of your search area like it would do if geo-filtering is off it will time out and give you a mongoose error. I have been testing after the new firmware patch and switched to strict mode with ping assist. I have been only testing as a solo player and so far after 3 days I have had no disconnects like I did during previous testing. How have been the connections you've experienced? Is the bullet detection the same across your games? Link to comment Share on other sites More sharing options...
Bmann Posted August 28, 2019 Share Posted August 28, 2019 Iron Banner is usually the worse for me for whatever reason. I do find that ghost bullets to be bad probably half of the time in pvp and certain game modes like comp and IB tend to be worse. We are at the misery of Destiny deciding who the host is and its not always in our favor. I hate the fact that I can drop 40 plus kills in one game and the next match I can barley kill anyone and I am doing everything I can. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 that's disappointing and accurate to my experience last night. I would say 3/10 PvP matches seems liked the Duma was doing what it's supposed to be doing. @Netduma Admin @Netduma Fraser @Netduma Alex @Netduma Jack Can I setup a session with someone and confirm I am using/doing is accurate so this product works for me? thank you in advance, Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 28, 2019 Administrators Share Posted August 28, 2019 The auto ping won't be as useful for Destiny as most of the time it will be P2P so there won't always be one host per se so the Auto Ping will get confused. We're a small busy team so can't really provide 1 on 1 sessions unless there is a major issue and from your screenshots and descriptions there wouldn't be much we could do. Geo-Filter settings look fine but what settings are you using for QoS? Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 Ok, I guess that's fair enough. So would it be accurate to say that Destiny 2 isn't exactly a game that is fully supported by DumaOS? Definitely not trying to be difficult I'm just trying to understand why this product only works 30% of the time for Destiny 2. I wish I was into COD or something because it seems like the game you guys use most to advertise the Duma. My QoS is setup as recommended on this forum. I can't seem to find the thread I used but I think it's like the console gets 70% ?? when traffic gets saturated by something. Is there a specific setting I need to be following for optimum QoS for D2 PvP? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 28, 2019 Administrators Share Posted August 28, 2019 It is supported but it can be tricky in that they've changed their matchmaking. It should still help you as the server is closest to you so then you should have an advantage. I'd suggest you follow this guide: http://support.netduma.com/en/support/solutions/articles/16000074717-diagnose-modem-internet-service-provider-issues while saturating your connection e.g. downloading, streaming etc and trying different Anti-Bufferbloat percentages until you find what works best for you by keeping the ping low and stable. Depending on your internet usage use 'Always' if people stream etc a lot, it will help with buffering or use 'When High Priority Traffic Detected' if not much bandwidth is used. I usually leave Bandwidth Allocation alone with share excess enabled for download/upload. Keep Traffic Prioritization using DumaOS Classified Games. No specific QoS for D2 but this should get you optimal. Link to comment Share on other sites More sharing options...
Wintercabin Posted August 28, 2019 Author Share Posted August 28, 2019 My DL speed is usually ~200+ down and 25 up so I use 'When High Priority Traffic Detected'. I'll have to check the ping when I get home from work. One question I do have is that some of their "dedicated" servers that do pop up from time to time, should I deny those and only Allow the ones closest to me? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted August 28, 2019 Administrators Share Posted August 28, 2019 It might be risky as you might block ones used for authentication which could cause kicking during the game etc. Strict mode on would be better than blocking servers in this instance but could still cause kicks etc. Link to comment Share on other sites More sharing options...
Engineerbyday Posted September 13, 2019 Share Posted September 13, 2019 Why doesn't my net duma shows which sever I'm connected to and who's connected to me? like the picture I posted. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted September 14, 2019 Administrators Share Posted September 14, 2019 You're connected to the server in the middle of your radius and those players in your radius. It's also possible the ones outside your radius are connecting through the dedicated server to you but you have the advantage as the server is close to you. Link to comment Share on other sites More sharing options...
