Administrators Netduma Alex Posted April 23, 2020 Administrators Posted April 23, 2020 3 hours ago, hell12309 said: im having trouble i let someone use my wifi and they installed some custom firmware on it and ive tried multiple time reinstalling the duma OS firmware in it but no luck can u guys help me We can't really help because, as @BIG__DOG said, the warranty is void. That said, @Dilly Dilly made a great suggestion. You can try to upload the latest DumaOS firmware using TFTP. You'll have to figure it out on your own but it should be quite easy using this guide: https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Mercenary Posted April 23, 2020 Posted April 23, 2020 What even is a TFTP client does it restore the original firmware
Mercenary Posted April 23, 2020 Posted April 23, 2020 That's what YouTube is for sometimes they have set up tutorials
BIG__DOG Posted April 23, 2020 Posted April 23, 2020 1 hour ago, fpsmercs said: What even is a TFTP client does it restore the original firmware You need a program such as putty. I wasn't going to suggest this as beinng a moderator it is not my place to advise. It is a fairly straight forward process so long as you are somewhat network savvy just in case you run into any snags.
Mercenary Posted April 23, 2020 Posted April 23, 2020 Thank you very much I appreciate this for helping me I'll have to do this later tonight when everyone's asleep there's a few people that use the internet and they're going to wonder why I'm doing this they're not going to understand they're not much of a tech savvy person if I don't know how to use that YouTube has some set up wizards sometimes
Mercenary Posted April 23, 2020 Posted April 23, 2020 or I can figure it out I do have short-term memory loss but I am pretty good at figuring stuff out
BIG__DOG Posted April 23, 2020 Posted April 23, 2020 11 minutes ago, fpsmercs said: or I can figure it out I do have short-term memory loss but I am pretty good at figuring stuff out there are lots of tutorials on YT on how to do this to a router. The link that Alex posted will fully guide you through it. I suggest you have that page open on another browser to refer to while you are going through the process or print the instructions out. Good luck.
Krush Posted April 23, 2020 Posted April 23, 2020 I can say that I managed to do it with the XR500. I had published these links at the time ...
Mercenary Posted April 23, 2020 Posted April 23, 2020 does my computer have to be hardwired directly to the router or no because my computer is somewhere else in the same room and it's really heavy it's a pretty old PC but it runs the latest software it's the Windows 10 but it's a 2013 PC it's not too old it can play some new games but the graphics card isn't letting me play every new game The graphics card is a G-Force GTX 750 TI 2 vram DDR3 32 gigs of RAM almost I have 20 gigs of RAM
Newfoundland Posted April 23, 2020 Posted April 23, 2020 Just now, fpsmercs said: does my computer have to be hardwired directly to the router or no because my computer is somewhere else in the same room and it's really heavy it's a pretty old PC but it runs the latest software it's the Windows 10 but it's a 2013 PC it's not too old it can play some new games but the graphics card isn't letting me play every new game The graphics card is a G-Force GTX 750 TI 2 vram DDR3 32 gigs of RAM almost I have 20 gigs of RAM Do you play COD?
Mercenary Posted April 23, 2020 Posted April 23, 2020 I use my PS4 to play all that stuff and yes I do play cod only on the PS4 though if you are planning on adding me my username is Fps Mercs axactly how I wrote it if you can't add me through my Activision ID my PlayStation 4 ID is rustycodplayer you can add me on different consoles through my PlayStation ID you just have to change the friend request system to PlayStation Network
BIG__DOG Posted April 23, 2020 Posted April 23, 2020 1 hour ago, fpsmercs said: does my computer have to be hardwired directly to the router or no because my computer is somewhere else in the same room and it's really heavy it's a pretty old PC but it runs the latest software it's the Windows 10 but it's a 2013 PC it's not too old it can play some new games but the graphics card isn't letting me play every new game The graphics card is a G-Force GTX 750 TI 2 vram DDR3 32 gigs of RAM almost I have 20 gigs of RAM yes, you absolutely must be hard wired (if you are referring to installing firmware or using TFTP).
Mercenary Posted April 23, 2020 Posted April 23, 2020 Okay I understand I'll have to do it later tonight or tomorrow night I'm not sure when whenever anyone else isn't using the internet or gone
Mercenary Posted April 24, 2020 Posted April 24, 2020 This worked I got 0 blocks transmitted took awhile to figure it out and the router is in the recovery mode LOL it didn't reboot yet sooo
Mercenary Posted April 24, 2020 Posted April 24, 2020 I don't know if I'm really doing it right it says zero block transferred in 0 seconds to 0 block retransmitted MD5 I don't know if I'm doing it right
Mercenary Posted April 24, 2020 Posted April 24, 2020 I'm getting pretty mad right now this stupid 64-bit application you guys had me download is working but it's not working the way it's supposed to work The log viewer doesn't tell me anything TCP client sometimes it works sometimes it doesn't I also tried to do the putty but that's ridiculously hard I'm confused I don't know why you guys aren't messaging me back right it's still in recovery mode
Administrators Netduma Alex Posted April 24, 2020 Administrators Posted April 24, 2020 Nobody was online to reply... Anyway it looks like you're making progress, you just need to follow the guide to the letter. I can't really help you any more than that.
Mercenary Posted April 24, 2020 Posted April 24, 2020 Progress it's not even restarting after 4 minutes
Mercenary Posted April 24, 2020 Posted April 24, 2020 Is it even supposed to restart I'm getting very frustrated
Mercenary Posted April 24, 2020 Posted April 24, 2020 Thanks a lot guys The bios got corrupted now I have to reinstall the stupid operating system and TFTPD 64 isn't even working the way supposed to
Mercenary Posted April 24, 2020 Posted April 24, 2020 Whenever I try to flash the bios the white light keeps blinking
Newfoundland Posted April 24, 2020 Posted April 24, 2020 If you wanted a router with third party stuff on the R7800 would have been best and Voxels firmware and a few others that add stuff. Cracking WiFi too.
