DAKOTADOCKALL Posted May 8, 2017 Posted May 8, 2017 I cant get it to be a+ no mater where i set the upload and download bar in the CC. Can anyone give me a hand? I can try and screen shot things if necessary.
BIG__DOG Posted May 8, 2017 Posted May 8, 2017 1st of all, gaming on ps4 or any other console uses a tiny ammount of bandwidth so giving that much bandwidth is basically overkill and pointless. reset share excess and leave it alone.........what are your isp speeds, provider and modem/router the duma is connected to? If you want to test for bufferbloat it needs to be over ethernet through a pc and not a console browser and if you are doing it through the console browser you are doing it all wrong.
DAKOTADOCKALL Posted May 8, 2017 Author Posted May 8, 2017 My isp speeds are 200/10 my modem is a sbg6580 in bridge mode my provider is cableone and i have been using my pc
BIG__DOG Posted May 8, 2017 Posted May 8, 2017 ok. Make sure you have reset share excess and they are both enabled for upload and download. The 70/70% rule in anti flood is only a guideline as all connections are unique due to distance, quality of connection isp,the list is endless. do a speedtest at speedtest. net roughly 6 times and write the results down, work out your average upload and download speed results and then input 95% of those totals into bandwidth settings and when prompted if you want duma to make changes click NO. now for the painful task.....reduce you anti flood sliders 3 or 5% at a time after running a bufferbloat test to see which gives you the best result. an A or A+ is what you are after but so long as you arent getting ping spikes on the upload then you will be fine as it is the upload that is your hit detection. my speeds i actually get are 75/18 so i put in the bandwidth settings 67.5 and 16.4 as that is 95% of my average speeds.
DAKOTADOCKALL Posted May 8, 2017 Author Posted May 8, 2017 okay i did as you said heres a screen shot from dsl reports
DAKOTADOCKALL Posted May 8, 2017 Author Posted May 8, 2017 okay i posted that before i show your post there ill get back to you once im done
DAKOTADOCKALL Posted May 8, 2017 Author Posted May 8, 2017 btw do you why my netduma is slow now after reseting share excess ? and im still working the 3 to 5% dont really understand what to do on that
DAKOTADOCKALL Posted May 8, 2017 Author Posted May 8, 2017 okay i just got done with the CC sliders and this is my results BIG__DOG. I also had to turn turbo mode of the get this if that helps
BIG__DOG Posted May 9, 2017 Posted May 9, 2017 Hi. Did you turn turbo mode on or off?, I dont have download speeds like your's but I understand that for those speeds you should also try super turbo mode but I am sure I will be corrected if I am wrong on that! Have you tried gaming with that last setting you posted?
RADDY1993 Posted May 9, 2017 Posted May 9, 2017 I get A+ across the board, what i do is go into my Modem and get my speeds from there and enter those into the Duma. I then set my CC to Upload 80% and Download 90%, try that and see what you get.
Administrators Netduma Fraser Posted May 9, 2017 Administrators Posted May 9, 2017 Hey, welcome to the forum! I wouldn't worry about bufferbloat at all, it only happens when your connection is saturated. With the speeds you have and with CC enabled you're not going to experience it.
garage gorilla Posted May 15, 2017 Posted May 15, 2017 tbh even with your mom using wifi your gf on wifi you gaming isn't enough to cost bad bufferbloat imo i was getting f and fifa felt fine got a+ and fifa felt laggy vs the same person lol
Direink144 Posted May 16, 2017 Posted May 16, 2017 Hi...try changing your bandwidth on your main router.. I went from 20 to 40 and it made a huge difference... Now my bufferbloat is A+...
Glazeko Posted May 20, 2017 Posted May 20, 2017 Hey, welcome to the forum! I wouldn't worry about bufferbloat at all, it only happens when your connection is saturated. With the speeds you have and with CC enabled you're not going to experience it. OK so if why even if I use all the recommended settings or go by searching which one works for me. Why I never get good results for buffebloat?
Netduma Staff Netduma Jack Posted May 22, 2017 Netduma Staff Posted May 22, 2017 OK so if why even if I use all the recommended settings or go by searching which one works for me. Why I never get good results for buffebloat? Well not only is it not terribly accurate, but there's also a lot of variables. Having your anti-flood set to 70/70 or there abouts should nullify the effects of bufferbloat anyway. Just make sure you're put the speeds you are receiving into "Set Bandwidth" and you should be fine - regardless of what the bufferbloat test states. It's all about how the game actually feels, and the actual effects on your other devices.
DAKOTADOCKALL Posted June 19, 2017 Author Posted June 19, 2017 Iv have fixed this problem you can close this thread admin sorry for the long wait.
Cécé Posted June 20, 2017 Posted June 20, 2017 ok. Make sure you have reset share excess and they are both enabled for upload and download. The 70/70% rule in anti flood is only a guideline as all connections are unique due to distance, quality of connection isp,the list is endless. do a speedtest at speedtest. net roughly 6 times and write the results down, work out your average upload and download speed results and then input 95% of those totals into bandwidth settings and when prompted if you want duma to make changes click NO. now for the painful task.....reduce you anti flood sliders 3 or 5% at a time after running a bufferbloat test to see which gives you the best result. an A or A+ is what you are after but so long as you arent getting ping spikes on the upload then you will be fine as it is the upload that is your hit detection. my speeds i actually get are 75/18 so i put in the bandwidth settings 67.5 and 16.4 as that is 95% of my average speeds. bonjour, Je fais mes tests de vitesse avec le mode turbo et j'ai après calcul à 95% 218.5 download et 105 upload le probleme est que en laissant l'algorythme en réactif, aucun calcul de bufferbloat ne démarre sur le site dslreport. Je mets en préemptif et la le calcul fonctionne, je laisse en réactif mais retire le mode turbo et ça marche aussi je suis perdu pouvez vous m'aider svp?
Administrators Netduma Fraser Posted June 20, 2017 Administrators Posted June 20, 2017 Great to hear that! Feel free to open another thread if you have any further questions/issues.
Administrators Netduma Fraser Posted June 20, 2017 Administrators Posted June 20, 2017 bonjour, Je fais mes tests de vitesse avec le mode turbo et j'ai après calcul à 95% 218.5 download et 105 upload le probleme est que en laissant l'algorythme en réactif, aucun calcul de bufferbloat ne démarre sur le site dslreport. Je mets en préemptif et la le calcul fonctionne, je laisse en réactif mais retire le mode turbo et ça marche aussi je suis perdu pouvez vous m'aider svp? Please make a new topic as the original posters issue has been resolved I'll be closing this topic. S'il vous plaît, créez un nouveau sujet lorsque la question des affiches originales a été résolue. Je terminerai ce sujet.
