Need help with settings for IW. Bo3 is great!!!
So I'm new to netduma, but I am very up to date on everything for the most part. I played bo3 and IW with the same settings and IW is so trash for hit detection compared to bo3. 70/70 l, 100/10, 10/10 I've tried all the cc's you can think of. I need help bc I need to wreck in this game!!!!
Congestion control shouldn't have anything to do with hit detection. The purpose of congestion control is to limit the maximum amount of bandwidth that can be used so people in your house can't saturate your connection which would cause your ping to increase.
If you want to know why you can't hit anything, watch this...
I only have IW on XB1 but if you want, you can try my settings... Every COD including IW runs great here. Actually, I haven't really tested MW:R enough yet, don't want to make a liar out of myself lol
http://twitter.com/a7legit/status/799921711114121216
What are your settings for PS4 version of the game?  Would love to see the Miscellaneous settings as well.
Thank You
I love both of these videos.  I've never heard of this guy but I have subscribed to him now.
Thanks a lot @A7Legit. Tried the setup and got very good results. Had to find the ports to forward for ps4 at port forward.com
Great to hear that! Let us know if you have any further issues.
need help. my download speed is 9-12mbps and upload is 573kbps. what should my best geo-filter setting be? i found that for IW 40-50ms worked great. I've been able to a lot of 15-25 gun streaks on it. b03 I would be able to gets nukes around 20. But now no matter what I seem to lag a bit and have been getting melted often even by sitting back more or rush.
Please could you make your own thread including the screenshots from here and we'll best be able to help: http://support.netduma.com/support/solutions/articles/16000022425-lag-support-instructions-to-post-on-the-forum-
However, make sure all devices connected to R1 so congestion control works correctly. 70/70 anti-flood, console in hyper traffic. ~1000km radius, strict on, PA 0.
  • 4 weeks later...
What's the benefit of Port forwarding over upnp?
UPnP opens ports automatically for that device, whereas Port Forwarding requires you to manually select which ports become open (Though in this way, port forwarding can cater to specific needs.) That's the basic difference; so I'd say the benefit is being able to open ports for specific games rather than relying on an automatic system which sometimes gets it wrong.
Yeah that's true. You don't suppose that port forwarding is maybe more reliable and consistent?
It will ensure that those ports are always open for that device. Whereas UPnP will not open them all unless it detects that it needs it. So it's up to you really.
Port forwarding = single device you're trying to get an open nat for
Upnp = multiple devices you're trying to get open nat for
Upnp doesn't always work that well because the games do not request the appropriate ports all the time. And that is on the game developers.
Exactly what Buck said, if the game doesn't request the port or ports to be opened then they won't be opened (dev thing not a duma thing)
You can always check on your duma under settings > UPnP after the game is launched and see which ports are opened.
With that being said the duma does a really good job of opening the required ports and as long as I got an open NAT I just use UPnP.But if you have a moderate or strict NAT,then maybe you should give manual port forwarding a try.
