oatesy50 Posted December 23, 2015 Posted December 23, 2015 Hi, iv posted this problem up a few times now and still not had any feed back on how to resolve this issue, for some reason or another my netduma is taking FOREVER to load, including Host filtering, settings, congestion control ETC and i mean forever, sometimes i sit waiting for the host filtering page to load for over 10mins sometimes, and it also keeps telling me that im pinging at over 900ms which is clearly wrong! Any help with this would be very much appreciated as im loosing faith in my netduma, it just seems to be a bit redundant since BO3 has come out, i get into better connection lobbies without the host filtering than i do with it, and every time i try and use my netduma it just slows right down and gives me false ping feedback! Thank you
Netduma Staff Netduma Crossy Posted December 23, 2015 Netduma Staff Posted December 23, 2015 What version are you on?
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 Im using the latest FW as far as i know R1 debug version 1.03.5m running on rb-951g-2hnd
PharmDawgg Posted December 23, 2015 Posted December 23, 2015 What have you already tried that way we want repeat ourselves?
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 i have tried rebooting the R1 which helps with the loading problem for about 20mins then it goes back to slowing right up again, iv have tried putting my PA to 0 and to just search for games with filter by distance, iv tried changing some of the miscellaneous settings around which hasn't really helped and enable auto cloud and bleeding edge cloud are always ticked
Scrizzy Posted December 23, 2015 Posted December 23, 2015 This was happening to me as well. For some reason the Misc settings kept resetting back to everything "ticked"! In particular, having the Turbo modes ticked caused tremendous slowdown and the browser would take forever to shift between menus in the Netduma. Unticking the Turbo, Subperturbo, IPV6, etc. and refreshing seemed to do the trick for me. All I leave selected is Enable Cookies, Multicast snooping, and Upnp. Not sure if anything else there is really critical for me. Problem is, last night it kept reverting back to everything ticked like every half hour or so, so I'd have to rinse and repeat. I'm not sure what was causing it.. And I'm on the 1.03.5m
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 This was happening to me as well. For some reason the Misc settings kept resetting back to everything "ticked"! In particular, having the Turbo modes ticked caused tremendous slowdown and the browser would take forever to shift between menus in the Netduma. Unticking the Turbo, Subperturbo, IPV6, etc. and refreshing seemed to do the trick for me. All I leave selected is Enable Cookies, Multicast snooping, and Upnp. Not sure if anything else there is really critical for me. Problem is, last night it kept reverting back to everything ticked like every half hour or so, so I'd have to rinse and repeat. I'm not sure what was causing it.. And I'm on the 1.03.5m This happens to me as well, every so often i go into the settings after its taken its time to load and every thing i unticked would ticked again, and i have exactly the same settings ticked as you but this doesn't help with the slow down or the ping issue :-(
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 So no one has any ideas of how to fix this issue then?
Netduma Staff Netduma Crossy Posted December 23, 2015 Netduma Staff Posted December 23, 2015 So no one has any ideas of how to fix this issue then? You could try a factory reset
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 You could try a factory reset Iv done a factory reset twice and the problem is still ongoing, Im starting to think maybe my R1 is faulty! :-( Do you think going back to the old firmware will help?
Netduma Staff Netduma Crossy Posted December 23, 2015 Netduma Staff Posted December 23, 2015 Iv done a factory reset twice and the problem is still ongoing, Im starting to think maybe my R1 is faulty! :-( Do you think going back to the old firmware will help? It isn't recommended to go back versions. Could you try using a different device to access the interface?
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 It isn't recommended to go back versions. Could you try using a different device to access the interface? Ok i shall leave the FW as it is for now, and yes i have tried 3 different devices, my laptop (wired) another family members laptop (wireless) and my phone (wireless) and its doing the same on all 3 devices, and it just seem to be getting slower and slower each time i reload a page, i have just restarted my netduma, it fixed the problem for about a 3mins and its now gone back to being painstakingly slow and showing me that im pinging at over 900ms again and now its not showing anything on the geo-filter map even though im in a game! :-/ Something is definitely wrong here!
Netduma Staff Netduma Crossy Posted December 23, 2015 Netduma Staff Posted December 23, 2015 Iain has been checking the forum today so when he checks I'm sure he will be able to give you a solution or look into it
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 Iain has been checking the forum today so when he checks I'm sure he will be able to give you a solution or look into it i hope so because this is driving me slightly mad now
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 I thought id solved the problem for a minute then, i completely unplugged my R1 and left it to cool down and it seemed to sort the slow down issue out for all of 30mins and its doing everything it was before again, running slow as hell and giving me false ping readings of 900ms, this is absolutely ridiculous and getting out of hand now, its rendered my netduma almost unusable!
Netduma Staff Netduma Crossy Posted December 23, 2015 Netduma Staff Posted December 23, 2015 Do you have turbo mode enabled? If you do, try disabling it and see if it stops it getting so hot (which might fix the other issues you are having).
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 Nope, turbo mode and super turbo mode are both unticked but saying that every now and again when i go back into settings everything is ticked again by its self and i have to put my settings back to what they were
PharmDawgg Posted December 23, 2015 Posted December 23, 2015 Is you're router plugged into a power strip? Sounds like your router is rebooting itself.
oatesy50 Posted December 23, 2015 Author Posted December 23, 2015 power strip? its plugged straight into the wall, and im pretty sure its not rebooting its self because it would kick me offline every time it did reboot and that doesn't happen
Administrators Netduma Iain Posted December 25, 2015 Administrators Posted December 25, 2015 Oatesy can you go to "Congestion Control" it may take a long time for it to load but just wait. Then go to "Device Priotisation" and click "Reset Distribution". Then also make sure your anti-flood sliders are set to 100%. Does this fix the issue?
oatesy50 Posted December 28, 2015 Author Posted December 28, 2015 Oatesy can you go to "Congestion Control" it may take a long time for it to load but just wait. Then go to "Device Priotisation" and click "Reset Distribution". Then also make sure your anti-flood sliders are set to 100%. Does this fix the issue? Hi, sorry iv taken a while to reply, been a bit of a busy Christmas, i have done what you have suggested and it seems to have sorted the problem for now, thank you all for the help! :-) i shall let you know if it starts doing it again
oatesy50 Posted December 28, 2015 Author Posted December 28, 2015 Nope, its gone back to being ridiculously slow and telling me in pinging at over 900ms again!! Why is it doing this?!? :-(
Netduma Staff Netduma Crossy Posted December 28, 2015 Netduma Staff Posted December 28, 2015 Nope, its gone back to being ridiculously slow and telling me in pinging at over 900ms again!! Why is it doing this?!? :-( Are you using PPoE?
oatesy50 Posted December 28, 2015 Author Posted December 28, 2015 Are you using PPoE? Well the netduma is connected to my ISP router via Ethernet cable, is that what you mean?
Netduma Staff Netduma Crossy Posted December 28, 2015 Netduma Staff Posted December 28, 2015 Well the netduma is connected to my ISP router via Ethernet cable, is that what you mean? That means you're not using PPoE if it is connected to a router You could possibly try factory resetting if you haven't already tried it or you could wait and see if Iain/Fraser can take a look without the need for a factory reset.
