Aeup Posted December 4, 2015 Posted December 4, 2015 If you buy the netduma router do you have to pay monthly or once you buy you won't have to worry about paying monthly? Is the netduma also good for playing xbox live?
II N3MES1S II Posted December 4, 2015 Posted December 4, 2015 Why do you think you have to pay a monthly fee? It is made for online gaming.
Aeup Posted December 4, 2015 Author Posted December 4, 2015 Oh ok is it easy to setup? It's not a scam right like it's actually legit?
II N3MES1S II Posted December 4, 2015 Posted December 4, 2015 No need to worry man its all good. First day I heard about the router my hands were itching to spend that money, I believe I ordered it the next day. Got it in two days and used a 10% off code. It does what it says, but know this, it is made for people who like to tinker with settings but it can be somewhat plug and play.
Administrators Netduma Fraser Posted December 4, 2015 Administrators Posted December 4, 2015 No monthly fee, just a one time purchase & yes it works for XBL
Aeup Posted December 4, 2015 Author Posted December 4, 2015 Also one more question. I was looking at routers and some of them require a vpn do i need one for the netduma?
wrathoftank Posted December 4, 2015 Posted December 4, 2015 Also one more question. I was looking at routers and some of them require a vpn do i need one for the netduma? no, you don't need a vpn to use netduma. Check out the netduma wiki for a bunch of info http://wiki.netduma.com/doku.php?id=startand feel free to ask anything you feel is unanswered
fuzzy clam Posted December 4, 2015 Posted December 4, 2015 Pull the trigger on the router you won't be sorry,it's the best purchase i've made for gaming aside from my console... And it's really user friendly and easy to set up.And if you ever have any issues during set up post your issues and we'll get it sorted out for you.After all that's what the forum is for.
Administrators Netduma Iain Posted December 4, 2015 Administrators Posted December 4, 2015 If you buy the netduma router do you have to pay monthly or once you buy you won't have to worry about paying monthly? Is the netduma also good for playing xbox live? Hi, just want to add you still need an Internet connection.
Aeup Posted December 17, 2015 Author Posted December 17, 2015 do you need a modem with the netduma? and if you dont does the netduam need a internet provider for it to work?
Netduma Staff Netduma Crossy Posted December 17, 2015 Netduma Staff Posted December 17, 2015 do you need a modem with the netduma? and if you dont does the netduam need a internet provider for it to work? You need a modem and an ISP.
Alex Posted December 17, 2015 Posted December 17, 2015 do you need a modem with the netduma? and if you dont does the netduam need a internet provider for it to work? I'm not trying to be mean or rude, but you may want to research home networking basics to get an understanding of how this all works.
secretface Posted December 17, 2015 Posted December 17, 2015 buddy it sounds likeyou don't know much about computers so in that case I would say no! You dont just plug this in and it works. I have been tinkering with mine for over a month
