Destiny - Quail, Beaver, General Network Errors
  • Replies 154
I am also having this issue. Fraser 1 to 1 last night with no issue. Upon finishing the one to one and testing late into the night I was still getting beaver errors on entering tower and within and zoning in of crucible.
If anyone is having this issue please do either provide me with IDs of blocked hosts or PM me for a 1 on 1 today. Liam I'll PM back soon for another 1 on 1.
I'll be doing a cloud update today so would really like to get Destiny sorted as well
Just wanted to chip in on this too. Had the same disconnects from Trials over the weekend, usually during load screen. I've had a couple of Lan Connection failures too.
I set up my netduma as per the Crucible settings.
Hi,send Fraiser a PM,and asi if he can do a 1-1 with you,go into the Shoutout box and ask for some assistance,i have no idea why mine started to work at all,.well yes after the 1-1 it was ok?
I'd love to do a 1 on 1 Fraser - but I suspect we'll struggle due to timezone differences. I'm on GMT in the UK.
Is there anyway for you to remotely access my router to obtain log information?
So i disconnected mine for about 15 mins last time then reconnected it,but no joy it was only when frasier looked at mine it worked...whats your skype maybe i can talk my settings to you whilst your online
Thought I would share this screenshot to show you what the Crucible is like for me with Host Filtering turned off. I am in the UK, playing people from Africa and the US.
Any updates from Netduma staff on how to resolve would be greatly appreciated.
Screen%20Shot%202015-11-18%20at%2016.58.
Sorry for the delayed response to this, have been extremely busy this week. I suspect there are some IDs that need adding to the allow list. I will respond to your PM dai and set up a 1 on 1 with you and let others know what happens
What kind of timescale you looking at Fraser? Quail errors are getting the better of me right now.....
Howd you go with the resolution?
As be nice for all destiny players to get some settings feedback etc.
Its all blops 3 ..
I can share some info if ya need it.
Mine playes ok for about a hour? Then i randomly get kicked "beaver"
Have to turn off geofilter then restart a game play without it on then when it ends turn geofilter on?
Then usually ok with mostly 60 ms but sometimes it can be one shooting upto 180 200 300 ms
Of you turn geo off its not that good but you can play and wont get kicked.
Geo on for whatever reason can make you get kicked still...
Its a learning curve ...but think we need more help setups for destiny pvp.
Cheers ..
Here are some updates on my experiences over the past week or so.
Friday 20th Nov
  • Installed new firmware update (1.03.5)
Tested over the weekend. After installing this update I was getting kicked less, but still too frequently.
Wednesday 25th Nov
Had a one on one with Fraser. He changed the following:
  • Host Filtering
    • Peer Ping - Checked
    • Auto Ping Host - Unchecked
    • Kilometres - Checked
    • Strict Mode - Unchecked
    • Show Dormant Hosts - Checked
    • Show Legend - Checked
    • Increased distance filter from 500km to 1,000km
  • Settings > LAN
    • IPv6 - Disabled
  • Settings > WAN
    • IPv6 - Disabled
  • Settings > Miscellaneous > Miscellaneous
    • Enable deep packet processing - Unchecked
    • Allow auto feedback(no personal data ever) to help improve the R1 - Checked
    • Allow remote access to Netduma tech support - Checked
    • Enable upnp forwarding - Unchecked
    • Enable multicast snooping - Unchecked
    • Enable link-local IPv6 - Unchecked
    • Access control panel from WAN(not recommend) - Unchecked
    • Enable cookies - Checked
    • Enable wifi work-around - Checked
    • Stealth Mode - Unchecked
    • Turbo mode - Unchecked
    • Super Turbo mode (disables CC) - Unchecked
  • Settings > Miscellaneous > Cloud Settings
    • Enable auto cloud - Checked
    • Bleeding edge cloud - Checked
    • Clicked "Apply Cloud Settings"
Here are my results so far:
Successful games
12
Kicked games
Kicked from Tower
