Miiiithraaks Posted September 27, 2023 Posted September 27, 2023 Hi all, long time lurker. Ive had an XR500 since launch and an XR1000 since launch. Ive been using the XR1000 exclusively since I got it. Ive had most of the frustrating and annoying issues people describe here in the forum. Ive lurked and tried a lot of the suggestions given. Actually, I think I did find this particular one on this forum too but Im not sure which post it was. Ive had quite a few of the issues reported. Devices not connecting\losing connection requiring a router reboot to work again. Rebooting the device and router at least daily which escalated to more reboots needed over time. Finally after rebooting there was a 50% chance the router would reset itself and Id need to factory reset it. This became a daily event. Often multilple times a day in the end. Id get the hasrl CGI errors\inaccessable web GUI and the routers WIFI would work but not work (hard to describe this one) and need to factory reset. Im sure Im missing some other quirky issue here also. Anyways, nothing seemed to help. Resets and re-configs didnt help. Doing the dhcp in the .50s and using IP reservations didnt do anything. I think port forwarding made things worse haha. I finally tried to use TFTP to re-load the firmware. Now this is a troubleshooting method Netgear gives. They even mention its to help with DHCP issues. But the instructions on the Netgear site simply do not work. There is a very short window to get the command in which feels impossible with my feeble human fingers. Ended up finding a post here believe mentioning using nmrpflash instead and using that to flash the router firmware. This may not be simple for non-technical individuals as skillsets do vary. Once everything is connected, it worked without issue. It did take a me few moments to get the connection working I will admit but that might be just me. So, again, I do heed caution if you are unfamiliar with some of this stuff as you could potentially brick something. Chances of that are provably low but you never know so Ill throw out a precaution. I got the software from a Github but Im not sure if its ok to post links here. I went ahead and used nmrpflash per the ReadMe instuctions on the Github. I used the most recent Xr1000 firmware, 1.0.0.68_1.0.54. So far, its been just over a month and Ive rebooted once about a week ago. This was due to a setting change I made. Ive configured it and I havent had a device lose connection and need a router reboot yet. Even the notorious old TV and old samsung tablet I have that lost connection every single day. Its crazy to me. So far so good anyway... I hope my little anecdotal experience maybe helps someone else out there because I do love this router but it also can be a really frustrating little piece of technology when it wants to be. MarkonikovBR, TrayDay and Krush 3
Miiiithraaks Posted September 27, 2023 Author Posted September 27, 2023 Little additional info here. Ill throw in some links but if not allowed, delete them. Here is the Netgear KB article that led me to try to use TFTP rather than just factory resetting or using an old firmware and uploading through the GUI ( Ive done those so many times now its hilarious.). This TFTP method may work but I could not get it to with the XR1000. I tried quite a few times before just giving up out of frustration. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP I kept poking around for how to TFTP a firmware to the router and eventually came across this post. This isnt from this forum but appears to be the Netgear equivalent sister forum. This led me to try to use the nmrpflash tool to get the firmware flashed. https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR1000-unresponsive-and-unable-to-update-firmware/m-p/2216450
AZX Posted September 27, 2023 Posted September 27, 2023 Interesting. I have all the same issues listed with my xr1000. I have also been lurking for answers/resolution for quite awhile lol. Pretty sure Fraser would block me if he could. I will give this a go tonight and report back.
Miiiithraaks Posted September 27, 2023 Author Posted September 27, 2023 Haha I hear ya man. Ive tried most everything and nothing really ever helped for any extended period of time. Usually it was back to its same shenanigans the next day if not the same day. I was at the point of giving up and tried this. I cant say if it will stay working this way but its the most stable its been for a long, long time. Good luck man, I really hope it helps.
Administrators Netduma Fraser Posted September 28, 2023 Administrators Posted September 28, 2023 Sounds like you had an issue in the boot process which is why TFTP helped (it skips the boot process) as it's the cleanest firmware install you can do, thanks for posting your experience, it could definitely help others! Miiiithraaks 1
DARKNESS Posted September 28, 2023 Posted September 28, 2023 I tried TFTP and all you get are timeouts even if you time when the light turns orange and see the light indicate that Ethernet is active that didn't work for me and I tried nmrpflash but all I get is no such file directory even though it in there unless I am smoking crack at this point might have to do it on a windows since mac doesn't seem to be the simplest way to do this and there barely any info out there doing it on mac. Unless someone understands what am doing incorrectly here would be appreciated
Administrators Netduma Fraser Posted September 29, 2023 Administrators Posted September 29, 2023 14 hours ago, DARKNESS said: I tried TFTP and all you get are timeouts even if you time when the light turns orange and see the light indicate that Ethernet is active that didn't work for me and I tried nmrpflash but all I get is no such file directory even though it in there unless I am smoking crack at this point might have to do it on a windows since mac doesn't seem to be the simplest way to do this and there barely any info out there doing it on mac. Unless someone understands what am doing incorrectly here would be appreciated Might be the \ you put after nmrpflash
DARKNESS Posted September 29, 2023 Posted September 29, 2023 @Netduma FraserTried that didn't work either the only thing that works is the full file input without cd
Administrators Netduma Fraser Posted September 29, 2023 Administrators Posted September 29, 2023 You might be able to run a terminal from the actual folder, I haven't used a mac in awhile so a little hazy on the details
DARKNESS Posted September 29, 2023 Posted September 29, 2023 @Netduma FraserYeah I tried that I just get a prompt with the details and can't prompt anything
Administrators Netduma Fraser Posted September 29, 2023 Administrators Posted September 29, 2023 2 minutes ago, DARKNESS said: @Netduma FraserYeah I tried that I just get a prompt with the details and can't prompt anything You may need to do a terminal using sudo/run as administrator
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Definitely run as admin like Fraser says. I did mine on Windows but I think I got stuck at the same spot for a min. I think I was trying to run the nmrpflash app and then somehow enter the command from in that screen. Im pretty sure I ended up just running the command like this in a powershell from the directory nmrpflash is located is in. ".\nmrpflash -i net22 -f XR1000-V1.0.0.68_1.0.54.chk" without quotes and it did the trick. Its been over a month now so my recall is a little hazy. I just remember having a very similar problem trying to launch it. Netduma Fraser 1
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Is there a directory named nmrpflash or is it the file just in the downloads? What do you see if you cd to the downloads folder and run a directory listing?
DARKNESS Posted September 29, 2023 Posted September 29, 2023 @MiiiithraaksYeah it just in downloads as for the directory it doesn't contain a folder I just added into a folder and same occurs as for running a directory listing how would you do that?
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Im not great with Macs\linux honestly but I believe the command to list is ls. I know once you can get into that directory with the file, it should work. Im just not sure why its saying directory not found. Could you try to do just "cd downloads" and see if that puts you into the downloads folder? Then do the "ls" command if youre able.
KinGzzy Posted September 29, 2023 Posted September 29, 2023 Most Netgear supports nmrp recovery, this is a simple way to return to stock. TFTP recovery is very similar in that it works from the bootloader of the router, before the OS even boots, so it will not matter what OS is installed or if that OS is able to boot. TFTP recovery should be activated by holding down the reset button while turning the power on and keep holding the button until the power LED flashes orange. NMRP if supported will load when the router is turned on without pressing any buttons, when the PC is running an NMRP server. I did it on an Xr500 a while ago and it worked "for me"
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Perfect, now try the command nmrpflash -L Does that return your network adapters?
DARKNESS Posted September 29, 2023 Posted September 29, 2023 @MiiiithraaksNope just say command not found
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Does "open nmrpflash -L" do anything different?
Miiiithraaks Posted September 29, 2023 Author Posted September 29, 2023 Aggh, that sucks. I wish my mac knowledge was better. Youre almost there, Im just not sure how to get the command to run on a mac.
DARKNESS Posted September 29, 2023 Posted September 29, 2023 I have tried the tfftp method though all I get is timeouts
DARKNESS Posted September 29, 2023 Posted September 29, 2023 @MiiiithraaksNo big deal is this one of the issues of using operating systems that not many users use like linux I feel bad for those users 😂
