Netduma R2 Connection Benchmark App Issue | Significant Reduction of Speed
Sameer
On 8/22/2022 at 12:01 AM, Netduma Fraser said:
Disable port scan and syn flood protection in WAN Settings then re-test please and see if you get any higher
As requested, I turned off both Port Scan Protection and Sync Flood Protection off.
The speeds never reached upto 800Down.
22 hours ago, Netduma Fraser said:
Disable IPv6 in WAN/LAN as well please, what do you get then?
I did just as you asked, I didnt see any improvements on the speed.
I think it is very likely that this is the maximum speeds you'll be able to get through the R2 on your connection. There aren't any other settings that impact speed that could be adjusted and given you tried it with the PC in the DMZ so ALL traffic went to the PC basically unimpeded and it didn't get you any higher then I don't think it will be possible to get any higher unfortunately.
Thank u for the information!
Is it a one off incident? Have you tested urself in your lab?
A few people max out around the same as you. In a lab environment we have achieved 900-950Mbps max but every household is different so some can achieve that and others achieve around your level of speeds.
is there a possibility to exchange one that can achieve +950 with mine? I dnt mind If i could exchange mine for 2nd hand R2 if you have lying around.
It's not a case of one R2 performs better than the other, it's to do with the network environment that it is within that impacts the speeds it can achieve
