Duma interface won’t work with safari
Hi I’ve been having issues with my safari not loading the xr1000 gaming router page. Is there any reason why?
Have you tried clearing the browser cache then trying to log in again?
9 hours ago, Exe_uz said:
Does it work with chrome or firefox?
Chrome is a good choice, will work well. Should also work on Firefox so it depends on which you like most.
As above, chrome is an excellent choice on mac. Safari does not play nice with dumaOS as I can recreate on my pc the possible error you are getting. I also ran into an issue where I couldnt even get the page to load at all unless i used http as it defaults to https which is a secure connection.
As above, believe it is due to the new Safari upgrade that forces all connections to be HTTPS if they're HTTP. So would be advised to use a different browser at this time.
Does the 1.0.0.58 update work properly yet? I’m still on 52 because it wasn’t acting right with my router.
It works nicely with most browsers, which issues were you having exactly?
18 hours ago, Doughboy said:
The same issue I use safari it just shows spinning wheels on all the rapps
How are you accessing the interface? Via routerlogin.net or 192.168.1.1?
I’m using chrome on my Mac and I updated the router to .58. It’s still showing a spinning wheel. Or it says the rapps are taking too long I don’t know what to do now. Should I scrap the router now? Because it was doing it with the past update now this one. I also cleared the cache on chrome as well
Are you using the IP to access? Make sure you're connecting using http so http://192.168.1.1
Reboot the router from the interface, wait 2 minutes then access and it should load correctly. No need to scrap the router, it can and will be fixed.
That 192.168.1.1 access won’t come up only 10.0.0.1 will work. And that’s on chrome
Okay that's fine so make sure to always type in http://10.0.0.1 when trying to access and with my last suggestion see if it works better
The geofilter and ping heat map still won’t come up it says this rap is not loaded yet please try again in a min
I'd recommend reinstalling the firmware using the TFTP method: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP that will upgrade the firmware bypassing the boot process and any issues there. Then you can do a factory reset after that for the freshest install possible. As your issue seems to persist after a reset/reboot the issue may very well be in the boot process.
