slugg Posted May 10, 2021 Posted May 10, 2021 Summary: Shots 1-5: Clearly missed. Shots 6-9: Missed due to recoil (bad spray control). Shots 10-11: Very close, but recoil and inaccuracy make these reasonable misses. Shot 12: Likely didn't actually fire because you were already dead.
TODDzillaInLA Posted May 13, 2021 Posted May 13, 2021 i use to play at 1080p 120hz, i changed to 1440 120 and it was a huge game changer for me
N3CR0 Posted May 13, 2021 Posted May 13, 2021 43 minutes ago, TODDzillaInLA said: i use to play at 1080p 120hz, i changed to 1440 120 and it was a huge game changer for me You get more fps from 1440?
TODDzillaInLA Posted May 13, 2021 Posted May 13, 2021 no you dont but the view area is better, it depends on what size monitor your playing on if you even are playing on a monitor or tv i have a 27" 240hz so 1440 ended up being the best change for me, i was always told and read 1080p with the highest refresh rate and higher frames is better, but if your on a 27" inch or bigger 1080 is going to handicap you i would watch all the big streamers and noticed their game looked different from mine, then one day i donated some $ to iron and asked him about his display settings and he has like a 5 min conversation about how 1440 was king. i tried it and he was 100% correct
N3CR0 Posted May 13, 2021 Posted May 13, 2021 8 minutes ago, TODDzillaInLA said: no Thats why I asked. Surely it'd give you the same or a little less. I've been playing on 1440p for months on my Xbox One X since CoD only runs @ 30fps with 4k. Would much rather play on my laptop, was getting 100-110fps average in 1080p on my 17ins 144hz screen but since the game ignores my QoS rules, the connections trash so no point in playing.
N3CR0 Posted May 13, 2021 Posted May 13, 2021 32 minutes ago, ONEovFOUR said: i switched to monitors couple years back i just bought a ACER NITRO only couple hundred 24 inch omg the picture on new gen xbox is so good Nice. I've been using a Asus VP28UQG for the last couple of years.
TODDzillaInLA Posted May 13, 2021 Posted May 13, 2021 for my series x i use the samsung odyssey g7 and for my stream pc i use the ASUS ROG Strix XG27AQ 27" ps5 or series @120hz console still frame locked at 60fps but it looks alot nicer
adam01625 Posted May 14, 2021 Posted May 14, 2021 14 hours ago, TODDzillaInLA said: for my series x i use the samsung odyssey g7 and for my stream pc i use the ASUS ROG Strix XG27AQ 27" ps5 or series @120hz console still frame locked at 60fps but it looks alot nicer I thought warzone was 120fps on series x now?
zman1156 Posted May 15, 2021 Posted May 15, 2021 by his movements and the outcome of the gunfight id say that he was a pc player. having 1gbps is overkill for console imho i dont even think consoles can utilize alll of that but i could be wrong
TODDzillaInLA Posted May 15, 2021 Posted May 15, 2021 23 hours ago, adam01625 said: I thought warzone was 120fps on series x now? All new series consoles 120hz frame locked at 60fps, 60hz frame locked at 30fps
adam01625 Posted May 15, 2021 Posted May 15, 2021 5 hours ago, TODDzillaInLA said: All new series consoles 120hz frame locked at 60fps, 60hz frame locked at 30fps Ah right I see, is the FPS uncapped in PC?
N3CR0 Posted May 15, 2021 Posted May 15, 2021 2 hours ago, adam01625 said: Ah right I see, is the FPS uncapped in PC? Unless you set it in game or by some other means, on PC its uncapped... Having said that, the lobby menu I've heard is capped... I believe this is true as on PC Warzone I get 50-60fps on the lobby menu but 110fps+ in a match.
TODDzillaInLA Posted May 17, 2021 Posted May 17, 2021 On 5/15/2021 at 8:33 AM, adam01625 said: Ah right I see, is the FPS uncapped in PC? why alot of these streamers at 200+ fps looking like they on dead silence 24/7 lol
