Newfoundland Posted October 11, 2020 Posted October 11, 2020 If you can’t remember your password or never made a note you will need to factory reset. It’s then a good idea to make a note of your credentials so that you don’t forget. Look at the bottom of your router, if you never changed your WiFi credentials then it will be the one you see there.
Guest Killhippie Posted October 11, 2020 Posted October 11, 2020 Did you change your Wi-Fi password and admin? If not type in admin and the password on the bottom of the router making sure its in English not Polish. As I don't think the router has a polish language file by default.
Max Posted October 11, 2020 Author Posted October 11, 2020 Everything it’s in English 😂and I did not change the password if I can’t login i will restart r2
Administrators Netduma Fraser Posted October 11, 2020 Administrators Posted October 11, 2020 I don't think it would have let you continue the wizard without entering anything. Hold the reset button in the back of the router for 30 seconds then wait a minute and go through the wizard again. With the Google Translate extension for the web browser you can translate it as you see it.
Guest Killhippie Posted October 12, 2020 Posted October 12, 2020 17 hours ago, Max said: Everything it’s in English 😂and I did not change the password if I can’t login i will restart r2 Are you doing all this via a PC or you phone/Tablet? The R2 doesn't really like mobiles so maybe try the Netduma App on the Android and iOS store. I would try to reset and login via a PC top start with though.
Max Posted October 12, 2020 Author Posted October 12, 2020 Guys all done 💪 I restart The r2 setup again on laptop and everything it’s working fine so far thanks a lot for support 👊 Any tips with advanced setting r2 for call of duty gaming?
Administrators Netduma Fraser Posted October 13, 2020 Administrators Posted October 13, 2020 14 hours ago, Max said: Guys all done 💪 I restart The r2 setup again on laptop and everything it’s working fine so far thanks a lot for support 👊 Any tips with advanced setting r2 for call of duty gaming? Glad to hear it. Use Congestion Control in Always mode, try a percentage then do a benchmark test, rinse repeat until you find a percentage that lowers the Ping Under Load test as much as possible. Use Ping Heatmap to identify the closest/low ping servers to you and then adjust your Geo-Filter settings to force them.
Max Posted October 13, 2020 Author Posted October 13, 2020 It happened again after rebooting the r2 I was ask to put username and password but After clearing the cache from browser I login no problem 😁 do I have to save something somewhere? and my 2 question is I reduced download and upload to 50/50 but when I’m doing connection test on benchmark I’m getting full speed of my broadband is that normal? but broadband on other devices is reduced
Administrators Netduma Fraser Posted October 13, 2020 Administrators Posted October 13, 2020 It will ask you to login from time to time that is normal. Congestion Control doesn't affect the speed part of benchmark, just the Ping Under Load section.
Administrators Netduma Fraser Posted October 14, 2020 Administrators Posted October 14, 2020 Go to Settings, DHCP and reserve an IP for it.
Max Posted October 14, 2020 Author Posted October 14, 2020 Is this the right place and numbers maybe I’m trying copy som of them from r1
Max Posted October 14, 2020 Author Posted October 14, 2020 Sorry I think that should be here can i do this for my 3 Ps4 ? sorry for silly questions 🥴
Administrators Netduma Fraser Posted October 14, 2020 Administrators Posted October 14, 2020 First picture is wrong as you're aware, if you apply that you'll likely be disconnected from the internet. 2nd picture is correct yes and you can do it for all the devices. Would recommend you give them the IP they already have so check the device manager to see what they have.
Administrators Netduma Fraser Posted October 14, 2020 Administrators Posted October 14, 2020 Did you click on anything when that occurred? Are you on the Geo-Filter page?
Max Posted October 14, 2020 Author Posted October 14, 2020 It was on geofilter rebut the r2 going well now but I have access to r2 only by pc using the app or phone I can’t login to r2 🥴
Max Posted October 15, 2020 Author Posted October 15, 2020 Still can’t login to r2 using app or google chrome on my phone any suggestions guys?
Newfoundland Posted October 15, 2020 Posted October 15, 2020 Do your WiFi devices work ok? double check you are entering the correct credentials.
Max Posted October 15, 2020 Author Posted October 15, 2020 Yes everything is working password it’s ok
Max Posted October 15, 2020 Author Posted October 15, 2020 But I can’t login to r2 with app or chrome on my phone I have to use pc and login every time as well
Administrators Netduma Fraser Posted October 16, 2020 Administrators Posted October 16, 2020 What happens when you try to access using the app on your phone?
Max Posted October 16, 2020 Author Posted October 16, 2020 On the phone keep asking me for username and password can’t get in and every time I login to pc asking me for username and password to something it’s not save
