Does pppoe work on r2?
Victor-Yout
26 minutes ago, Netduma Fraser said:
Let us know how you get on with it if you decide to purchase.
Yes i will do that. Is it even better to connect the r2 via pppoe rather than dhcp to the modem?
If you have the option I would suggest you still have the hub handling PPPoE and have the R2 connected to it using DHCP. That's just my personal opinion, you could have the R2 handle PPPoE if you wanted to and shouldn't see any issues.
I configured my R2 with PPPoE but I have big speed drop.  I pay for 1000 and I got only 300, but in DHCP, I got more than 850, sometime 950 ! I did it ( PPPoE ) because I was not able to get open Nat in DHCP, but for some reason, actually I can get open nat in DHCP since the FW .123 I run DHCP
I get my full speeds using pppoe, but i noticed a bug that when i am using it, the dowload slider in CC doesnt work anymore and is always at 100%
Is it stuck on 100% and you can’t alter it or do you notice this after you leave the settings then return to them?
I can move the slider around but it hasnt an effect
So if you have 100Mbps for example and set the download slider to 50% and do a speed test then download won't be affected but upload would?
exactly, download would still be at 100 mbps
Great thank you. Would you be able to produce a small video showing that you're connected to PPPoE, showing that QoS isn't disabled fully and change your QoS settings and then doing a speed test where it doesn't throttle please? Then I can confirm it's definitely a bug and pass it on to the developers. Could you also do it using the Chrome browser?
sorry forgot about chrome, but i made the process with chrome with the same outcome
R2pppoe.mov
That's great thanks a lot, I'll pass this straight onto the devs.
Hi Victor, the developers have asked if you could check using the R1 handling PPPoE if you see the same behaviour with the R1 not throttling bandwidth.
Hi Fraser, just tested it with the exact same result
I have this problem too. No matter what speed i set for download or upload i get full speed for both with no throttling.
I'm also on pppoe.
Also how do the rapps update? i have 5 apps ready to update and qos is one of them.
I'm also on pppoe.
Just to double check, have you disabled QoS completely in the Congestion Control 3 line option menu? At the moment we're doing updates via firmware so that will come later.
Draytek vigor 130 modem and the r2 set to pppoe as the vigor is the uk version thats just a modem. yes speedtest.net.
Thanks for that, one final thing before I pass over to the devs, could you provide a screenshot of the QoS page please?
Just installed DumaOS-R2-RC5-Production-3.0.129-100820 from off here with no reset and its working great.
Ah okay great, that's excellent. Let us know if you encounter it again!
@Victor-Yout Could you try this as well?
https://www.dropbox.com/s/vklzjkftpdcd01t/DumaOS-R2-RC5-Production-3.0.129-100820.sig?dl=0
To update: Download the file above, open DumaOS, click the three dots in the top right corner, choose update, upload the file you just downloaded, and wait a few minutes while the R2 restarts.
