theseus33 Posted November 14, 2019 Share Posted November 14, 2019 i have cox communications for ISP. they use a panoramic modem. i have my netduma wired to the modem, then my ps4 wired to the netduma. cox will not allow me to use the proper ports for call of duty, nor will they allow me to set up a dmz...due to security concerns. my nat type is moderate constantly. any suggestions on how i can attain an open nat? Link to comment Share on other sites More sharing options...
BIG__DOG Posted November 14, 2019 Share Posted November 14, 2019 Hi. Most of the ISP's in your country allow you to use your own modem and stop using theirs, this would stop these restrictions as the ports are being blocked by their issued modem. I am not sure if COX allows this, but I am almost certain they do. I suggest you go to amazon and buy a good quality modem that is compatible with your isp and swap them over. If this fails you can returm your modem to amazon for a full refund. If this works then you can return your coz modem and cancel any extra charge they put on your bill for hiring their equipment. Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Jack Posted November 14, 2019 Netduma Staff Share Posted November 14, 2019 11 hours ago, theseus33 said: i have cox communications for ISP. they use a panoramic modem. i have my netduma wired to the modem, then my ps4 wired to the netduma. cox will not allow me to use the proper ports for call of duty, nor will they allow me to set up a dmz...due to security concerns. my nat type is moderate constantly. any suggestions on how i can attain an open nat? Big Dog is absolutely right above - the restrictions should be limited to the modem they've provided, so a new modem should bypass their stupid restrictions and allow you to get an open NAT. Let us know if that works out! Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 i went and picked up a netgear nighthawk ac1900 c7000 modem at bestbuy. after initial set up and plug in, im now at strict NAT. trying to figure out how to forward ports, and or put the netduma in a dmz...and how to do that. its quite the mess for illiterates such as myself. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 14, 2019 Administrators Share Posted November 14, 2019 19 minutes ago, theseus33 said: i went and picked up a netgear nighthawk ac1900 c7000 modem at bestbuy. after initial set up and plug in, im now at strict NAT. trying to figure out how to forward ports, and or put the netduma in a dmz...and how to do that. its quite the mess for illiterates such as myself. Take the WAN IP from the R1 Device Manager (Original Firmware) or System Information (DumaOS) and put that into the Nighthawk DMZ which is in WAN Settings. Once you've done that if you're still having trouble you can follow this guide: http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 netduma is placed in dmz upnp is enabled on both the netduma and the nighthawk ports are entered on the modem with net duma wan ip what am i missing? cause im still strict Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 46 minutes ago, Netduma Fraser said: Take the WAN IP from the R1 Device Manager (Original Firmware) or System Information (DumaOS) and put that into the Nighthawk DMZ which is in WAN Settings. Once you've done that if you're still having trouble you can follow this guide: http://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat netduma is placed in dmz upnp is enabled on both the netduma and the nighthawk ports are entered on the modem with net duma wan ip what am i missing? cause im still strict Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 14, 2019 Administrators Share Posted November 14, 2019 What do you mean by ports are entered on the modem? You don't need to forward ports on it because the DMZ covers that. Are you just using UPnP on the R1 or have you used port forwarding as well? Where is it strict, in the console network settings or on the game itself? Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 4 minutes ago, Netduma Fraser said: What do you mean by ports are entered on the modem? You don't need to forward ports on it because the DMZ covers that. Are you just using UPnP on the R1 or have you used port forwarding as well? Where is it strict, in the console network settings or on the game itself? At the moment, upnp is enabled on both the netduma and the nighthawk. The strict NAT is on the ps4 console. Which is hard wired to the netduma. Ive taken the port forwarding out. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 14, 2019 Administrators Share Posted November 14, 2019 53 minutes ago, theseus33 said: At the moment, upnp is enabled on both the netduma and the nighthawk. The strict NAT is on the ps4 console. Which is hard wired to the netduma. Ive taken the port forwarding out. What NAT Type does it say the console has 2 or 3? Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 33 minutes ago, Netduma Fraser said: What NAT Type does it say the console has 2 or 3? type 3. i have 3 consoles wired to my netduma. with the cox modem, i was getting type 2, which i know is fine for playing, but wasnt able to host. have to be able to host matches. i get this new modem, and now its type 3. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 14, 2019 Administrators Share Posted November 14, 2019 Type 2 is an Open NAT so if you couldn't host it was probably because you were blocking people with the Geo-Filter. So your setup now is the Nighthawk modem > R1 correct? No other router/modems connected? Disable UPnP on the Nighthawk, I would also have a look to see if you could switch it to modem or bridge mode. UPnP is ideal to use on the R1 with multiple consoles but it may be harder to get them all open. Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 4 minutes ago, Netduma Fraser said: Type 2 is an Open NAT so if you couldn't host it was probably because you were blocking people with the Geo-Filter. So your setup now is the Nighthawk modem > R1 correct? No other router/modems connected? Disable UPnP on the Nighthawk, I would also have a look to see if you could switch it to modem or bridge mode. UPnP is ideal to use on the R1 with multiple consoles but it may be harder to get them all open. Ive been told that type 2 was an open nat type. However, its shows moderate on the console, and would not allow me to connect with other players that have open nat types. I double checked the geo filter, and am fairly certain they are within range. I disabled the upnp on the nighthawk, and i am back at type 2 now. Which is helpful. So thank you. But if anyone has any ideas on how to get open, that would be great. Had an open nat on all three consoles for the previous title. Not sure what changed. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted November 14, 2019 Administrators Share Posted November 14, 2019 I'm not sure what you mean it's NAT Type 2 now which is great but where is it saying moderate, on the game? It's a good idea to add them to the allow list on the Geo-Filter anyway. If you disable the Geo-Filter can you connect with them? Also the Geo-Filter may just be causing the moderate reading but is actually open, if you disable it and then reload the game it may change. Link to comment Share on other sites More sharing options...
theseus33 Posted November 14, 2019 Author Share Posted November 14, 2019 14 minutes ago, Netduma Fraser said: I'm not sure what you mean it's NAT Type 2 now which is great but where is it saying moderate, on the game? It's a good idea to add them to the allow list on the Geo-Filter anyway. If you disable the Geo-Filter can you connect with them? Also the Geo-Filter may just be causing the moderate reading but is actually open, if you disable it and then reload the game it may change. Yes itbis moderate on the game. I will disable the geo filter and try that. Link to comment Share on other sites More sharing options...
theseus33 Posted November 15, 2019 Author Share Posted November 15, 2019 1 hour ago, Netduma Fraser said: I'm not sure what you mean it's NAT Type 2 now which is great but where is it saying moderate, on the game? It's a good idea to add them to the allow list on the Geo-Filter anyway. If you disable the Geo-Filter can you connect with them? Also the Geo-Filter may just be causing the moderate reading but is actually open, if you disable it and then reload the game it may change. Made no difference. Still moderate. Link to comment Share on other sites More sharing options...
theseus33 Posted November 15, 2019 Author Share Posted November 15, 2019 6 hours ago, Netduma Fraser said: Type 2 is an Open NAT so if you couldn't host it was probably because you were blocking people with the Geo-Filter. So your setup now is the Nighthawk modem > R1 correct? No other router/modems connected? Disable UPnP on the Nighthawk, I would also have a look to see if you could switch it to modem or bridge mode. UPnP is ideal to use on the R1 with multiple consoles but it may be harder to get them all open. I tried switching the nighthawk to bride mode, ad it just shut down connection for everything. No internet at all. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted November 15, 2019 Administrators Share Posted November 15, 2019 Well... Sounds to me like your ISP might not enable you to have a truly open NAT. Moderate is still pretty good though, at least it's not strict. Link to comment Share on other sites More sharing options...
theseus33 Posted November 15, 2019 Author Share Posted November 15, 2019 22 minutes ago, Netduma Alex said: Well... Sounds to me like your ISP might not enable you to have a truly open NAT. Moderate is still pretty good though, at least it's not strict. Goes back and forth from moderate to strict on the game. But the console still shows type 2. I have no idea. Tired of messing with it honestly. When i plug one console directly to the modem, its type 1 open nat on the game. Plug two in directly to the modem, its type 2, moderate on the game. All three, same thing. But when i add the netduma to the equation, everything goes to strict on the game. Geo filter, congestion throttle, and all other options aside, im starting to wonder if i should even use the r1. Ive had it a few years now. Suppose ive gotten my moneys worth out of it. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted November 15, 2019 Administrators Share Posted November 15, 2019 Hmm. There's definitely no DMZ function on your modem? Link to comment Share on other sites More sharing options...
theseus33 Posted November 15, 2019 Author Share Posted November 15, 2019 27 minutes ago, Netduma Alex said: Hmm. There's definitely no DMZ function on your modem? There is. I have the wan ip from the r1 in the dmz function. It is clicked to enabled. Upnp on the modem is disabled. Upnp on the r1 is enabled. That worked for a couple of hours last night. Game was on moderate. Flipped to strict at some point, and cant get it back to moderate now. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted November 15, 2019 Administrators Share Posted November 15, 2019 Could you set your R1's WAN IP as static? Go to Settings > WAN, and change DHCP to Static. Put the IP address in as the same WAN address you currently have, put the gateway address as whatever your modem's IP is (usually your R1's WAN IP but the last number is a 1) and subnet mask 255.255.255.0 Link to comment Share on other sites More sharing options...
theseus33 Posted November 15, 2019 Author Share Posted November 15, 2019 3 hours ago, Netduma Alex said: Could you set your R1's WAN IP as static? Go to Settings > WAN, and change DHCP to Static. Put the IP address in as the same WAN address you currently have, put the gateway address as whatever your modem's IP is (usually your R1's WAN IP but the last number is a 1) and subnet mask 255.255.255.0 I will do this sunday when i return home. Thank you. Ill keep you posted. Link to comment Share on other sites More sharing options...
theseus33 Posted November 18, 2019 Author Share Posted November 18, 2019 On 11/15/2019 at 10:46 AM, Netduma Alex said: Could you set your R1's WAN IP as static? Go to Settings > WAN, and change DHCP to Static. Put the IP address in as the same WAN address you currently have, put the gateway address as whatever your modem's IP is (usually your R1's WAN IP but the last number is a 1) and subnet mask 255.255.255.0 I gave this a shot last night, without any success. Ultimately, i ended up just plugging all three consoles directly to the modem. It was not a perfect fix, although the consoles now show open or moderate on the game. It goes back and forth. Having them wired thru the r1, it was mostly strict, and occasionally moderate. I have read on this site, and others, that this issue seemingly lies mostly with activision, and is not a problem with netduma at all. And i believe that. However, the netduma, at least in my case, seems to complicate matters. Not being able to use congestion control or geo filter is going to suck for sure. But without any way to resolve the issue, i dont have much of a choice. I sincerely appreciate the effort of everyone that has tried to help me the last week. Thank you very much. Perhaps in the future a fix will be found. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted November 19, 2019 Administrators Share Posted November 19, 2019 I'm sorry to hear it didn't work. I notice in my instructions I didn't say that you should set your DNS server to 8.8.8.8 and 8.8.4.4, the Static option will not work without something entered in the DNS server fields. Link to comment Share on other sites More sharing options...
