Netgear Nighthawk xr 500 geofilter does not work
  • Replies 127
Ok my Test finisch i Test a new Port it doesnt help look at the pinggrafh and my Ping it schuld be Smoth normally
The ping graph shows a flat 18ms that doesn't fluctuate, is there another picture you're referring to that isn't there?
The first one didn't have a ping, so I assume the ping panel was still loading on that one. What was the ping on that one showing?
Well everything in these screenshots looks good. You say in your game you're experiencing lag? Like characters are skipping around or just that bullets feel slow?
What does the game itself say that your ping is? In some games you can find this out in the pause menu.
The connection shown is spot on so nothing wrong there. I'd suggest either forcing different servers by adjusting the Geo-Filter home location/radius or adjusting your QoS settings if you think you may be experiencing local congestion.
what can i do on qos or what you mean with the geofilter conquestion how can i force a server?
You can force a server by changing your radius size so you block servers that would normally be in the radius and so forcing whatever is left in that range. You can also move your location to cover other areas that have servers and force them that way.
yes i try this but it looks like the game gives me everytime a server so the geofilter have no effect on this game
when i force a server that i want the game try to give me everytime a different server
If you're talking about lag between your controller and the game then no, but if you're talking about a 10ms connection to the server than i'd say that's about as good as you could possibly get.
Yeah i talking about Controller to Monitor lag the Input lag yes so i asked my Developer of my Monitor he seid to me my Input lag from my Controller to Monitor has 10 ms
