Administrators Netduma Alex Posted August 22, 2019 Administrators Posted August 22, 2019 Have you upgraded to .56 now?
Gamer Posted August 22, 2019 Author Posted August 22, 2019 Yes is Upgraded to the new Firmware and i do A Factory reset after This. But the issue with kicks me out in the middle off Game is the same as in the old Firmware.
Administrators Netduma Alex Posted August 22, 2019 Administrators Posted August 22, 2019 You might need to raise your ping assist even more.
Gamer Posted August 22, 2019 Author Posted August 22, 2019 ok i test it thank you for information but i hope the milestone 1.4 fix problems like this
Gamer Posted August 25, 2019 Author Posted August 25, 2019 ok i test it now with strenger mode on and ping Assit high up a bit and grapping land area 4000 km or 5000 an it throws me out in the middle of the game then i become this message your console lost the connection to the gameserver
Administrators Netduma Fraser Posted August 25, 2019 Administrators Posted August 25, 2019 I don't think the Geo-Filter is causing this issue at all if its happening in spectating mode. I assume you're wired to the console, have you got any other ethernet cables to try with? Also have you tried connecting the console to WiFi and seeing if that makes any difference?
Gamer Posted August 25, 2019 Author Posted August 25, 2019 No i Dont play With WiFi and i bought me a new Cat 8 Ethernet cable. Also my old Ethernet cable was cat 7 The cable is definetly Not the Problem. I have some more Other Ethernet cables And the issue are here with all Ethernet cable. And the Problem is when i Test this things In Spectating Mode it can be happen that the complete day all its normal . The connection lost to the GameServer is Not all the Time but it is still There
Gamer Posted August 25, 2019 Author Posted August 25, 2019 Do you know What i mean a Test can be taken the completely day. In Spectating Mode.
Gamer Posted August 25, 2019 Author Posted August 25, 2019 Also Alex told me that you guys talking about the Milestone 1.4 in the Forum this week ?
Gamer Posted August 25, 2019 Author Posted August 25, 2019 Ok i Test it in Spectating Mode und then i give you a Feedback
Administrators Netduma Fraser Posted August 25, 2019 Administrators Posted August 25, 2019 Please also test in WiFi, I know it's not ideal but it could be a port issue - either with the router or the console and WiFi would rule that out. Also switch the port the ethernet cable is in and try as well. Yes we will be giving news on that this week!
Gamer Posted August 25, 2019 Author Posted August 25, 2019 Ok i tested with WiFi thank you for the Information.
Administrators Netduma Fraser Posted August 25, 2019 Administrators Posted August 25, 2019 Did that work?
Gamer Posted August 25, 2019 Author Posted August 25, 2019 I Dont know it is Not often that it kicks me out of the Game i Test this for 2 days for optimal News.
Administrators Netduma Fraser Posted August 25, 2019 Administrators Posted August 25, 2019 Okay keep us posted!
Gamer Posted September 4, 2019 Author Posted September 4, 2019 Hello Fraser i tested on WiFi and it does Not happen kicks me out in the middle of a Game but now Islay about 3 days with cable and it kicks me Not out of the Game maybie i need a Port?
Gamer Posted September 4, 2019 Author Posted September 4, 2019 And i have another Problem my Gameplays are Not Smoth i play only on Eu Server the highest Ping that i get is about 30 ms Ping. About 18ms Ping is about the closest Server to me. When i Show on the pinggrafh and it Show me 18 ms ping that means the Gameplay have to be very Smoth. But it feels Not like 18 ms ping more like 70-80 Ping. Can you help me to find the Problem i think Something is Not normal.
Administrators Netduma Fraser Posted September 4, 2019 Administrators Posted September 4, 2019 Did you also try it connected to a different ethernet port on the router? Doesn't happen when using ISP router either? That's a really good ping, does it spike at all when you're playing?
Gamer Posted September 4, 2019 Author Posted September 4, 2019 With my isp router the connection is bad with xr 500 much better but also when i got 18 or 25 ping i dont understand why its not smoth. yes i try it on a different port but do you realy think 1 port is deffekt its a new router since the new update comes out i dont try a different port.
Gamer Posted September 4, 2019 Author Posted September 4, 2019 ok i test it now with a new ethernet port
Gamer Posted September 4, 2019 Author Posted September 4, 2019 I need only 10 min then im back to the Forum i do 1 Game and look this helps or Not.
