Network Map and Network Monitor do not work properly
20 minutes ago, jdmefsir said:
yea i did a facotry restore and it worked for about an hour or two and now its back to not working. Also the geo filterbasically doesnt work because the device shows offline even though its hardline and im on it right now also
That's about how long mine lasts now..
Thanks for all the info guys. We are investigating. Just to double check - your issue goes away if you downgrade back to the previous firmware (.32)? It's helpful for us to know for sure as we / NETGEAR can then isolate the likely causes.
I have tested .32 and it works. Firmware .40 seems to have the issue. Thank you!
This is very helpful to know, thanks. We've shared it with the devs.
  • 2 months later...
