FQs19 Posted October 27, 2018 Author Posted October 27, 2018 Update on my issues: - Received my replacement XR700 - Zero issues on this one after updating and Factory Resetting. Speed test during setup worked. No funny gui issues or slow loading. No lan or wifi disconnections. - I still have not seen the internal fan run, though this router isn't as hot as my first one. - The only odd thing I can see is my logs are filling up with this: - I ran Pingplotter over night on it, pinging the router from a pc connected to it. I haven't found the right QoS settings for my network yet, but this is with 1000mb bandwidth, sliders at 70%, and minimal traffic like app updating starting around 930pm (as you can see, No Packet Loss): - I will be contacting Netgear next week and say this replacement is working perfectly so far. Looking forward to Milestone 1.3!
Administrators Netduma Admin Posted October 27, 2018 Administrators Posted October 27, 2018 Thanks for the update. Great to hear things are improved. Ignore those logs - they're just for developers and a future firmware will clear that particular log from appearing so frequently. Is the temperature better now?
FQs19 Posted October 27, 2018 Author Posted October 27, 2018 Just now, Netduma Admin said: Thanks for the update. Great to hear things are improved. Ignore those logs - they're just for developers and a future firmware will clear that particular log from appearing so frequently. Is the temperature better now? Okay. Good to know. Yes, temps are fine. Hopefully Netgear will get back to me on when the internal fan will turn on and you guys could add the temp. indications in a future firmware so we can monitor them.
FQs19 Posted November 14, 2018 Author Posted November 14, 2018 Finally got a day off to troubleshoot this router some more with Level 2 Netgear Support. First they had me install the newest firmware, 1.0.1.2. Then I had to factory reset the router. Then they had me go to the Debug Page, enable the LAN/WAN packet capture, then Start Capture. I ran like that for almost two days while running Ping Plotter to Verizon.com which showed a whole bunch of packet loss on a wired connection. I wasn't able to see if my wan connection dropped because the logs filled up with non-important stuff and just kept getting cleared out. I saved the debug log and sent it to them along with the Ping Plotter .pp2 file for their review. This is what ping plotter captured on my pc wired to the XR700 behind my Verizon Fios G1100: After they received my logs, they used TeamViewer to copy down my network diagnostics, both wireless and wired, from my Macbook Pro. Then they had me change the XR700 MTU to 1400 from the default of 1500 which i've been using forever with broadband internet. They want me to see if changing the MTU stops the disconnections and packet loss from happening. All of this info is being sent up to their next level of support. Unfortunately, my 30 day return period is approaching, so I must return it. I can't use a router with this many problems even if Netgear is willing to work with me on troubleshooting it. I don't have the time to be their beta tester. I'll update this thread if Netgear responds with anything of value. XR700 with 1.0.1.2 firmware verizon.com.pp2
Administrators Netduma Admin Posted November 14, 2018 Administrators Posted November 14, 2018 47 minutes ago, FQs19 said: Finally got a day off to troubleshoot this router some more with Level 2 Netgear Support. First they had me install the newest firmware, 1.0.1.2. Then I had to factory reset the router. Then they had me go to the Debug Page, enable the LAN/WAN packet capture, then Start Capture. I ran like that for almost two days while running Ping Plotter to Verizon.com which showed a whole bunch of packet loss on a wired connection. I wasn't able to see if my wan connection dropped because the logs filled up with non-important stuff and just kept getting cleared out. I saved the debug log and sent it to them along with the Ping Plotter .pp2 file for their review. This is what ping plotter captured on my pc wired to the XR700 behind my Verizon Fios G1100: After they received my logs, they used TeamViewer to copy down my network diagnostics, both wireless and wired, from my Macbook Pro. Then they had me change the XR700 MTU to 1400 from the default of 1500 which i've been using forever with broadband internet. They want me to see if changing the MTU stops the disconnections and packet loss from happening. All of this info is being sent up to their next level of support. Unfortunately, my 30 day return period is approaching, so I must return it. I can't use a router with this many problems even if Netgear is willing to work with me on troubleshooting it. I don't have the time to be their beta tester. I'll update this thread if Netgear responds with anything of value. XR700 with 1.0.1.2 firmware verizon.com.pp2 Thanks for the update. I'd recommend letting NETGEAR know about the return limit approaching. They might be able to arrange something for you.
FQs19 Posted November 14, 2018 Author Posted November 14, 2018 7 minutes ago, Netduma Admin said: Thanks for the update. I'd recommend letting NETGEAR know about the return limit approaching. They might be able to arrange something for you. They know about the return window. They also know my current xr700 is a replacement for the first one which had the same issues. Working 12hr shifts for 10 days in a row isn't helping our communication. Which is why the return window is closing before they can get a clear picture of what's happening.
Administrators Netduma Admin Posted November 14, 2018 Administrators Posted November 14, 2018 23 minutes ago, FQs19 said: They know about the return window. They also know my current xr700 is a replacement for the first one which had the same issues. Working 12hr shifts for 10 days in a row isn't helping our communication. Which is why the return window is closing before they can get a clear picture of what's happening. Ok, thanks for the update.
FQs19 Posted November 18, 2018 Author Posted November 18, 2018 Netgear finally sent me a request to sign up for a Beta they have for the XR700. They say it fixes some of my issues. Not sure what 'issues' they think they've fixed. Unfortunately, My 30 day return is up tomorrow and I can not allow myself to Beta test a $500 router, so I'm returning the router without trying their beta. I've asked them to clarify what the beta supposedly fixes, but if you guys could get in touch with Netgear and post something about what they think the problem was and how they fixed it, I would purchase the XR700 in the future. I am in agreement with a bunch of users who think Netduma should release their DumaOS on another Mikrotik product or even design your own router. Hopefully one that incorporates all the specs and hardware of a 2018/19 router would/should.
Administrators Netduma Fraser Posted November 18, 2018 Administrators Posted November 18, 2018 Sorry to hear that, it's probably to fix the disconnect issues as well as the Geo-Filter error message. We'll try to keep you posted on it's status so you can consider purchasing again in future.
Muyfa666 Posted December 20, 2018 Posted December 20, 2018 Hey fellas. I was looking to get the XR700, but the internal fan turned me off. Does it run alot and does it run loud?
Administrators Netduma Fraser Posted December 20, 2018 Administrators Posted December 20, 2018 9 minutes ago, Muyfa666 said: Hey fellas. I was looking to get the XR700, but the internal fan turned me off. Does it run alot and does it run loud? Hey, welcome to the forum! In my experience it will only turn on when there is VERY heavy usage so it's unlikely that for every day usage that it will be on. I also don't think it's very loud. You are also able to edit the fan speed via a special page to slow it down if you did find it to be too loud which is very unlikely anyway
FQs19 Posted December 20, 2018 Author Posted December 20, 2018 44 minutes ago, Muyfa666 said: Hey fellas. I was looking to get the XR700, but the internal fan turned me off. Does it run alot and does it run loud? In the month that I had the XR700, the internal fan never ran. You can also open http://routerlogin.net/debug.htm and adjust when the fan will turn on.
Muyfa666 Posted December 20, 2018 Posted December 20, 2018 Thanks for the fast responses and thanks for the warm welcome. 🙂 I just got the XR500 and are very happy with it. No complaints at all really. What would be the real life benefits in upgrading to XR700? Money is not really an issue - just want the best possible consumer grade network.
FQs19 Posted December 20, 2018 Author Posted December 20, 2018 1 minute ago, Muyfa666 said: Thanks for the fast responses and thanks for the warm welcome. 🙂 I just got the XR500 and are very happy with it. No complaints at all really. What would be the real life benefits in upgrading to XR700? Money is not really an issue - just want the best possible consumer grade network. More powerful CPU, Plex Server, and SFP+ port.
Muyfa666 Posted December 20, 2018 Posted December 20, 2018 Except for more powerful CPU, I don't use Plex and have no idea what SFP+ port is. Guess XR500 will do. Does XR700 possibly have longer range etc?
FQs19 Posted December 20, 2018 Author Posted December 20, 2018 24 minutes ago, Muyfa666 said: Except for more powerful CPU, I don't use Plex and have no idea what SFP+ port is. Guess XR500 will do. Does XR700 possibly have longer range etc? I believe it has the same wifi chip. So no.
Muyfa666 Posted December 21, 2018 Posted December 21, 2018 5 hours ago, FQs19 said: I believe it has the same wifi chip. So no. Thanks alot. Then I see no reason not to keep the XR500. 🙂
Netduma Staff Netduma Jack Posted December 21, 2018 Netduma Staff Posted December 21, 2018 8 hours ago, Muyfa666 said: Thanks alot. Then I see no reason not to keep the XR500. 🙂 I'm glad you're having a good time with your XR500 welcome to the forum!
Muyfa666 Posted December 23, 2018 Posted December 23, 2018 On 12/21/2018 at 1:55 PM, Netduma Jack said: I'm glad you're having a good time with your XR500 welcome to the forum! So far I really like it. Good work with the OS. Really nice.
Administrators Netduma Admin Posted December 24, 2018 Administrators Posted December 24, 2018 Thank you! Great to hear you’re enjoying it.
