Netduma Staff Netduma Crossy Posted June 22, 2015 Netduma Staff Posted June 22, 2015 Could you try plugging the PC into a different port on the Netduma?
iAmMoDBoX Posted June 23, 2015 Posted June 23, 2015 Ok I manually reset the duma and followed your instructions to a t plus disabled deep packet and work around. No change. Changed to original cable from modem to the duma, reboot and different server, no change (using firmware 1.03.4). Results are as follows: Duma: Modem: Try a different port on the R1?
Zennon Posted June 23, 2015 Posted June 23, 2015 If the congestion control sliders are at 100% , can you slide them down and then back to 100% on each slider just incase there is a glitch and it has not registered. And double check the speeds in the set bandwidth section are correct.
Administrators Netduma Fraser Posted June 23, 2015 Administrators Posted June 23, 2015 Please try these recent suggestions and if they don't work I'll try and do a 1 on 1 today.
Administrators Netduma Iain Posted June 23, 2015 Administrators Posted June 23, 2015 Hi Twisted Entropy, That upload is slow low that even the bottleneck features can handle it. So I'm almost certain it is therefore an IPv6 issue. As others have mentioned make sure you have the following: "Settings > LAN" - Disable IPv6. Then click apply "Settings > WAN" - Disable IPv6. Then click apply "Settings > Misc" - Disable linklocal IPv6 After doing that do the following in order: Turn off the modem & the router Wait 10 seconds Turn on the modem Wait 30 seconds Turn on the Netduma Wait 2 mins Via a wire on a PC/Mac (not a console/phone/tablet) do a speedtest Thanks
Twisted Entropy Posted June 23, 2015 Author Posted June 23, 2015 Here is results to the above referenced instructions:
Twisted Entropy Posted June 23, 2015 Author Posted June 23, 2015 If the congestion control sliders are at 100% , can you slide them down and then back to 100% on each slider just incase there is a glitch and it has not registered. And double check the speeds in the set bandwidth section are correct. Done also
Administrators Netduma Iain Posted June 23, 2015 Administrators Posted June 23, 2015 In congestion control make sure "tick excess" is enabled and then click reset distribution. Then rerun the test please.
Twisted Entropy Posted June 23, 2015 Author Posted June 23, 2015 Yes share excess is ticked. Results: still not it.
Administrators Netduma Fraser Posted June 23, 2015 Administrators Posted June 23, 2015 Twisted I can try and schedule a 1 on 1 with you this week if you would like.
Administrators Netduma Iain Posted June 24, 2015 Administrators Posted June 24, 2015 Hi Entropy, Fraser is unavailable today Entropy but I'll get him to schedule this evening. Are you available between 11am-6pmGMT during the week? If so which day and time is best for you?
Twisted Entropy Posted June 24, 2015 Author Posted June 24, 2015 I will only be available the rest of this week from 11am-3pm central standard time.
Twisted Entropy Posted June 24, 2015 Author Posted June 24, 2015 Sorry CST, which is 5pm your time I think. Local time now: 1:35pm.
Twisted Entropy Posted June 25, 2015 Author Posted June 25, 2015 Need confirmation, I will be up at 12pm to check for a reply.
iAmMoDBoX Posted June 25, 2015 Posted June 25, 2015 Need confirmation, I will be up at 12pm to check for a reply. Edit: Nevermind
Administrators Netduma Fraser Posted June 25, 2015 Administrators Posted June 25, 2015 5pm GMT works for me Twisted
Twisted Entropy Posted June 25, 2015 Author Posted June 25, 2015 I'm here so I will be back in an hour. Thanks so much
Administrators Netduma Fraser Posted June 25, 2015 Administrators Posted June 25, 2015 Okay so you want to do a 1 on 1 in an hour? As thats actually 7pm GMT.
Twisted Entropy Posted June 25, 2015 Author Posted June 25, 2015 I stated the time previously as Central Standard Time which is 1pm now. I am ready to allow access.
