Toni169 Posted April 2, 2018 Posted April 2, 2018 Hey guys I know that the theme is not right here but What about the input lag of asus mg28uq? I read difference results about it..20 ms and 10 ms..now i don‘t know what is the right result..can anyone help me? Or is there any monitor with a really good input lag results what you can recommend.. Sorry for my english Thanks
Zennon Posted April 2, 2018 Posted April 2, 2018 Hi, it is 10ms average. Top: 1.7ms Middle: 9.4ms Bottom: 17.7ms That is a great time, inline with most other gaming screens. Your screen is IPS and has a good 4ms response time gray to gray for an IPS model, you do have to add that to the input lag so it is 14ms in total which is still under a frame of 16ms. You can tweak the pixel response with Trace Free on your screen which is like the TN panels Overdrive option. I have tested Overdrive's input lag differences and for me on an Iiyama 4K gold master monitor it does not create any more input lag. mileage may vary screen to screen. Source
Toni169 Posted April 2, 2018 Author Posted April 2, 2018 My monitor „mg28uq“ has the TN-panel... the mg24uq has the ips panel.. and how can i use the trace free option? I use the monitor with a ps4 pro.. i don‘t have a pc.. I saw the video on youtube about the input lag of mg24uq...its 10 ms lag, but nothing see a video about the 28 inch... there are different
Zennon Posted April 2, 2018 Posted April 2, 2018 Oh sorry I didn’t notice it was the wrong model. It will be around the same for the 28” I am guessing, nothing to worry about. Trace free will be in the menu if the non IPS has such an option.
Toni169 Posted April 2, 2018 Author Posted April 2, 2018 Haw i scroll the trace free for no lag? Shall i scroll to 100 % or lower?
Zennon Posted April 2, 2018 Posted April 2, 2018 Haw i scroll the trace free for no lag? Shall i scroll to 100 % or lower? It is to stop motion blur not to lower your input lag. Your average input lag for your monitor is 10ms you can not lower that. 10ms is just fine that is a normal input lag time for a gaming monitor if you want next to 0ms you have to go back to the good old CRT screens of yesteryear. I mentioned input lag along side overdrive as using it on my screen while testing for input lag the screen stays at the same IL.
RL317 Posted April 3, 2018 Posted April 3, 2018 40-80% is generally regarded as best for Asus TraceFree. The lower you go the more ghosting you'll see; the higher you'll go the less ghosting you'll see, but with more artifacts. I guess it depends on the game/platform/refresh rate in use, but 100% is never a good idea. I've got a VG248QE and it looks messed up on 100 lol
purpleandgold33 Posted April 10, 2018 Posted April 10, 2018 Get a BenQ. Ive had one for 3 yrs. Nothing better! 1ms
Zennon Posted April 10, 2018 Posted April 10, 2018 Get a BenQ. Ive had one for 3 yrs. Nothing better! 1ms That is response time (grey to gray) not input lag.
Toni169 Posted April 12, 2018 Author Posted April 12, 2018 The asus has 1 ms too.. i spoke about the input lag...any idea what the inputlag is? Its a tn panel not an isp. The 24 inch has isp panel and has an input lag of 10 ms.. but there were nothing what i can find it about the input lag of the 28 inch
Zennon Posted April 12, 2018 Posted April 12, 2018 11ms https://displaylag.com/asus-input-lag-tests-4k-ultrawide-freesync-g-sync/
nunogsm Posted April 12, 2018 Posted April 12, 2018 i use this samsung, 27inch, 1ms response195€ https://www.worten.pt/informatica/imagem/monitores-pc/monitor-gaming-27-samsung-ls27e330-6365196
Toni169 Posted April 12, 2018 Author Posted April 12, 2018 Great .. 11 ms is a great result.. thanks Hope i did nothing wrong with it... I buy that especialy for cod ww2 online gaming, but i don‘t see any difference about the response instead of my tv sometimes.. i think that the servers are bad.. i didn‘t understand it
RL317 Posted April 12, 2018 Posted April 12, 2018 Great .. 11 ms is a great result.. thanks Hope i did nothing wrong with it... I buy that especialy for cod ww2 online gaming, but i don‘t see any difference about the response instead of my tv sometimes.. i think that the servers are bad.. i didn‘t understand it Servers are definitely bad but you'd probably feel drunk if you tried to play with a TV as well. I lost my monitor to a lightning strike in BO3 and used a spare TV for a while. Aiming was horrible on max sensitivity lol, so gloopy! When I replaced my monitor there was an immediate noticeable difference
purpleandgold33 Posted April 13, 2018 Posted April 13, 2018 That is response time (grey to gray) not input lag. either way still the fastest monitor on the market
RL317 Posted April 13, 2018 Posted April 13, 2018 either way still the fastest monitor on the market What model is that?
XSXS Posted April 13, 2018 Posted April 13, 2018 What model is that? A lot of people confuse response time with input lag. I think ASUS has the lowest input lag on their higher end models. However, BenQ does make some really nice monitors https://turbofuture.com/computers/Top-Gaming-Monitor
