Control Panel (Locked Out)
Hello, So two days ago i just got my netduma router and i was so hyped.It took me some time to set it up and all and i was so excited to use it and all which i can i just cant access the control panel and use the exclusive features to set up this amazing router.So for now its been a play router and i need assistance on getting in the control panel. I've tried http://192.168.88.1Doesnt Work Also http://r1 Still nothing
But here's the thing when i installed my router i had connected but it followed up with the "limited" no internet access
So i went on http://r1and i clicked wifi when the control panel still worked and Bam i had internet access but i could not get back into the control
Please Help Thanks!
ok first things first.
how are you trying to access the duma wifi or wired? are you also trying to game wifi or wired and how is it connected to your modem?
Connect to the duma via an Ethernet cable to see if you can see the GUI.
The set up should be
ISP modem/router >Ethernet to port 1 poe > Netduma
See my above post and always game using Ethernet as WiFi will drop packets.
Okay So i got into the control panel but it made my wifi limited and my wired connection limited so i couldnt get and i got my wifi back on and it just kicked me out saying your connection was interrupted
Turn off wif workaround in miscellaneous settings. Change your wifi password & apply. Then disable & apply. Then enable & apply.
Okay i will try it but i'm pretty sure it wont work since last time i tried to change wifi password and the name it didnt allow me since i had no internet connection and one quick question will and ethernet cable work as a lan cable or are there actually lan cables?
Okay So i went to the control panel and did what you told me Mr.Admin but the wifi workaround wasnt ticked already so i just changed the password and name and applied then disabled and applied again and it just like froze and kicked me out of http://r1saying a network changed was detected and i check to see what the wifi is called and its called netduma r1 again
If you were connected via wi-fi, it makes sense that you were kicked off. Try connecting via ethernet and then enable wi-fi, before connecting a device to the wi-fi. Do you get Internet access on that device?
The thing is when i do it with a wired device the internet is limited and i do not know how to fix that but when i troubleshoot,it says reset "ethernet" cable and then it says the "ethernet" does not have a valid ip configuration
Also another thing my speeds are slower than usual and they seem to cut out a few times during the day
Make sure turbo mode is checked like this below.
If you know that your ISP Hub requires PPPOE to access the Internet, you'll need to input those settings in "PPPOE" on the Netduma. Do you know what make the hub is / who your provider is?
So I got the internet connected with the wired setup but like i just connected the cable to the pc from the poe box lol because i cant seem to find the reason why i cant connect through the netduma so...I know its not the correct order but i got it working
