Blops 3 wall running
bagsta69
I finished the campaign on normal and started again on hardened to get some of the calling cards. I did not realise you had to unlock wall running ability from the safe house
, oh the joy when the girl tells you to run across the hoarding as the train passes underneath
Splat.
I know. If you unlock that last sniper rifle and place an infrared site on it. And just hang back. It's easy smeezy.
I didn’t like or use wall running at all during first prestige but last few days all of a sudden I am like a monkey just using in short bursts hopping up around corners, over enemies dropping down putting rounds into the tops of heads. Im sure everyone will be doing it soon but havent seen so much of it yet in the normal rank and file.
wow. good spot. I was wondering if there was any point wall running those barrels. I shall spend the night trying that... and failing miserably no doubt.
on redwood where you have the metal walkway and the rockface(where everyone rushes to face off at the start of a game)  you can run along the rock underneath the bridges.
on stronghold there is a way up onto the high rock at the cliff edge/bottom of the map, that looks up towards the main building, i don't think it's an exploit either, i tried it and you can run round the back of the rock without falling off but i couldn't figure where to boost up.
Run across the area by the broken wall that surrounds that building and jump. You can just teach if you burst jump to it. The under the bridge thing happened to me by mistake. I was pleasantly surprised.
I need to go into a private match and perfect that one. It looks like fun.
I will say this:  After watching some of the pros play this weekend in the qualifier, I am NOT doing anywhere near enough wall running, or wall transfers.  I saw some parts of maps that I didn't know you could even get to, let alone survive, this weekend...LOL
If you are following the standard, 3-lane routes with your boots on the ground, it is no mystery why you aren't having fun.  I need to use more wall running (while shooting) and I have to try to perfect the ability to run from one wall, to the opposite wall, to get past people and create new gun angles.
I learned a lot just watching an hour of games yesterday.  Just need to find some time to try some of it out.
