kinel Posted November 15, 2015 Posted November 15, 2015 I used to always use a bt open reach modem with my fttc connection till its speeds and pings droped they used to get 67 download 17 up ana 11 ms ping I was getting those speeds consistantly for over a year now if i use it my ping go up too 20 ms and speeds go no higher than 35dl mb and 5 mb up So i have to use my old router in modem mode and i get 67 dl and 17 up and 11ms ping but i want to use my modem again So the question is Question 1 Is there any way i can get those speeds back on my bt modem also Question2 can a modem pick up a virus causing these speeds drops Cheers
secretface Posted November 15, 2015 Posted November 15, 2015 that sounds like a firmware issue to me. But I'm no engineer.
Netduma Staff Netduma Crossy Posted November 15, 2015 Netduma Staff Posted November 15, 2015 I don't believe a modem can pick up a virus. I'd suggest plugging it on on your line and leaving it for a day or two and see if the ping settles down and you get the speeds back
kinel Posted November 15, 2015 Author Posted November 15, 2015 Crossy ive tried your idea many times before i left it for weeks and it never increased I aint got a clue what to try next maybe throw it in the bin lol
Netduma Staff Netduma Crossy Posted November 15, 2015 Netduma Staff Posted November 15, 2015 Crossy ive tried your idea many times before i left it for weeks and it never increased I aint got a clue what to try next maybe throw it in the bin lol Is it one given by BT? If it is you could ring and ask for a new one?
kinel Posted November 15, 2015 Author Posted November 15, 2015 Its the one i got from bt open reach engineer btw i am with talktalk they wont send me a modem as i am currently using there super router in modem mode or bridge mode
Sir_smooch Posted November 15, 2015 Posted November 15, 2015 Have you had a lot of router restarts in a short space of time? I was told by talk talk a little while ago though so many router restarts within a set period can cause DLM system to kick in, that can affect speed and line stability I believe.
Zennon Posted November 15, 2015 Posted November 15, 2015 Sounds like it has had its day if when you use the TT router is slap bang where it should be. Bin it, I got a Hauwei on flebay for 17.50.
kinel Posted November 15, 2015 Author Posted November 15, 2015 Yeh sirsmooth i know about dlm kicking in i have it many times before but this aint it
Zennon Posted November 15, 2015 Posted November 15, 2015 If your cab is a Hauwei cab deffo get a Hauwei modem it means you will have G.inp enabled which is fastpath with on the fly error correction. If you buy a ECI sadly it will give you interleaving if you have line issues.
Sir_smooch Posted November 15, 2015 Posted November 15, 2015 Sounds like it has had its day if when you use the TT router is slap bang where it should be. Bin it, I got a Hauwei on flebay for 17.50. What model did you get Zen, please? Does it run well? I thought the TT routers were Hauwei
Sir_smooch Posted November 15, 2015 Posted November 15, 2015 I got the Hauwei BT Modem. Do they only make the one or do they have a few different ones? Would you recommend it as an upgrade over the H635 hub they do
Zennon Posted November 15, 2015 Posted November 15, 2015 There are two modems ECI & Hauwei I would get the Hauwei if you want a modem as it handles G.inp. If your line is working OK as is just leave it smooch. I like modems as I can power cycle my routers as much as I want with no effect to DLM as my modem is always on.
kinel Posted November 16, 2015 Author Posted November 16, 2015 Great post zennon i loved it My modem model is a eci b focus the broken one i am currently using a talktalk huawei super router hg635 or 630 i cant remembere atm When i change routers or get power cuts it can take up too 2 days for dlm to lower my pings somtimes its instant for the pings to come back if i leave everything unpluged for more than 30 mins So zennon to you does this sound like i have a g inp cabinet Also as that hg super router is huawie 635 or 630 would i still need a huawie modem as i want to use the fastpath if i can
Zennon Posted November 18, 2015 Posted November 18, 2015 Have a look at this http://www.kitz.co.uk/adsl/fttc-cabinets.htmscroll down and it will show the different types of cab find yours and let me know which one it is.
BENORMOUS Posted November 18, 2015 Posted November 18, 2015 Mines one of those huwaei 288 it's about 100mtr from my home,they are the newest ones then?
kinel Posted November 18, 2015 Author Posted November 18, 2015 i was just walking around my streets the only cabinet i found was the Huawei 288 FTTC cabinet i hope its my cabinet as it wasnt far from my house so its a g inp cab as i am using a huawei hg 630 or 635 superouter at moment in modem mode or bridged mode will i still need to buy that Huawei modem you told me to buy to enable the g inp for fastpath as you said If your cab is a Hauwei cab deffo get a Hauwei modem it means you will have G.inp enabled which is fastpath with on the fly error correction. and i really badly want the fastpath enabled on my line as i had it on adsl i know how good it was cheers again your so helpful and everyone on these forums
kinel Posted November 18, 2015 Author Posted November 18, 2015 cheers zennon i was hoping that my Hauwei hg 630 or 635 super router when in modem mode or bridged mode would do the same as a Hauwei modem and enable the g inp on the line cheers again for the the help
Zennon Posted November 18, 2015 Posted November 18, 2015 cheers zennon i was hoping that my Hauwei hg 630 or 635 super router when in modem mode or bridged mode would do the same as a Hauwei modem and enable the g inp on the line cheers again for the the help Yes they should, they would need a firmware update, as would the modem, the router maybe has not had the update yet. So its up to you whether you want to get a modem or not. I would ask on the TT forum as to whether they can update the routers from their end. Do not bother ringing the script monkeys.
kinel Posted November 18, 2015 Author Posted November 18, 2015 i posted a thread of talktalk forum earier i just got a reply they say i am currently using the newest firmware mines is Hardware vers g1 01 Software v v1.06 for huawei hg635 super router
Zennon Posted November 18, 2015 Posted November 18, 2015 So you should be running G.inp then. What are your pings using the duma's diagnositcs.
