Grey Posted September 27 Posted September 27 Hello, for a long while now my speed on LAN and WiFi have been very very slow, i used to get 500mbps download and around 30mbps upload before upgrading to a 1gig plan through my ISP, now I can barely install small updates without having to leave my PC on overnight, I've turned off QoS, redid the setup after factory resetting 6+ times, called my ISP, tested my modem via ethernet and updated/downgraded to various different firmware versions I'm lost on what todo, attached will be my speed tests on LAN, both WiFi bands and LAN connected straight to my modem. Currently all settings are default besides QoS is turned off. ISP: Spectrum Modem: Arris Surfboard SB8200 Router: Netgear Nighthawk XR500 Modem - XR500 - PC via LAN Modem - PC via LAN WiFi 5GHz band WiFi 2.4GHz band
Administrators Netduma Fraser Posted September 27 Administrators Posted September 27 Which test is which? If you're not getting your speeds directly connected to the modem then there isn't anything the router can do, you'll need to sort that with them first
Grey Posted September 27 Author Posted September 27 8 hours ago, Netduma Fraser said: Which test is which? If you're not getting your speeds directly connected to the modem then there isn't anything the router can do, you'll need to sort that with them first 1st photo is Lan through the Modem - XR500 - PC 2nd photo is Lan through Modem - PC 3rd photo is over WiFi 2.4GHz band 4th photo is WiFi 5GHz band So I am getting the correct speeds directly connected to the modem, the router speeds are the issue.
Grey Posted September 27 Author Posted September 27 new Speedtest Modem - XR500 - PC via ethernet with two brand new Cat8 ethernet cables
Grey Posted September 27 Author Posted September 27 small update... so i fixed it, i didn't have QoS and DPI fully disabled i never clicked on the three lines until i took that screenshot above
Administrators Netduma Fraser Posted September 28 Administrators Posted September 28 Good to hear, thanks for the update! You shouldn't have to disable it fully though - did you have your speeds entered into the router and what did you have Congestion Control set to?
