euphidra Posted December 19, 2023 Author Share Posted December 19, 2023 I managed to configure the two LG soundbars but what a pain. Obviously I have a fixed IP on all devices and I will have difficulty finding the soundbar's IP address immediately after the reset. If they didn't connect I would have unified the wifi bands always with an automatic channel. But there is certainly something that creates conflict with the Netduma R3 router. I hope you resolve it with an upcoming firmware and Hybrid VPN also arrives. SmartBoost is active during LG Soundbar app setup (has the same app setup difficulty if SmartBoost is disabled). I keep IPV6 deactivated, UPNP active and all the protections active on Troubleshooting (Remote Access and Port Scan Protection). Thanks Fraser if you fix it. Improves the wifi that the 5Ghz wifi band from yellow wifi icon on more distant devices and on 2.4Ghz wifi band red wifi icon on more distant devices. Devices far away in the same location. Thank you. And add interface exit button in router menu. There is only the reboot. I'll send you the log @Netduma Fraser R3_2023-12-19T20_45_35.813Z_logs.txt Link to comment Share on other sites More sharing options...
l2eactionz Posted December 19, 2023 Share Posted December 19, 2023 On 12/16/2023 at 11:42 PM, euphidra said: I am in Messina (Sicily). The test worked but I don't understand how to manually optimize the bufferbloat and enter the percentage myself. Automatically uses 93% download and 100% upload. Putting Messina on the GPS makes me go to Calabria and I move it manually to Sicily. I use PPPOE with FTTC TIM 200 mega. The exit button is missing from the router menu so you just have to close the browser page. By chance I can go back to the official firmware without rebooting or I stay with this version. Does it have problems as a beta? I reset to see on the PPPOE startup setup that you have to skip that part but both the speed test and the ping optimizer work when the setup starts. I played on PlayStation 5 and the console upload test was 4.5 mega while with VPN I exceeded 10 mega upload. What happens if the server is not stabilized? I clicked on the pad icon and it appeared again but not from the game server side. The playstation speed test is to the playstation servers where upload is prioritiesed for people actually using the accounts. Message a friend on psn speedtest.net and use the ps5 Web browser to get a true ps5 reading of speeds euphidra 1 Link to comment Share on other sites More sharing options...
l2eactionz Posted December 19, 2023 Share Posted December 19, 2023 On 12/17/2023 at 12:33 AM, euphidra said: After I'm logged into the router I mean. Netduma R2 in the restart and exit menu to exit the login. Now I just have to get it out by closing the browser page. https://www.waveform.com/tools/bufferbloat?test-id=2aab069b-f150-4644-8b70-2d91508e5b67 I entered 70% download e 70% upload. Run full test active, ping optimizer mode expert, congestion control auto, speed test bypass active. I can't remove the danger triangles in Low Latency Gaming which on Netduma R2 gave me positive ticks. Is there a way to fix it? I can't remove the danger triangles in Low Latency Gaming which on Netduma R2 gave me positive ticks. Is there a way to fix it? PPPOE and QOS works perfectly but this Low Latency Gaming is better. Between an official firmware and a beta one (and vice versa) is it no longer necessary to reset the router like Netduma R2? Insert a backup to save settings so even if you reset the router in an instant you reset everything. If you have a beta hybrid vpn firmware ported from Netduma R2 please could you send it to me. Thanks Fraser. Test Ping Optimizer manuale Ping ms Jitter ms Loss % 36.5 0.1 0% Test History close Time Ping ms Speed test bypass is still active euphidra 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 19, 2023 Administrators Share Posted December 19, 2023 What was it that you did that allowed the sound bars to work exactly? I still don't know what you mean by exit button? It's like if you were going to close a website, you would close the tab euphidra 1 Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 The soundbar then disconnects from the LG soundbar app (one of the two soundbars). I don't know what happens but with Netduma R2 this didn't happen. the exit button is to exit the interface like R2 but perhaps you have eliminated the problem that came out of the login interface, so even if I close the interface tab, if I return it is already logged in to the router. Improve these bugs with LG Soundbar and Google Home apps (I read about users who also have problems). Also check this log and compare it to the previous one that the two soundbars were both active on the app. I saw that there is firmware 4.0.20. I have 4.0.19. Could you send it to me Fraser. Thank you. R3_2023-12-20T00_22_17.717Z_logs.txt Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 IPv6 activated which I deactivated during setup. I activate Ipv6 and deactivate it again but the wifi on the cell phone no longer connects. Will I have to reset it? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 20, 2023 Administrators Share Posted December 20, 2023 Could you disable Steady Ping on the Geo-Filter page please and see if that issue is better? Someone mentioned that caused an issue for their smart devices. Reboot the phone and it should connect then euphidra 1 Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 They sent me firmware 4.0.20. Is it an official version? What problem does it solve? I install and reset because after activating ipv6 the wifi gives me problems. Fix these bugs. It's better not to put IPv6 at setup startup but not to activate it later as it creates problems. Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 I installed firmware version 4.0.20 and disabled Steady ping and also Smartboost but I cannot complete the configuration with the LG Soundbar app. It can find the soundbar's wifi but no app communicates with the soundbar. I have separate wifi bands with automatic channels. Now I will reset the router and set the same wifi band as in the initial setup. Let's see if it works. Netduma R2 worked without any problems. It's a mistery. Message following this: Even with the same wifi band, the LG Soundbar app does not connect to the two soundbars. I don't know what the problem is that it worked with R2. I have firmware 4.0.20 installed. Android 14 version with ONE UI 6.0 installed on Samsung Galaxy S21FE smartphone SmartQOS doesn't work. @Netduma Fraser R3_2023-12-20T14_19_32.899Z_logs.txt Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 Hi Fraser I may have the firmware 4.0.21 Thanks. I hope you solve the problem with LG Soundbar app. SmartQOS doesn't work. @Netduma Fraser Link to comment Share on other sites More sharing options...
TG3NOC1D3 Posted December 20, 2023 Share Posted December 20, 2023 On 12/17/2023 at 5:18 AM, euphidra said: You exit the router interface. The danger triangles on Low Latency Gaming at the end of the bufferbloat test (with Netduma R2 I had double positive ticks). I manually put 70% download and 70% upload (while automatically it was 93% download and 100% upload but still the danger triangles on Low Latency Gaming). Can this be fixed with some firmware update? Using PPPOE. Test Bufferbloat: https://www.waveform.com/tools/bufferbloat?test-id=424a3722-21fb-4348-a6d5-e16227c3d82d Ok, when you see those triangles, ignore them. All you are looking for is less them +5ms increase during download and upload. The website doesn't know your route latency to the gaming servers. I get a lower ping in games than I do on the test. The test even gives me checkmarks, I also have fiber, but realistically you are just making sure your bloat stays within +5 ms or less as this is what is considered excellent. Very good is +10ms or less when using dslreports bufferbloat speed test. Trust me, don't get hung up on the check marks or danger triangles, those don't mean jack shit when it games to gaming cloud servers. Last note, there is no way to block youtube ads without a lot of work on the browser side and a vpn and dns tunneling, it just isn't worth the headache man. euphidra 1 Link to comment Share on other sites More sharing options...
Megatf Posted December 20, 2023 Share Posted December 20, 2023 Hey, I am a new poster but not a first time user. I have owned the R2 and now own the R3. I beta test Alpha firmwares for other hardware I own and would like to test the latest ones as well to compare to the latest public release firmware. I have a Bachelors in Cybersecurity: Wireless and can use Wireshark with my eyes closed. Can you please send me a link to test out the latest Alpha firmware for the R3? I currently live in Hawaii and I am always looking for every opportunity such as this device to optimize my ping as much as possible due to my geographic location. Thank you Fraser! Link to comment Share on other sites More sharing options...
euphidra Posted December 20, 2023 Author Share Posted December 20, 2023 @Netduma Fraser You did not answer my questions. Fix the LG Soundbar app issue and the rest of the bugs. Disabling steady ping and smartboost doesn't change anything. All the devices have a fixed IP and I also tried to unify the wifi bands, keeping them separate and both on automatic channel. Detects the soundbars wifi but does not finish the guided setup of the LG Soundbar app. There's an update you're trying to get them to work on. I went back to version 4.0.19 after downgrading to 4.0.16. A friend has already written to me that he sees 4.0.20 which I can't see. Thanks Fraser Link to comment Share on other sites More sharing options...
Deasha Posted December 20, 2023 Share Posted December 20, 2023 I’m having the same problems with setting up my Apple home pods. Tried everything to get them set up but keep getting this message. Tired geo filter off, smart boost off, steady ping off, separating wifi bands, kicking ISP connection, reseting ISP ports, reseting network settings, factory reset router, UPNP on and off, port forwarding apples air play ports manually, factory resting home pods, deleting all data from phone and iCloud before factory reset, saving manual IP addresses for home pods Link to comment Share on other sites More sharing options...
euphidra Posted December 21, 2023 Author Share Posted December 21, 2023 @Netduma Fraser The firmware has updated to version 4.0.20 but I cannot configure the two LG soundbars. That is, I can do one but at 2.4Ghz and not 5Ghz (It has a fixed IP set on the router but it can't find the LG Soundbar app with the fixed IP set giving many soundbars in the list). The other soundbar only connected to 2.4Ghz and it took it to find the fixed IP of the router set manually). What is the problem that with Netduma R2 it didn't happen and I was connected to both soundbars at 5Ghz (I use automatic channel wifi in both bands by default). You have a firmware fix to try to see if it works. Thanks Fraser. Link to comment Share on other sites More sharing options...
euphidra Posted December 21, 2023 Author Share Posted December 21, 2023 @Netduma Fraser I connected the two soundbars but on two separate frequencies. The soundbar closest to the router is at 5 Ghz (automatic channel) while the one furthest from the router is at 2.4 Ghz (automatic channel). Not even both on the 2.4Ghz wifi band I was able to connect. With the Netduma R2 both soundbars were connected to 5 Ghz. I don't know why. Fraser looks why there is this problem. The two LG soundbars detect both wifi bands but does not complete the configuration on the LG Soundbar app. Thanks Fraser if you solve the problem. I use fixed IP on all devices with DHCP from . 100 to .250 On DEVICE MANAGER I see all the connected devices. The 2.4 Ghz band gives me a yellow wifi icon on the soundbar while on the TV near the soundbar it gives me a red wifi icon (But the wifi on the TV works perfectly so I don't know if it's just a display problem). You need to optimize the wifi signal like the Netgear XR1000. R3_2023-12-21T16_45_42.943Z_logs.txt Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 21, 2023 Administrators Share Posted December 21, 2023 @euphidra no need to repeat the issue, we have identified what the cause is, it is what deasha referred to above, the team are looking into this and will resolve it as soon as possible. PharmDawgg and euphidra 2 Link to comment Share on other sites More sharing options...
euphidra Posted December 22, 2023 Author Share Posted December 22, 2023 @Netduma Fraser Thank you. Hi Fraser, I also need firmware beyond 4.0.20 which updated automatically. Thank you. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 22, 2023 Administrators Share Posted December 22, 2023 29 minutes ago, euphidra said: @Netduma Fraser Thank you. Hi Fraser, I also need firmware beyond 4.0.20 which updated automatically. Thank you. It just fixes VLAN but sent euphidra 1 Link to comment Share on other sites More sharing options...
euphidra Posted December 22, 2023 Author Share Posted December 22, 2023 Smartboost works better with 4.0.21 compared to 4.0.20 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 22, 2023 Administrators Share Posted December 22, 2023 We didn't make any changes to it but that's good to hear! euphidra 1 Link to comment Share on other sites More sharing options...
euphidra Posted December 22, 2023 Author Share Posted December 22, 2023 It seemed to work. For example, in WIFI the smartboost does not detect NOW in Video & Streaming while on LAN it does. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 23, 2023 Administrators Share Posted December 23, 2023 39 minutes ago, euphidra said: It seemed to work. For example, in WIFI the smartboost does not detect NOW in Video & Streaming while on LAN it does. Most likely it wasn't triggering properly in the first place for some reason and the reboot/update allowed it to trigger but do let us know if you notice anything else like that euphidra 1 Link to comment Share on other sites More sharing options...
euphidra Posted December 23, 2023 Author Share Posted December 23, 2023 It doesn't detect Now on wifi but with a LAN cable on the other TV it does. I tried to put only Now in priority but it turned on and off immediately after a few seconds. To improve the speed of the speed test in PPPOE which gives low speeds compared to DHCP. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 23, 2023 Administrators Share Posted December 23, 2023 13 hours ago, euphidra said: It doesn't detect Now on wifi but with a LAN cable on the other TV it does. I tried to put only Now in priority but it turned on and off immediately after a few seconds. To improve the speed of the speed test in PPPOE which gives low speeds compared to DHCP. Interesting, is it the same device being used that is connecting via WiFi or ethernet or a different device? euphidra 1 Link to comment Share on other sites More sharing options...
Please sign in to comment
You will be able to leave a comment after signing in
