dominican_3niz Posted July 23, 2015 Posted July 23, 2015 hi guys i am paying for 150 down and 20 up when i connect my duma. only get 85 down and 18 up is there any settings for my connection so i can get on duma what i get on the xfinity moderm
dominican_3niz Posted July 24, 2015 Author Posted July 24, 2015 http://www.speedtest.net/my-result/4527246936
Blochand Posted July 24, 2015 Posted July 24, 2015 Are your settings at the Congestion Control menu on 100%?
iAmMoDBoX Posted July 24, 2015 Posted July 24, 2015 hi guys i am paying for 150 down and 20 up when i connect my duma. only get 85 down and 18 up is there any settings for my connection so i can get on duma what i get on the xfinity moderm http://wiki.netduma.com/doku.php?id=setup_gt_120
PuppetMaster Posted July 24, 2015 Posted July 24, 2015 It use to be fine but since the 1.2 update(I believe it was this one) its been maxing at 60-85. My upload has been fine though.
lukasz Posted July 24, 2015 Posted July 24, 2015 I please follow up the link provided by I am Mod box nad let us know how it goes. Dont forget to reset both router and the modem. After you are statings.
RADDY1993 Posted July 24, 2015 Posted July 24, 2015 hi guys i am paying for 150 down and 20 up when i connect my duma. only get 85 down and 18 up is there any settings for my connection so i can get on duma what i get on the xfinity moderm Change your Algorithm to Reactive.
dominican_3niz Posted July 24, 2015 Author Posted July 24, 2015 i haved donde all those things and still up to 80 down and 24 up. when i run speed test on m ps4 it worth my ps4 givin me 21 down and 2.1 up
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 i haved donde all those things and still up to 80 down and 24 up. when i run speed test on m ps4 it worth my ps4 givin me 21 down and 2.1 up Don't worry about the speed test on the PS4 - they are not too accurate. Are you doing the test on a wired connection and is it with a reputable speed test website such as http://speedtest.net? Also, can you confirm that in Settings >> WAN, Settings >> LAN and Settings >> Miscellaneous that IPv6 is disabled. Also that you are using the reactive algorithm in congestion control. If that is still giving you slow speeds, can you restart the Netduma by going to Settings >> Miscellaneous and clicking 'Reboot Router'.
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 yes averything is correct Ok, and are you still getting slow speeds? Even after restart. Can you also confirm that you are doing this on a wired connection. Also, what is the make of the modem you are using in-front of the Netduma?
dominican_3niz Posted July 24, 2015 Author Posted July 24, 2015 yes still slow and duma is righ next to my moderm.. xfinity comcast
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 yes still slow and duma is righ next to my moderm.. xfinity comcast Is the Xfinity in modem mode? Could you just plug your computer directly to that without changing any settings and see what the speeds are.
dominican_3niz Posted July 24, 2015 Author Posted July 24, 2015 it when up top 97 download and 24 up.. but still to low for im paying tho
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 it when up top 97 download and 24 up.. but still to low for im paying tho Can you try pressing the reset button on the back of the modem and see if this fixes the issue
dominican_3niz Posted July 24, 2015 Author Posted July 24, 2015 i did it as it factory but still i have the red duma cable conneted to the moderm and duma and them a yellow one to the pc like all conection is good but speed test is bad
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 i did it as it factory but still i have the red duma cable conneted to the moderm and duma and them a yellow one to the pc like all conection is good but speed test is bad Could you try taking it out of bridge mode and see if you get the speeds you pay for when you do that?
Administrators Netduma Fraser Posted July 24, 2015 Administrators Posted July 24, 2015 Just to add, reset device prioritisation as well before a speed test
Alex49H Posted July 24, 2015 Posted July 24, 2015 Just to add, reset device prioritisation as well before a speed test How do you reset Device Prioritization?
Netduma Staff Netduma Crossy Posted July 24, 2015 Netduma Staff Posted July 24, 2015 How do you reset Device Prioritization? Press the button under 'the flower' that says 'Reset Distribution' and then press 'Update Distribution'
Alex49H Posted July 24, 2015 Posted July 24, 2015 Press the button under 'the flower' that says 'Reset Distribution' and then press 'Update Distribution'
