Infoseye Posted February 3, 2023 Author Posted February 3, 2023 8 hours ago, Fuzy said: Are you talking about the MW2 game in multiplayer? I hadn't tried to play on this game for a while, a priori they improved the rendering of latency at the level of the game, or just a tip... This is still good news for netduma because it is getting closer to the information given on dumaOS (auto ping) On the server closest to me, I ping at 9ms on the geofiltre netduma auto ping and I ping on the game at 20ms in part... This is not the case on "old" CODs +20ms ping in general compared to auto ping (on the latency given by the game on the server). I understand the screenshot better! Yes it is on MW2 multiplayer on warzone is about 25 -30
Infoseye Posted February 3, 2023 Author Posted February 3, 2023 8 hours ago, Fuzy said: @Seye I don't know if the fiber module is built into your BT smarthub, but it might be worth bypassing it ! How do I check? Have got one of these on the wall.
Newfoundland Posted February 4, 2023 Posted February 4, 2023 11 hours ago, Seye said: I believe its BT for home use, I'm abit new to this how do I check if its broadcasting? Thisis what I can see on the admin login There is no opt out of the free WiFi from the UI, can you see if it’s broadcast if you use a WiFi analyser? your other photo looks like an ONT, do you have the BT voip service ie. Home phone. If so if you don’t use their router you will not be able to have your home phone. what’s the model number of the homehub?
Krush Posted February 4, 2023 Posted February 4, 2023 12 hours ago, Seye said: How do I check? Have got one of these on the wall. Indeed it is an ONT: There are different ways to bypass the ISP router with R2: PPPoE identifier, dhcp option (60 ; 61) or even the Vlan ID. You can see it in network setting at the Wan level. I don't know how it is with your BT provider. But you can definitely find the information on Google... As explained @Newfie, this will prevent you from using your fixed telephony because the R2 does not have asterisk or other software for bypassing the voice part. (Personally, I do not use it, the cell phone is sufficient) For information, one thing that I also noted on the forum is that some users have noticed a drop in speeds with PPPoE. To confirm
Infoseye Posted February 4, 2023 Author Posted February 4, 2023 4 hours ago, Newfie said: There is no opt out of the free WiFi from the UI, can you see if it’s broadcast if you use a WiFi analyser? your other photo looks like an ONT, do you have the BT voip service ie. Home phone. If so if you don’t use their router you will not be able to have your home phone. what’s the model number of the homehub? So I wasn't giving a phone service with it since I barely use telephone am always on my mobile for calls. Its a smart hub 2 model number GRV9517UAC34-A-SA
IREWolfman Posted February 4, 2023 Posted February 4, 2023 Ditch the bt hub. Connect the Netduma directly to the ont
Infoseye Posted February 4, 2023 Author Posted February 4, 2023 I checked it seems 13 minutes ago, IREWolfman said: Ditch the bt hub. Connect the Netduma directly to the ont I have tried doing this but R2 doesn't connect to the internet.
Administrators Netduma Fraser Posted February 4, 2023 Administrators Posted February 4, 2023 26 minutes ago, Seye said: I checked it seems I have tried doing this but R2 doesn't connect to the internet. You'll have to click WAN Setup then skip and enter the information you need in Settings
Infoseye Posted February 4, 2023 Author Posted February 4, 2023 12 minutes ago, Netduma Fraser said: You'll have to click WAN Setup then skip and enter the information you need in Settings I honestly don't know the required information, do my ISP provide username and password?
Administrators Netduma Fraser Posted February 4, 2023 Administrators Posted February 4, 2023 Yes they would, otherwise you can find it in the hub settings
Infoseye Posted February 4, 2023 Author Posted February 4, 2023 1 hour ago, Netduma Fraser said: Yes they would, otherwise you can find it in the hub settings Searched the four corners of the internet 😂 for BT settings and found the settings on Sky forum, successfully connected via PPPoE 2 hours ago, IREWolfman said: Ditch the bt hub. Connect the Netduma directly to the ont I managed too cheers
Infoseye Posted February 4, 2023 Author Posted February 4, 2023 On 2/3/2023 at 5:09 AM, Newfie said: Is this BTs business router version as their home hubs don’t offer DMZ? on the home hub they broadcast free WiFi, worth checking that’s disabled but I believe it still broadcasts but is hidden. Opted out of the BT WIFI https://www.bt.com/help/broadband/how-do-i-check-that-i-ve-joined-the-bt-wi-fi-community-
Newfoundland Posted February 5, 2023 Posted February 5, 2023 That’s the link to opt out. Just wish they would disable the WiFi on their routers if you opt out. I stayed in then just removed their router.
Newfoundland Posted February 5, 2023 Posted February 5, 2023 19 hours ago, Seye said: I honestly don't know the required information, do my ISP provide username and password? It should be your primary email address and password can be anything, I use BT as my password.
Infoseye Posted February 24, 2023 Author Posted February 24, 2023 Sorry didn't get an update you replied, I have figured it out but login. I have ditched BT router and using R2 as my main.
