NetDumaNewb Posted January 11, 2022 Author Posted January 11, 2022 I've allowed remote access tech support, are you able to look into it yourself this way, somehow??? I feel like this would safe us both LOTS of time.
Krush Posted January 11, 2022 Posted January 11, 2022 @Netduma Fraser there is no more choice, it is necessary to solve the problem at her place!
Administrators Netduma Fraser Posted January 11, 2022 Administrators Posted January 11, 2022 31 minutes ago, NetDumaNewb said: Ok I tried launching call of duty warzone on WIFI, it was no longer connected on the VPN, although I did not change anything. Area shown was now Amsterdam. (why?, because VPN is set on PS5) So with 80 MB download and 7.5mb upload I should be able to normally play (was hoping this was my VPNed speed, but no this was based on my Amsteram area) when i tried to play a game i was lagging so bad, checked my latency and it was going from 65 to 999 to NA. joystick input had so much lagg that game wasnt been playable at allllll. You may need to re-enable the VPN. Have you setup QoS or the Geo-Filter at all? If not you will need to do that to reduce your latency. Did you do the factory reset after the upgrade was successful? We don't do remote support that way for normal setup, only if there is an issue a dev has to look into. Also are ALL devices connected to the router?
NetDumaNewb Posted January 11, 2022 Author Posted January 11, 2022 Yes I’ve set up the geo filter (Amsterdam where I live). I didn’t factory reset because it wouldn’t finish the firmware upgrade, it kept hanging there twice for so long that I just force closed the page….. Ok, well then I gotta bother you again tomorrow via the forum. I’m sorry. No my roomie her phone is connected to the old WiFi network that is in the air again due the fact the modem is no longer in bridge mode
Administrators Netduma Fraser Posted January 11, 2022 Administrators Posted January 11, 2022 Now that it is all upgraded I would suggest you do the factory reset from the interface, a lot has changed between versions and it prevents old low level code causing issues. Ideally if you could get her phone to connect to the R2 that would make the QoS more effective - you could disable the WiFi on the ISP router to prevent devices auto connecting to it.
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 12 hours ago, Netduma Fraser said: Now that it is all upgraded I would suggest you do the factory reset from the interface, a lot has changed between versions and it prevents old low level code causing issues. Ideally if you could get her phone to connect to the R2 that would make the QoS more effective - you could disable the WiFi on the ISP router to prevent devices auto connecting to it. I havent been able to complete the firmware update yet. **
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 471 MB speedtest connected to the old WiFi from the ISP 294 MB SPEED on the NetDuma router mehhh. Which speed of the two I gotta fill in for the bandwidths? OT: still not able to complete firmware update tried safari/chrome and chrome incognito. Restarted PlayStation aswell
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 After my latest restart the update proces did turn my WiFi off and the lights from my router. I did see changes in the background of the NetDuma OS Background Does that mean it worked although it keeps saying upgrade is in progress?
Newfoundland Posted January 12, 2022 Posted January 12, 2022 Set the 2.4ghz to 20Mhz and use this channel for IoT devices. Set the 5ghz to 80Mhz. if you are using both your isp and R2 WiFi at the same time insure they are not on the same channel to help with interference. Positioning is very important to obtain the best performance, you may get a tad more out of the R2’s WiFi. The best I’ve achieved on average is 450Mbps.
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 16 minutes ago, Newfie said: Set the 2.4ghz to 20Mhz and use this channel for IoT devices. Set the 5ghz to 80Mhz. if you are using both your isp and R2 WiFi at the same time insure they are not on the same channel to help with interference. Positioning is very important to obtain the best performance, you may get a tad more out of the R2’s WiFi. The best I’ve achieved on average is 450Mbps. Where can I set that up again if I've skipped that during setup?
Newfoundland Posted January 12, 2022 Posted January 12, 2022 5 minutes ago, NetDumaNewb said: Where can I set that up again if I've skipped that during setup? It’s under settings, you will see the WiFi tab. Take your time to explore the features so you get to know the layout if it’s now running ok. The chances are both 2.4 and 5Ghz are already on the correct settings but you can double check.
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 Ok changed the 40Mhz to 20 Mhz (y). Do you also have a clue why the downloaded firmware update is hanging/freezing(?).
Newfoundland Posted January 12, 2022 Posted January 12, 2022 Were you updating over WiFi? Is so double check the firmware version installed as the client doing the upgrade loses connection. If it’s not updating its best for Fraser or Liam to pop in as they’ve already started the procedure to get you up-to-date and I will just confuse the issue.
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 9 minutes ago, Newfie said: Were you updating over WiFi? Is so double check the firmware version installed as the client doing the upgrade loses connection. If it’s not updating its best for Fraser or Liam to pop in as they’ve already started the procedure to get you up-to-date and I will just confuse the issue. I was connected over WiFi while doing the update. During the firmware update I saw lights turning on and off on my router so I assumed it worked, but it never refreshed the page where Fraser talked about. It kept busy updating and updating until the point I no longer believed it would finish (multiple times). And I would just click the DumaOS page away.. I downloaded the most recent firmware update from the link they've provided me with earlier: ''DumaOS-R2-3.0.394.sig''
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 Secondly, I'm wondering why my WiFi is faster than my connected LAN cable? @Newfie
Newfoundland Posted January 12, 2022 Posted January 12, 2022 If the update went to plan you need to reset and do a fresh set up. once you have done that and it’s up and running then do a test to double check your lan speeds are working as intended.
Netduma Liam Posted January 12, 2022 Posted January 12, 2022 Good advice from Newfie, please complete the steps he mentioned above! You can see if the upgrade was successful by checking the firmware version in the top right of the interface, it should now read 3.0.394. Newfoundland 1
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 22 minutes ago, Netduma Liam said: Good advice from Newfie, please complete the steps he mentioned above! You can see if the upgrade was successful by checking the firmware version in the top right of the interface, it should now read 3.0.394. I've checked it out and it indeed matches the new version! Woohoo Shall I reset via the button on the router or the unbuild reset button on the dumaOs> @Netduma Liam @Newfie Newfoundland 1
Newfoundland Posted January 12, 2022 Posted January 12, 2022 That’s great. Use the rear pinhole to reset. Hold it in for 20 seconds, release and then allow it to fully boot up before setting up.
Newfoundland Posted January 12, 2022 Posted January 12, 2022 Did it Find an internet connection on setup?
Administrators Netduma Fraser Posted January 12, 2022 Administrators Posted January 12, 2022 Did you wait a few minutes after the reset before trying to access?
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 I clicked on the inbuild restart button directly from the dumaOs. I’ve now also resetted the router itself with a pin. Only first two lights are burning. No connection found yet
Administrators Netduma Fraser Posted January 12, 2022 Administrators Posted January 12, 2022 Reboot the modem, wait 2 minutes, then reboot the R2, wait 2 minutes and you should get a connection
NetDumaNewb Posted January 12, 2022 Author Posted January 12, 2022 I've pulled out the power adapter and put it back in. I now have 4 burning lights and my Netduma wifi again. Still says: R2 3.0.394 as version (Correct r) How do I know if the reset has worked correctly? How would it look like? Was it necessary to pull out the power adapter or did that ruin anything.
