R2 speed problem
Densha-Warrior
Hi!!^^ @Netduma Fraser
I have 1g internet speed
With my xr500 and my asus router, I have on speed test etc 950 Mbits down and 470 Mbits up Max
With the R2, I have 700,800 Mbits down , sometimes even lower and 470 up
I never had 950 Mbits down. Never.
I have my R2 since day one, I pre-ordered it.
Have I come across a bad model by bad luck seeing this is the first edition?
Maybe that's why it doesn't work the way I want it to?
Thank you in advance for your help!^^
They will be more powerful hardware wise compared to the R2 so it does make sense it would be lower. Is this with QoS enabled or with QoS completely disabled from the Congestion Control :menu menu?
Yes , I know for hardware Frazer, but here there is a problem.
With "qos never" at 1000down and 1000 up and qos disable too, it does the same
@Fuzy has 950 Mbits on his R2 and has the same internet provider as me.
Have you tried reinstalling the latest firmware followed by a reset then test.
Hopefully Fuzy will pop in to compare his settings with yours but if it were me I would be tempted to do the above.
I don’t think there’s been any hardware alterations as the model you have will be the same as Fuzys given the timeline.
Salut Densha,
Les résultats sont aléatoire suivant l'heure de la journée... Si tu fais tes tests entre 18H et 22H cela me paraît normal et pas alarmant.
ça ne changera rien a ton game play étant donné que les jeux ont besoin de très peu de bande passante....
Comment effectues-tu ton test de vitesse ?
J'utilise l'application speedtest pour W10 car elle consomme moins de CPU.
Sur le R2 le QOS est totalement éteint, juste mon PC d'allumé dessus.
Il est 8h45 du matin voici mon résultat ...
Si je fais le même test ce soir en période de congestion sur le même serveur. Je pense être entre 700 et 800... comme toi.
Le problème ne vient pas du R2 mais de la congestion de la ligne GPON ou la congestion sur le serveur de test. La fibre est partagée en amont de ta ligne ce qui limite les tests de débit en soirée ...
Mais avec 700 ou 800 Mbps, tu as largement de quoi faire.
C'est gentil de me répondre.
J'en étais sûr que tu allais me répondre ça. Logique.
Mais là, je l'ai fait en testant mes routeurs puis le R2 à la suite sur le même serveur.
Pour info, j'utilise le site Nperf sur le serveur "Free 40g Paris".
Comme si mon R2 était bridé. C'est très bizarre.
Peux-tu refaire le test ce matin sur le R2 avec l'app speedtest W10 ? Tu es chez Free ou SFR ?
Après je ne pense pas que cela soit problématique ...
Les speedtest sont très aléatoire et cométique ...
Par exemple : je peux télécharger à 110 Mo/s sur battle.net mais faire un test de débit à seulement 700 Mbps en DL... y a pas vraiment de logique ! (1Mo/s = 8Mbps) ou encore telecharger à 60 Mo/s sur steam alors que mon test de débit affiche 930 Mbps en DL ...
Le mieux serait de faire un test en mode sans échec avec réseau !
Sur une ligne adsl à 5 Mbps si tu perd 20% de ton débit, je pas comprendre que cela peut poser problème, mais sur un ligne FTTH 1000/500... Tu en as encore sous le pied avant de la congestionner ...
Comme l'a suggéré @Newfie, j'ai fait un réupload du firmware et un factory reset.
Je suis chez Red SFR @Fuzy
Donc voilà mon test juste fait à l'instant avec Mon R2 et mon asus à une minute d'intervalle
mon asus :
Mon R2:
Je suis chez Red @Fuzy
mon asus :
Mon R2:
Tu es en direct ONT pour les 2 !
J'avoue, je ne comprend pas ....
Oui, je suis en direct ONT sur les 2.
Non, moi non plus, je ne comprend pas XD , c'est pour ça que je demande 😂
En tout cas merci d'user de ton temps pour ça 😄
Pour tous les serveurs c’est pareil ?
essayes le Trappes comme moi .
donc là c'est sur le serveur sfr bordeaux:
mon asus:
Mon R2:
voilà, c'est vraiment étrange.
Je pense sincèrement que mon R2 a un problème.
Tu as moyen de faire un test DL sur Battle.net pour voir si il y a réellement une différence de débit en DL ? ... Sinon c'est juste cosmétique ...
7 minutes ago, Densha-Warrior said:
ah oui , ça je suis d'accord sur le côté cosmétique.
Mais bon, je suis trouve ça hyper bizarre quoi....
En tout cas, merci @Fuzy
Welcome !
I don't think there is anything wrong with the router, every connection is different so you'll never get the same results even compared to someone with a similar connection. For example, Fuzy has a base ping of 8 when yours is 24. This can affect speed, for Fuzy it will be a lot quicker to reach the potential speeds, with your ping it will take a little longer. I just tested this myself, using a close server I hit my 550Mbps pretty quickly at 9ms, choosing a different server which gave me 20ms I didn't reach those speeds until towards the end of the test. I suspect if the test was longer the speeds would be higher. Try a few other speedtest sites and see what you get e.g, Fast.com, https://speed.measurementlab.net/#/ (this is what we use for Benchmark),
Fuzy m'a demandé d'utiliser l'application w10 speedtest, on ne peut pas vraiment changer le serveur.
Mon ping est de 24, 23 sur bordeaux car ça doit passer à Paris avant.
Mon ping est de 15,17 sur Paris.
Avec mon Asus sur Nperf à l'instant:
30 secondes plus tard avec mon R2:
C'est un peu mieux. Vous pouvez essayer de créer une règle de contrôleur de trafic pour autoriser TOUT le trafic pour l'appareil de test et voir s'il est plus rapide
Bon, je ne vois pas l'intérêt de faire ça en fait.
Je pense surtout que le problème vient de mon port WAN. j'ai testé les différents ports LAN et ça fait exactement pareil.
Le port WAN a dû lâché à un moment donné, ou il a toujours été comme ça.
C'est pour ça que je parlais de la première édition du R2, je suis peut être tombé sur un mauvais exemplaire malheureusement.
Ce n'est pas un port défectueux ou cassé, si c'était le cas, cela ne fonctionnerait pas du tout. C'est juste parce que chaque connexion est différente, 800 semble être votre maximum malheureusement.
Bah non, je l'ai prouvé plusieurs fois:
Là ce n'est pas une question de connexion, c'est une question de ce que peut gérer mon R2.
est-ce que tu crois que c'est peut être une question de software ou hardware?
Software, j'en sais rien, j'ai fait plein de réupload de versions précédentes du firmware et plein de factory reset.
Je pense sincèrement que c'est hardware, ça doit venir de l'intérieur.
Je vais te raconte une anecdote:
j'étais chez un autre internet provider l'année dernière ("free" pour info), et le modem n'allait qu'à 880Mbits (c'était la mini 4k),
et le R2 allait donc jusqu'à 880Mbits (donc c'est normal)
sauf qu'une fois, j'étais sur mon routeur R2 et je faisais des benchmarks etc et d'un coup: il s'est comme freeze, éteint!
Je n'arrivais plus à le rallumer, donc j'ai appuyé comme un malade sur le reset etc
finalement il est revenu et depuis, bah il n'a jamais plus atteint ces débits max
Y a un truc qui a dû prendre cher
J'aurai peut être dû te raconter ça avant XD
C'était une connexion et un modem différents, donc ce qui se passe pour cela ne serait pas nécessairement le même. Après le crash, à quelles vitesses avez-vous pu obtenir cette ancienne connexion ?
Comme maintenant il me semble, je ne peux pas être certain car je n'avais pas trouvé à l'époque de serveur stable pour le max, donc ça oscillait vers les 600-700Mbits.
Mais sur le moment, justement j'avais retesté et il me semble bien que c'était plus bas directement.
Donc je l'ai vu mais j'ai pas vraiment fait attention.
là je viens de mettre mon R2 derrière le Asus pour tester, c'est exactement pareil.
Vous pouvez essayer de désactiver les options de protection dans les paramètres WAN, cela pourrait augmenter un peu la vitesse, mais à part cela, il n'y a rien d'autre à modifier
