XR1000 - QoS not working for Upload for PPPoE connection
Hi
I have changed my router to XR1000 and my internet is over PPPoE.  When I enable QoS its not working for upload.  I am getting full speed but not the allocated bandwidth.  And in-game its very painful.  I appreciate your help here.
Thanks
Badri M
It's something we're aware of and looking into, if you can use your ISP router to handle PPPoE instead then the upload will work on the XR
Hi
Thanks for the update.  ISP's router doesnt provide bridge mode.  To avoid 2 firewalls I went with my own router.
Regards
Badri M
You don't need bridge mode, you can use the DMZ instead which is essentially the same thing and will pass traffic straight through to the router and bypass the firewall
Hi @Netduma Fraser
I have enabled VLAN.  In that I see priority and it is by default 0.  Where do I find to know what are those values means?  I have one managed switch in that 8 means high priority port and 0 means least.  Here how it is?
Thanks
Badri M
Do you need VLAN? If you're not familiar with how it works you may end up cutting the internet. It affects the order in which packets would be sent, there is lots of information online about it, I'd recommend you research it if you want to use VLAN
If he use vlan badrisuper will have the same problem because netduma have a old bug on pppoe and vlan afecting qos uploud
Yes, I need VLAN.  I tried using ISPs router and XR1000.  There is lot of difference.  Even I can see that in dslreport.  So we need a fix and build to fully utilize the router's ability.  I have R2 and I changed it only for this reason again I got stuck.  Its little disappointing.
Thanks
Badri M
Thanks
Badri M
Do you have a ONT if yes you can use a smart-switch to untag the vlan to your wan port on the xr1000
Hi
Yes, I have managed switch.  Zyxel GS1200-8HP.  How do i do that?  From Media converter switch and assign vland id to that port.  right?
Thanks
Badri M
Thanks
Badri M
We are working on it currently, also the next update for the R2 will have VLAN included
ONT---MANAGED SWITCH--- XR1000
On your Zyxel you need to tag the vlan on the port you connect your ONT and on the port you connet your router you need to untag the vlan an set the ID-vlan to your vlan number you use.
I tried this way and I am able to connect.  But still QoS on upload is not working.  You sure it will work?
Regards
Badri M
Did you remove VLAN from the XR after you did it? If you're still using PPPoE you'll still have the issue
Looks like its working in R2 but QoS doesnt reflect in XBOX Series X.  Any suggestions?
Thanks
Badri M
How are you testing, via the network settings or through the web browser? Is Traffic Prioritization showing it is prioritizing when testing?
I did a complete restart and all started working.
Do you have any dates for new firmware release.  Because XR1000 handled 1GB speed very well and I was getting low ping as well.  But R2 is decent and still doesnt a match.
Thanks
Badri M
58 minutes ago, badrisuper said:
Thanks @Netduma Fraser.  Can you confirm that XR1000 QoS has problem even if I use switch for VLAN?
Thanks
Badri M
No if something upstream is handling these requirements then you shouldn't see the issue on the XR1000.
Thanks @Netduma Liam.  But I tried XR1000 multiple times it failed to apply QoS for Upload and the same is working for R2.  What is it I am doing wrong here?  I will try again.
Thanks
Badri M
Thanks
Badri M
The XR1000 should be handling any PPPoE or VLAN configuration currently, could you confirm that's the case?
XR1000 is handling PPPoE and VLAN is configured in a switch.  Like below
ONT -  Managed Switch (VLAN) - XR1000 (PPPoE)
Are both PPPoE and VLAN required? Can the switch not handle PPPoE?
Yes, both VLAN and PPPoE required.  Its a very basic managed switch.  It doesnt support PPPoE.
And I can confirm one more bug in R2 as well.
In R2, under traffic prioritization if I add ports 1-65535 in both source and destination then QoS wont work.  I am not sure what other combination will disable QoS.  But I can confirm this.  I spent half a day to identify why suddenly QoS failed.  In total, software is buggy if I want to use PPPoE.
Thanks
Badri M
