Warzone Lag - The usual Shoot first die first
  • Replies 128
31 minutes ago, Fuzy said:
Stop with the MTU guys, it's wind!
Ok so what suggestion do you have that i can try to fix this? My ping on the geofilter is always between 25-35ms. 450mb down and 50up. I run the connection tests and i get A+ in all 3. I still get the shoot first die first.
On 1/24/2022 at 11:35 PM, fabigas said:
why u change mtu in netduma? u can change it on playstation or xbox as well. So just the console is involved and Not other Things like netflix
you guys have a big huge miss understanding on MTU,
You can not change the MTU value on xbox it has to be done on the router side and unfortunately changing the mtu values under the wan settings for the DUMAos on the R2 do nothing for online gaming, NETduma team needs to fixe this or add MTU back to LAN like they had on both sides on the original R1
ON PS and PC change the values on the device its self when you play but remember to put them back when file sharing downloading or streaming
Unfortunately, there is no miracle solution! You can keep trying everything from here to there. The only advice I have to give you is to play!
